Question about Kodak EASYSHARE Z1285 Digital Camera
Kodak Easyshare Z1285
My Koday Easyshare Z1285 will no longer turn on. It is only 2 weeks old and the batteries are fully charged according to the charger.
  • 5 more comments
  • drob0374 Sep 07, 2008
    My batteries died so I replaced them with a new set. The new set would not power it up so I purchased more and still no power. The camera is only 3 months old and has only taken about 35 photos. Any assistance would be appreciated.
  • Anonymous Nov 24, 2008
    1. will turn on .
  • Anonymous Dec 17, 2008
    I have sent the camera twice for fixex and it has done it once more; I think this camera is a lemon.
  • Anonymous Dec 31, 2008
    same problem; Christmas present to my (responsible) young son; used for 170 pix, now will not even turn on, even with fresh batteries. Very annoying as you others have same trouble.
  • rugbypro Jan 05, 2009
    i got the camra as a cristmas present and i had it for about 3 days and had took 75 photos and then i went to recharge some batterries and then put them in when they were full power and it dident turn on.
  • jax1401 Jan 19, 2009
    my camera was working perfectly but not it will not turn on, the batteries are fully charged and the correct ones for the camera, mine is now stuck with the lens fully extended! it turns on for a second and goes straight back off again but not enough time for the lens to retract.
  • Anonymous May 18, 2009
    The batteries are fully charged and the camera will not turn on.
Are you using the batteries listed as compatible according to the cameras battery door? Or are you using NON-compatible Alkaline or Ni-Cad batteries? Only Li-Ion and Ni-MH are compatible. Hope this helps...
Posted on Jan 04, 2009
Camera won't turn on with fully charged batteries. Camera worked fine for 2 years and 2 weeks after warranty was over it will no longer turn on.
Seems that the control board is faulty if you are quite sure that the batteries are fully charges and giving good contact.
Remove off battery for some time and reset the battery , hold down power and see if there is any signs of life.
If not the camera be referred to Kodak with a plea for consideration..you might get an advantage.
Sep 18, 2010 | Kodak EasyShare C613 Digital Camera
I was using my Koday M893 one day, and i sat it down for a second, when i picked it back up the screen was blank, and the lens is still out. The camera will not turn back on, and i feel like i have tried...
What exactly did you try?
Check these:
  • Fully charged batteries
  • Taking batteries our from the camera and reinserting
  • Other set of batteries
If you did try all of the above without success, the only thing you could do is take the camera to a local electronist, or Kodak dealer for repairs.
Apr 09, 2010 | Kodak Easyshare M893 Digital Camera
My camra worked just fine, then when I tried to turn it on it wont turn on no matter what I do
Please try the following: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 23, 2010 | Kodak EASYSHARE Z1285 Digital Camera
We have a kodak easyshare Z1285, it is only 1 year old and the last time it was used the lense extended and the camera will no longer turn on. We have tried new batteries, no change.
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak EASYSHARE Z1285 Digital Camera
I purchased a dharger for my z1285, however, I can
let the camera charge for about an hour and then turn the camera on there is a battery meter on the camera you might ave to go into the menu application
Oct 18, 2009 | Kodak EASYSHARE Z1285 Digital Camera
When the EasyShare digital camera is not in use, and the battery is fully charged, can I leave the camera (turned off) in the dock?
The EasyShare camera dock automatically stops charging the batteries after it registers a full charge, so it is fine to leave the EasyShare digital camera on the EasyShare camera dock for short periods. However, leaving the camera on the dock for longer periods (days or weeks) is not recommended because this can cause problems with your camera and the batteries.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Kodak EASYSHARE Z1285 Digital Camera Logo
419 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
