Question about Braun AromaDeluxe KF 580 Coffee Maker
Swing-out filter basket with pause and serve..not functioning properly
I received this coffee maker almost a year ago and have loved it up until recently. During the 'drip' phase..at some point..the brewed coffee stops coming out and stores up inside the filter basket area.
There doesn't seem to be anything broken with the lever mechanism. And I learned that there seems to be a rubber 'nipple' type stopper that covers the hole where the brew drips out. I could remove it, but figured its obviously there for some reason.
I would rather not return or send in for servicing if I can prevent it if there is an easier solution worth trying.
I even tried a drop of olive oil on the 'nipple' type stopper thinking it might prevent some sort of 'stickage' that was occurring, but same problem persisted.
  • vernfish33 Nov 17, 2008
    Sometimes the coffee stops dripping into the pot before the pot is full, pushing and tilting the pot makes it resume its fill cycle. The spring and rubber machanisms appear to be intact and the swing arm fits fine.
    Occasionally coffee will leak from somewhere on the bottom og the pot. The coffee mqaker works fine 60% of the time. I like the pot and not being able to solve the problem is getting to me. I consider fixing it a challenge.
Something wrong with your little 'grab a cup' mechanism. There should be 2 hinged plastic pieces (one of which contains the 'nipple', and one spring. The spring is shaped like a squared off 'U', and is about 2 inches long. Check to make sure all these parts are there, and move freely.
Also, check the basket. It dovetails onto a swing arm, and could be misplaced. If the basket is not positioned properly, the pot will not push up on the mechanism to let the coffee out. Make sure the pot is able to be pushed fully onto the hotplate and trip the mechanism as well.
Posted on Jul 17, 2008
Just bought a new Bunn Thermafresh and it overflows coffee grounds and coffee all over. What can I do?
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Don't overfill the basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Make sure that the Pause 'n Serve button isn't sticking. (If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.)
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Nov 04, 2009 | Bunn NHB Coffee Maker
I have a FTX49 Mr Coffee Maker purchased 9 months ago. It just started to leak in the front area where the round burner casing meets the tall front face of the unit (the groove area on both sides??) What...
There is a lever in the back of the carafe area that pivots and controls a spring loaged valve on the bottom of the removeable filter basket. This lever breaks easily. Pull the filter basket out and you can see the lever hanging down into the carafe "bay". (assuming it's not broken off entirely).
When you pull the pot out during brewing, the lever swings forward and allows the valve on the bottom of the filter basket to close. This shuts off the flow of coffee to avoid drips. The plastic lever is held in place underneath the valve by two round tab "ears". One of these ears can break off, causing the level to hang at an angle. This means the filter valve never completely opens, even if the pot is pushed in all the way. During brewing, the filter basket can't drain into the pot fast enough and overflows.
I fixed mine by going ahead and removing the damaged lever and then wedging the valve open. The spring loaded valve has a little drip "Spout" which hangs underneath the filter basket that directs the coffee into the pot. You can push in on the back of the drip spout and wedge something into the two slots at the back to hold the valve open. This let the coffee flow freely during brewing.
Oct 15, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee has doesn't drain into the carafe and just overflows all over the counter
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine or too course. (See instruction manual.)
4. Make sure the filter cone/basket clicks into place and that the carafe is pushed all the way in.
7. Make sure that the Pause 'n Serve isn't sticking. (If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.)
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket.
9. Make sure the coffee machine is sitting level on the counter.
Oct 05, 2009 | Zojirushi ECBD15BA Coffee Maker
When brewing the coffee at times the water stays and almost overflows where the filter and coffee is rather than brewing properly- what could this be and how to fix it?
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
3. Do not overfill tank with water. Use the marks on the side of the reservoir rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. (See your owner's manual.)
4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
Aug 13, 2009 | Cuisinart DCC-1200 Coffee Maker
Our coffee maker overflows,coffee grinds get in coffee and overflows.
Jul 11, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Coffee maker with grinder--sometimes, when percolating, it overflows
Jun 28, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Cusinart 12 cup grind and brew overflows with grinds and water
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
Apr 02, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Water overflows from filter basket
Dec 25, 2008 | Mr. Coffee ISTX95
Hamilton beach coffee maker Model 49464
Leave the carafe off the hot plate and place the basket in holder with the lip under hinged flange so it sits flat. Then replace the carafe and the basket should not move up when the Pause and Serve button opens. I just bought this pot too and
love it but except for the basket placement problem.
Feb 18, 2008 | Coffee Makers & Espresso Machines
Braun AromaDeluxe KF 580 Coffee Maker Logo
252 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
ellipse0904
Level 1 Expert
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
