Wireless WI FI problem
My wireless button lamp is always RED(means off)
I installed the driver soft ware from HP web site, but NOT working
I donno wt to do
  • soft_girl_86 Jun 29, 2008
    My lap top is HP Compaq Presario F500 F572US Notebook PC with WI FI high speed wireless LAN as I said, I downloaded the soft ware but the wireless button is always red
    I believe that my PC can't identify or recognize it
    thx 4 ur care
  • soft_girl_86 Jun 30, 2008
    Mine is BROADCOM & anyway my prob. 've been solved :D
    I've downloaded the software from HP then wn I turned it On I clicked F10 then Diagnostic then restart then It worked
    But now the problem is in the coprocessor, it needs a re installation in the device manager
    Thank you
  • 298 Answers
What is the brand or the model no. of your wireless router?
Does your wireless network adapter say working properly on its properties on you device manager?
Posted on Jun 29, 2008
Not able to use Wi-fi
go to the device manager. right click the My Computer Icon -> click on Properties click on the Hardware tab -> Device Manager button you can see all the drivers installed in your laptop. if you want to reinstall the driver, just double click the hardware you choose -> click on Driver tab -> click on the Update Driver button. select the path where you put the driver for your hardware. then click on Ok till you get to the desktop. then your done. test it.
May 25, 2010 | HP Compaq Presario C700T
I have a compaq presario F756nr with an Atheros wireless wi-fi card in it. Can I replace the wi-fi card with a Broadcom 802.11 b/g wireless LAN card?
no you cannot replace the built-in wi-fi card...
if you try to change the drivers for atheros wi-fi to Broadcam driver, your wi-fi card will not function anymore.... but you can always install another WI-FI card in your laptop... you can buy a USB Adapter or a Cardbus(PCMCIA) adapter for this purpose...if you want your wi-fi signal strenth and range to be higher, you can opt to buy an adapter which comes under N standard....N standard wi-fi adapters are capable of connecting at a speed of more than 300mbps(practically) to any N standard device like router....
Mar 29, 2010 | HP Compaq Presario F756NR Notebook
I m having MTN L broadband with HG520 wireless router but when i tries to connect from Nokia E72 itr is not accessible
Try to install wi-fi software in your mobile and connect your wireless router to your mobile it ranges to 30 -50 meters you can get soft-wares in dotsis.com
Jan 19, 2010 | Office Equipment & Supplies
Linksys WRT160 router doesn't work
Wi-Fi Protected Setup Button
If you have client devices, such as wireless adapters, that
support Wi-Fi Protected Setup, then you can
use Wi-Fi Protected Setup to automatically
configure wireless security for your wireless
network(s).
To use Wi-Fi Protected Setup, run the Setup
Wizard, or refer to the “Wireless > Basic Wireless
Settings” section of “Chapter 3: Advanced
Configuration".
Wi-Fi Protected Setup LED (Blue/Amber) It
lights up blue when wireless security is
enabled. The LED flashes blue for two
minutes during Wi-Fi Protected Setup.
The LED lights up amber if there is an error
during the Wi‑Fi Protected Setup process. Make
sure the client device supports Wi‑Fi Protected
Setup. Wait until the LED is off, and then try again.
The LED flashes amber when a Wi‑Fi Protected
Setup session is active, and a second session
begins. The Router supports one session at a
time. Wait until the LED is off before starting the
next Wi-Fi Protected Setup session.
Jan 01, 2010 | Linksys WRT160N Wireless Router
I have problem with the wi-fi network adapter.its just simply not detect wifi adapter in network adapters and my wi-fi is not working at all.i have installed drivers for wi-fi adapter many time evenif its...
If you know you installed the right driver and you know for sure that the device manager is showing no signs of the wireless card then the motherboard is probably bad.
To verify this, put another wireless card into the slot, if the system doesn't pick up on the 2nd card then that slot on the motherboard is bad meaning the motherboard would have to be replaced.
Aug 15, 2009 | HP Compaq Presario F500 F700 and G6000...
Wifi never turns on
This notebook is officially designed to work with windows Vista. Wireless won't be any problem in case you load windows Vista onto it. There are however some drivers available to work with windows XP which can turn on the wireless but the light on the wireless button won't change it will stay amber.
