Question about Dell Axim X3 Pocket PC
Two way synch for dell axium x3 pda
How do I synch from both the dell axium x3 pda and my computer I can only synch from the pda now.
I didn't know this was a paid plan.
Thanks anyway
Posted on Jun 30, 2008
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
AXIM X3 Language
1. Download Axim X3 English (A01) setup, link from here -->
2. run the setup and make a backup ROM of youre x3, save someplace handy. I now have a file named A01-10240300GE.RIS
3. Run setup again, try to upgrade, get an error message - wrong language, etc but in that DELL folder, you now have a file named, in my case, P16R_A04080402EN.IMG
4. Open with a hex editor A01-10240300GE.RIS and copy all lines from 00 to 07
5. Open with a hex editor P16R_A04080402EN.IMG, select all lines from 00 to 07 and paste there the 7 lines from the first file, save with any name WITH .ris EXTENTION!
6. Run setup again, choose backup/restore and point to the modified .ris file. Now you have the same thing in that window, up and down side.
The PDA restarts itself and, voila, you have axim x3 with a new language.
Jul 28, 2009 | Dell Axim X3 Pocket PC
WHere can I buy a wireless card for my Dell Axim X3 PC.
the pda has 1 Integrated SD/SDIO Now!/MMC Slot
you can buy a SDIO wireless card
Best deal will probably come from ebay have a look here
Let me know if you need anything else.
Feb 17, 2009 | Dell Axim X3 Pocket PC
Dell Axim X3 HC02U Pocket PC PDA
Feb 02, 2009 | Dell Axim X3 Pocket PC
Hot Synch an existing PalmVx data to a replacement palmVx
The first thing you want to do is to do a Hard Reset on the used PDA that you bought as a replacement. To do that follow these steps:
1. Hold down the power button and then depress the small hole in the back with the tip of your stylus.
2. Continue to hold them both in until you see the Palm logo.
3. Let go of both of them and then follow the onscreen directions. You will want to answer yes and use the 5 way navigation button on the bottom of your pda and hit up so that is completes the reset. After that you will have to set up your touch screen and go through the tapping the target. After you have gone through all this then do a hotsync2.gif. It should clear up your problem. Best wishes.
Dec 12, 2008 | Palm Vx Handheld
I just bought a palm Z22 PDA. I used the AC charger to charge the Z22 but when I attempted to attach the USB synch cable I noticed that the plug is different from the plug on the AC charger. The USB...
I have concluded that the USB synch cable is not the correct one for my Palm Z22 PDA. There is only one point of attachment on the PDA and it is different from the plug on the USB synch chord. This was the last Palm Z22 PDA in the store so I think that the store clerk rounded up leftover parts and components of previous PDA kits and tried to make a complete set out of it. I am going to return the PDA to the store (Staples) in the next day or two.
Thanks for your offer of help. I will contact you again in the future if I need help.
Oct 15, 2008 | Palm Z22 Handheld
Email forwarding
You can only sync your inbox through Activesync with Outlook not Outlook express. There is a full version of Outlook on the CD that came with the Axim. You should be able to move your data from OE into Outlook.
Sep 19, 2005 | Dell Axim X3 Pocket PC
Sync problem
I assume you use activesync. Check in the options that it is set to synchronise this data. if you have already done this try reinstalling activesync or installing the newest version, 4.0.
Sep 15, 2005 | Dell Axim X3 Pocket PC
Sync problem
I am assuming you use activesync. Check in the options that it is set to synchronise this data. If you have already done this try reinstalling activesync or installing the newest version, 4.0.
Connecting Axim plus Palm on the Same PC
I may be wrong but each PDA (assuming you are connecting different brands) have different drivers. I connected a Toshiba and Dell PDA and each required their respective install disk with their respective drivers. Then I configured each pda using the Active Sync Connection Wizard. Everything ran smoothly after that.
Sep 14, 2005 | Dell Axim X3 Pocket PC
Dell Axim X3 Pocket PC Logo
106 people viewed this question
Alun Cox
