1st You download Webcam Driver.
A4tech Pro Viewcam-Model pk-865
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
SOURCE: Driver for A4TECH PK-MAR ViewCam
http://www.a4tech.com/ennew/download%20driver.asp Go to this site and enter your make and model number, on
the next page that comes up click the pc driver button. Once it pops up the download window save it to your desktop
so you have it for future use. Move it to somewhere you will be able to find it if you need it again so you do not have
to download it again! Unzip the file with winzip and run the install program and you will be up and running. If you need
more help feel free to contact me [email protected] I will help you for free,I do this for a hobby. Send me your
number and I will walk you through the whole process. Hope this gets you going, If not get in touch and I will help you
until we get it working. Thanks,
George
SOURCE: my webcam failed to connect after installing model a4tech PK-635M.
Normal
0
Try disconnecting the Camera from the USB port and reinstall
the CD or Downloaded software program. When the program asks you
to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
SOURCE: install A4 tech PK635 M web cam without cd installer
1. Go to: http://www.a4tech.com/ennew/downloads.asp
2. Under the"Downloads" section, you will find 2 fields. Click the arrow next tothe field labeled "SELECT" & choose "PK" from the drop-down menu.The second field will display "130MG". Click the arrow next to thisfield & select "635M" from the drop-down menu.
3. Click the "GO" button.
4.In the next page: in the orange side-bar to the left you will find yourweb cam model & 2 buttons. Click the button labelled "Driver ForPC". This will start the download of the installer for your web cam.
SOURCE: i lost cd a4tech viewcam
A4tech Viewcam Pro Pk 835 Webcam Driver Download
Driver FileName ( s ) :A4_IM_Magician.rar
Feature :For MJ & E Series
Apply for Model ( s ) :
PK-760E ' PK-336E ' PK-335E ' PK-333E ' pk-635E ' PK-836MJ ' PK-835MJ ' PK-800MJ '
PK-750MJ' PK-730MJ ' PK-720MJ ' PK-710MJ ' PK-600MJ ' PK-200MJ ' PK-130MJ ' PK-30MJ
' PK-8MJ ' PK-5MJ
System Requirements :
Windows 2000/XP/Vista/Win 7,MAC10.4.8
Version :V1.0
Update :2010-11-22
Download Link: http://hotfile.com/dl/97484719/c131bdf/A4_IM_Magician.rar.html
Notes:
* All PC Drivers are in Zip format . Therfore , if you do not have Zip software yet
, please download & install WinZip before installing the device driver .
Instruction on How to download and install the driver properly :
1 ) Press Download button to download the desired driver .
2 ) Save it somewhere where you will remember after download . We recommend that
you save it on your desktop , so it will be easy to find .
3 ) After successfully downloading the driver , do not open the driver file until
you make sure the following has completed : ***REMOVE / UNINSTALL any original
mouse driver from the PC . ( If you forgot to do this part , your driver may not be
able to install correctly and successfully later )
4 ) After the original mouse driver has been removed , open the downloaded file .
5 ) Follow the on-screen instructions .
6 ) When it's successfully installed , please restart your computer .
7 ) After you have restarted the computer , plug the webcam into your computer and
it will automatically recognize the new hardware.