You can try:
Atheros wireless driver:
http://www.atheros.cz/download/drivers/ar5xxx/xp32-5.3.0.56-whql.zip
NOTE: The URL above will take you to a non HP Web site. HP does not control and is not responsible for information outside of the HP Web site.
Installation Instructions :
1. Download the spXXXXX.EXE file to a directory on your hard drive.
2. Execute the downloaded file and follow the on-screen instructions.
3. Restart the notebook when the installation is complete.
Download these files and save them for back up for future use.
Jul 08, 2009 | Compaq Computers & Internet
Wi Fi doesn't work. Have compaq 700. Says the
There are many reasons why wireless doesn’t work but lets look at it step by step
How it works is that there’s a card inside your laptop which detects networks “wireless only” that are in your house and near you like neighbours.
The most common mistake is “the button” there is bound to be a button either
On the side, the rear, the front of the laptop or even near the keyboard it usually has
A dot with signal lines that button switch on and off the wireless device so make sure its on and then wait 10 second for the signal to appear.
There is no button? Right then there’s a keyboard shortcut to switch it on and off
You must first press and hold the “fn” button or the function button then find the wireless key which is either “f8” or “f4” it varies from model to another but it always has the wireless logo on it and it is always one of the f keys.
Didn’t help? It could be you’re running multiple utilities to run your wireless, you either have to use windows utility which is normaly in your task bar but if that’s not working then another utility is using it, so find in your programs list “wireless utility” or “belkin utility” which usually does the same.
Didn’t help? Its getting more serious, makesure your driver is installed for the wireless, if you go to the device manager and then to the network area and there makesure your wireless drvice is enabled “no red cross on it” or else if you cant find a wireless device in there then it means your wireless card is faulty and need an expert looking at it.
It is good practice to re-install the wireless driver to fix most issues.
Mar 07, 2009 | Compaq Presario 700 470024-192 Notebook
I have an HP Pavillion DV4000. My built in wireless is not working. The light at the top of the keyboard does not come on. How do I get it to work?
you can see the wi-fi switch...you turn on and it will work if you install already the wireless driver...its only the problem with the switch combination between wireless..there some option also for enabling the wi-fi...you can press FN key + wi-fi botton.
Jan 28, 2009 | HP 14.1 Refurbished Thinkpad, 1.13GHz...
Wireless no longer works
1st Solution:
Check if the wi-fi card is properly installed under Device Manager. Go to Start then look for Control Panel on the right pane. Under Control Panel look for System and Maintenance and then click on Device Manager. Now under Device Manager look for Network Adapters and collapse or click the arrow next to it. Check if your wi-fi adapter is installed(10/100 or 10/1000 is your LAN adapter, wi-fi adapters usually indicates something like 802.11x(could be agn or g or b) or the word "wireless". If you don't see anything I mentioned above that means your computer is unable to detect any wi-fi adapters installed. Know if you found a wi-fi adapter but there is a yellow exclamation or question mark, all you have to do is re-install the drivers for your wi-fi adapter(you can download the drivers on the Compaq website for free.)
2nd Solution:
Check if the wi-fi is disabled or stopped, if you have a bulit in wi-fi adapter on your laptop they have a wi-fi switch on the side or near the function keys(F1, F2, F3 up to F12). Wi-fi button/switch will have a logo or marking of an antenna that has waves coming out of it and there is a LED light that will indicate if its on or off(for Comapaq laptops it's either a blue button at the front, near the function keys or at the front panel on the buttom edge.
If both fails then you may need to contact Compaq for further assistance.
Hope this will help you fixin the wi-fi problems on your laptop.
Regards
Nov 23, 2008 | Compaq Presario Notebook
Drivers for Wi-Fi (drivers for Ethernet Controller and Modem Device on high definition audio bus)
Not much offered at Compaq's driver site for XP. For the modem driver, try the link below, it says it's for Vista, but it should work. If it doesn't then you will need the make and model of the modem, then go to the manufacturer's site or driverguide.com for the drivers, and the same for the wireless, make and model, manufacturer's site or driver guide. To be honest with you, modems are just about obsolete, unless you have dial up at home, you'll probably never use it.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&lang=en&dlc=en&product=3739733
Jul 09, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
372 people viewed this question
David Payne
David Payne
