Top Load Kenmore 20832 that won;t agitate
Mike:
I have patsed your response to a similar problem below. I think your solution will work for me as well. I just need to clarify that I have to make the repair from the bottom of the machine as there is no access from the rear and removal of the back panel is proving difficult.
Thanks in advance
Hugh
posted by cmpulley on Jun 23, 2008 Report abuse
Washer filled and when it got ready to agitate it made a loud noise and did not agitate and would not spin. I emptied the machine by pressing on the switch under the lid. I tried other sections on the dial to see if it would agitate or spin and it will not.
Can you help?
Post Solution Work Queue --> Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Best Solution posted on Jun 27, 2008
mikedurland
Rank: Guru
Rating: 88%, 30 votes
this sounds like the direct drive coupling between the motor and transmission. very common problem and not very expensive. look under the machine and and between the motor and transmission you will see a round rubber coupling and 2 plastic pieces one on either side; they all connect together to mate the motor and trans without a belt.
  • 1 more comment
  • Hughbwc Jun 30, 2008
    Mike, this was very helpful. I am orederin gteh parts for this repair tomorrow. Thanks and have a great day.
  • Hughbwc Jul 02, 2008
    Mike:
    I was able to replace the coupling and get teh cabinet back together. My problem now is that the water level switch isn't working. It doesn't shut the water off and start the wash cycle.
    Mike that did the trick. It wasn't pinched however I took it off and replaced it and then it worked. I will keep an eye on it for the next few loads. Thanks again.
  • 481 Answers
  • yes you can make the repair from the bottom.
  • or you can unscrew and flip back the control panel revealing 2 metal spring clips that hold the case in place. use a screwdriver to release the spring clips and the whole case will come off.
  •  it is a little tricky to put it back on though so you might want to just try to access it from the bottom.
  •  lay the machine down on its side and you can see all the components from the bottom.
  • start with the water pump (2 metal clips holds it on)
  • then the motor (also has metal clips but larger and may have retaining screws)
  • this will give you full access to the coupling
Posted on Jun 29, 2008
  • Mike Durland
    Mike Durland Jul 02, 2008
    • when you put the case back on did you notice a translucent plastic tube running alongside the wire harness?
    •  this is the water level pressure tube.
    •  flip back the control panel and make sure it is not pinched between the case and the rear panel.
    • if it not pinched then make sure it is connected to the tub properly, if even a little air gets in while it is filling up it will over flow.
    • let me know how it turns out.
My kenmore top load washer will not spin. It fills, agitates, drains, then wont spin, it will not spin on the first spin cycle, it will on the second cycle. The model number is 110. 20832 990.
Try it in all the timer cycles. If it still does it then your transmission might need to be inspected. It is a simple design. Remove the agitator and then yank out the tranny. Remove the clutch and transmission cover. Inspect the main drive gear and the spin pawl beneath it.The main drive gear show in this 30 sec video is plastic (click on the link). The new gear comes with a matching pinion for around 75 bucks. More HERE
Apr 06, 2011 | Kenmore Washing Machines
I have a kenmore top load washer, The top part of
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The top section of a two part agitator is designed to turn only one way. If the "agitator dogs" in it are worn, it wont agitate either way.
Look at the section on the Sears site for Agitator, basket and tub.
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following on how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136
Oct 28, 2009 | Kenmore Washing Machines
My agitator turns sopradically.
pop the cap off it,you will see 4 little gears called dogs,theses have to be replaced they work the agitator-mike
Jul 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore top load washer top agitator not moving
HI, this is exactly what you need to eliminate this issue.i will list the part number below. you can click on that number to order the kit directly from the parts store if you wish.
285727
Jun 21, 2009 | Kenmore Washing Machines
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
Tell me more Is there voltage to motor? The transmission makes it agitate .
May 28, 2009 | GE WBSR3140DW Top Load Washer
Kenmore washer agitator will not work.
is it a kenmore top load washer?and does it spin and drain?let me know more-mike
Mar 31, 2009 | Kenmore Washing Machines
Agitator slipping
is it a top load washer?if so there are 4 dog ears under the agitator cap that turn it ,you need to replace them($2 at your local appliance parts store-mike
Mar 19, 2009 | Kenmore Washing Machines
Washing Machines Logo
204 people viewed this question
Top Washing Machines Experts
