Question about LG Washing Machines
WE HAVE A 4 YEAR OLD WD-127*FHB WASHER. wHEN YOU GO TO START IT IN ANY MODE IT WILL PAUSE, START FILLING WITH WATER THEN START TO ROTATE FOR A SECOND THEN STOP AND A SE MESSAGE COMES ON THE DISPLAY SCREEN. tHE MACHINE IS ON A BOAT AND GETS LITTLE USE AND HASENT BEEN RUN SINCE LAST SEPT. aNY IDEAS?
  • brucemel43 Jun 29, 2008
    Yes the machine sits stopped with the SE display flashing
    Genius:
  • 3,422 Answers
Its an indication of a motor or motor drive circuit fault.
Check out the carbon brushes in the motor. Theyre graphite blocks which transfer mains power to the copper segments of the motor - located at the other end of the motor from the drive pulley. Theyre probably worn down. They're quite cheap parts and easy to replace - the holders are plastic or bakelite and are generally held in with screws or plastic clips. Also, look at the copper segments they run on to check for burning or pitting. If the segments are burnt or damaged you need a replacement motor or a replacement armature (motor part) if you can source one. Occasionally may be a fault in the motor drive circuit board - in which case replacement of board only real option.
Posted on Jun 29, 2008
  • Priya darshan Jun 29, 2008
    Please don't forget to rate the solution.
    Guru:
  • 1,894 Answers
Then you say that it does not even get into spin cycle?
am i right?
  • dewan nafees ahmed Jun 29, 2008
    It doesn't pump or spin
    If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
    • If
      the motor is running, your washer probably has a frozen pump pulley or
      a broken pump belt. To check the pulley, remove the pump from the
      washer and try to rotate the pulley manually. If it doesn't turn
      freely--if it's frozen or stiff--replace it. If the pump belt is broken
      or looks quite worn, replace it--but be sure to check the pump pulley
      before you change the belt.
    • If the motor isn't
      running, the lid switch may be defective. If so, the washing machine
      can't spin and may not function at all. The switch is inside the
      washing machine main housing near the door frame. Often you have to
      raise or open the top or front of the washing machine to get to the
      switch. If it's defective, you need to replace it.
    It pumps, but doesn't spin
    If your washer pumps out the water but doesn't spin, check these:
    • The
      lid switch may be defective. If it is, the washing machine doesn't
      spin. The switch is inside the washing machine main housing near the
      door frame. Often you have to raise or open the top or front of the
      washing machine to get to the switch. If it's defective, you need to
      replace it.
    • The motor coupler may be broken. Many
      Whirlpool®-manufactured washers use a small, relatively inexpensive
      motor coupling. It's plastic and rubber and is mounted to the shaft of
      the motor on one side, and to the transmission on the other. Over time,
      the coupler wears out and fails. You may need to replace it.
    • A
      belt may be broken. Many washing machines have one or two belts. If a
      belt is broken or badly worn, you need to replace it with a genuine
      belt from the manufacturer. (Some washing machine belts are designed
      with special characteristics not found in automotive belts.)
    • The
      clutch may be worn. If your washer is a GE, it may use a clutch to come
      up to the proper spin speed. As the clutch wears out, it may prevent
      the unit from spinning well or at all. If the clutch is worn, you need
      to replace it. For this job, you probably want to hire a qualified
      appliance repair technician.
    • The drive motor may be
      defective. Many washer brands use a reversing motor. For agitation the
      motor runs in one direction, for spinning and draining, the other. It's
      possible for a motor to burn out in one direction and continue to
      operate in the other. If this happens, you need to replace the entire
      motor.
    • The transmission may not be shifting properly.
      Older washers produced by Whirlpool® have a transmission with an
      electro-mechanical shifter. If the shifter becomes even partially
      defective, the unit may drain the water but not spin. This is a complex
      system, if your washer has a shifter problem, you may want to hire a
      qualified appliance repair technician to repair it.
    • The
      spin bearing or basket drive may be worn or seized. These components
      allow the inner tub to spin freely inside the outer tub. When this is
      the problem, you usually hear a loud sound during the spin cycle. Call
      a qualified appliance repair technician.
    It spins only with the lid closed
    For
    safety, washing machines are made so that they spin only with the lid
    closed. The lid switch prevents the spinning action when the lid is up.
Why is the SP light flashing when the machine has filled with water and is ready to go
sp is the code for stand by or pause
so if you have set a soak period then it will stay there until the soak period has finished
if it is sp and you have pressed pause/start extra time the machine is in pause mode until you press start again
Sep 29, 2016 | Simpson Washing Machines
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Hi, I have a F & P top load washer (model GW701-U) over 10 years old. I use cold water washing. The water fills up very very slowly- just dribbles. After about 7 minutes of the water filling up, the...
Turn off the water to the washer, unscrew the hoses ( do one completely before moving to the other)Once you unscrew the first hose you will see a small filter screen inside the opening on the washer,Remove the screen and clean it, replace it and reattach the hose,Now go to the other hose and do the same thing, once both are done and hooked back up, turn the waterback on and everything should work as normal.
Dec 02, 2010 | Fisher and Paykel Washing Machines
Wont stop filling
If when you press pause while filling and it keeps filling then you have a faulty valve. If the filling stops then valve is ok.
If you filling keeps going until overfilling the machine which is what i understand is your problem, then most likely that you have a small pinhole in your pressure tube.
Apr 18, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Kenmore serie 80.does not stop filling water in and does not star
Yeah I've seen that happen a many of times. Take the back of the control panel off and where your load size selector is you'll find a little hose that's suppoed to be attached to the side of it. just reattach it and you'll be back up and running.
Almost all washing machines use a pressure tube that tells the washer when to stop filling with water. If the tube comes off for some reason the washer will never stop filling and that's an instant flood if you don't notice it quick enough. Also a hole or puncture of any kind can be causing ti to never stop filling as well.
Hope this helps
Jason
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Roper washer
I have the same damn issue with my Samsung washing machine(Top Loader) Not quite sure why it does it.Help please really annoying.
Jun 05, 2008 | Whirlpool LSB6200KQ Top Load Washer
Screeching Noise From Fisher & Paykel GWL115 Washer While Filling
if its while filling may be water pressure try turning tap down (hot)
Apr 04, 2008 | Washing Machines
Agitator always moving
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
Nov 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washer does not wash or spin
the electronic module who drives the motor its the problem . you can order and replace find part at partstore.com go by brand and model let me know if you need more help thanks
Jun 20, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
71 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
