Question about Frigidaire Heating & Cooling
Frigidaire AC Window, Model # FAC107P1A2
Problem: Unit will not turn on.
My unit is only 2 years old and hasn't been used very much. When I installed it in the window and plugged it in, the unit wouldn't turn on. I've tried the test-reset button on the plug dozens of times, but to no avail. I have confirmed that the electrical cord does have power going into the unit.
  • MrBz62 Jun 29, 2008
    It was suggested to me that I leave the unit unplugged for several hours then try again. I did that and the unit still did not turn on.
    I welcome all solutions/suggestions.
    Sergeant:
  • 243 Answers
Have you checked the connections with a multimeter to ensure there is a signal. even at the ac have you checked that when the thermostat kicks on its getting the signal. If not get a multimeter and test it out and you can eliminate whether or not its the thermostat.
Posted on Jun 29, 2008
  • 6,487 Answers
Thats odd, something should light up. Check for a loose wire connector inside the machine, if you have volt meter, you may want to do some voltage checks after the main power connector comes into the machine from the back.
If still nothing that can be a problem with the Control Panel Board that you may need to replace it.
Hope that helps.........
  • 4,472 Answers
Have you checked the thermostat wires and the fuses?
Thanks,
Lee
  • 1,879 Answers
Greetings,
Calling a qualified repairman is the best option if you can't identify what part in the control board is malfunctioning using an electronic meter.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
  • 758 Answers
Check the themostat wire from inside to outside our dog chewed ours and needed to be replaced.....also your a/c has a fuse pullout next to the compresser with 2 long round fuses
I hope that helps
Please rate accordingly
Thank you
Computerrep
    Genius:
  • 1,142 Answers
Please check the unit if its getting power and the power should be having the correct voltage the check the remote to turn it on. Further info please write
  • 2 more comments
  • Maanita Chadha
    Maanita Chadha Jun 29, 2008
    It doesn't turn on at all
    Check to see if there is power getting to the air conditioner. If it is a 110-volt unit, plug a lamp or other device into the same outlet the air conditioner is plugged into. If there's no power, check the fuses or circuit breakers. If there's still no power, you will need to contact a qualified electrician to restore power to the outlet.
    If there is power to the appliance but it is still completely dead there may be a problem in one or more of the following areas:
    • Wiring (Inspect for any broken or burnt wiring)
    • Thermostat
    • Compressor
    • Overload and/or relay
    • Selector switch
    • Control board
    Work on these areas of an appliance may require help from an appliance repair person or other qualified technician.
  • Maanita Chadha
    Refer to this website this will help you a lot
    http://www.repairclinic.com/0088_16_1.as...
  • Maanita Chadha
    Dont forget to accept and rate the solution
    Regards
  • Maanita Chadha
    did you try the previous posting i gave
    Guru:
  • 1,894 Answers
Please leave the unit unplugged from the main power for few hours and check if it works
    Master:
  • 638 Answers
You have clearly mentioned in your question itself that electrical cord does have power going into the unit.i feel it may be the problem with your power cord wire . try replacing the cord first and check whether the power reaches the unit.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
I have an LG window air conditioner that's about 2-3 years old. The cooling function doesn't work. It just blows air and makes the air conditioning sound. How can I fix it? Is there a cheap...
Hello, this could be a problem with the thermostat on you ac and not turning on your compressor or the unit has no revrigerant in it. Here is a links to where you can buy window ac's online. http://www.amazon.com/Frigidaire-FAX052P7A-Window-Unit-Conditioner/dp/B000Q7GSHQ. You can also try sears they might be able to install a window ac for you.
May 13, 2011 | Heating & Cooling
No power
Could be some kind of fuse it the unit.
Aug 17, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Installing a window A.C. unit by maytag
no it shouldn't matter,just insulate the gap so you dont loose cool air,as for the draining problem tilt it some more,and make sure drain hole is open and not plugged that should fixya
Jul 29, 2009 | Heating & Cooling
CARRIER WINDOW AC IN INDIA
clean the drain system, find the restriction
Apr 21, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Ac compressor not working
This unit is a 220 volt ac unit. 12-2 wiring is usually for 120 violt circuits?
  • Amps: 22.2 / 20.0
  • Watts (Heat): 4900 / 4000
  • Watts (Cool): 1650 / 1625
  • Amps (Cool): 7.7 / 8.3
  • Voltage Rating: 230V / 208V 60Hz
  • Power Cord Length: 5' (6')
  • Horsepower (Cool): 2.49
  • Plug Type: LCDI 6-30P
  • http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRH1822R2
    hope this helps?
    Jun 05, 2017 | Frigidaire Heating & Cooling
    Fidgerdare electrtolux air conditioner
    have you brought it down for a general cleaning on the 3 year period? if not then that's what it needs now.
    the coil is freezing up because of dirt accumulation on the coil. even there is a filter, still with in 3 years it could have accumulated to decrease the airflow thru the coil and freeze it up.
    tnx 4 using fixya,
    drcool
    Sep 07, 2008 | Frigidaire FAC124 wall/Window Air...
    Fridgidaire ac window unit
    More than likely this unit could be fixed reasonably. It sounds from your explanation like a bad connection inside the control panel of your unit. Could possibly be what is called a cold soldered joint.
    Jul 18, 2008 | Frigidaire FAC126P1 wall/window Air...
    Frigidaire FAC107P1A2
    then there is some wiring that has bee damaged sir.
    you can open the unit and start investigating about this problem.
    but do it only if you have prior experience
    dont forget to accept the solution sir.
    thank you
    Jun 29, 2008 | Heating & Cooling
    Heating & Cooling Logo
    516 people viewed this question
    Top Frigidaire Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Bill Long
    Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
