Question about Gateway Media Center 610XL PC Desktop
Monitor flashes After starting up windows the monitor starts to flashes after about an 1-2 hrs of operating and gets bad, then starts to flash every 5 seconds. I shutdown and restart atfer an hour or so it seems to work ok then starts to flash.
  • spoveda Jul 08, 2008
    I have the same problem with may media center.. could anyone help us??
  • mannuel_rubi Jul 16, 2008
    i have the same problem i though it was a virus first but i started noticing that everything was running smoothlybutt the monitor started flickering and it gets worse does anyone have any solutions for this.
I had the same problem with the flashing screen. It turned out to be the anti virus - anti spyware software was somehow screwing with the harddrive files. I uninstalled the anti virus and spyware program and that stopped the flickering. Hope this helps.
Posted on Aug 20, 2008
I just changed the oil and filter on my LX420 twin cam how do I get the blinking light to go out. Its a 2006
  • The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display.
  • The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time.
  • CHG"/"OIL"/TIME will alternate on the display for five (5) minutes after the meter reaches 50 hours.
  • While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five (5) minutes.
The display will also flash as described above for five (5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two (2) hours.( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...)
THE METER DISPLAY WILL RESET TO NORMAL AUTOMATICALLY, after the reminder maintenance time interval of two (2) hours. There is no method of manually re-setting this Service Monitor gauge.
May 01, 2017 | Cars & Trucks
Tip
MultiBoot USB Flash - Survival Guide
Grub4DOS is a boot manager
that can be easily installed to a USB flash.
It allows booting multiple operating systems
from a simple graphical user interface.
1.) Format the USB flash drive in the FAT32 or NTFS filesystem. (Windows)
Download and start HPUSBFW.EXE )http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
-REMINDER!!! all data will be deleted on the USB flash-
1.a) Download necessary files
Grub4Doshttp://dl.dropbox.com/u/4040651/grub4dos-0.4.4.zip
Grub4Dos gui Installer 1.1
http://dl.dropbox.com/u/4040651/Grub4Dos%20gui%20Installer%201.1.rar
1.b) Extract the downloaded zip files into separate folders.
For example:
Grub4DOS to C:Grub4DOS
Grub4Dos gui Installer 1.1 to C:
2.)
If your flashdrive is not already plugged into the computer, plug it in now.
2.a) The next step is to run the Grub4DOS Installer.
Browse to the Installer's unzipped folder using Windows Explorer.
2.b) Run the grubinst_gui.exe program (Windows XP)
Right-click on grubinst_gui.exe Run as administrator (Windows 7)
2.c) Once the program is started, select the Disk option,
then click the Disk Refresh button and then select
your flashdrive from the dropdown box.
IMPORTANT:If you accidentally select the wrong drive,
you may not be able to boot your system without doing a boot repair.
2.d) Now click the Part List Refresh button,
then the dropdown box and finally select the Whole disk (MBR) option
2.e) Click the Install button to install Grub4DOS to the MBR
of the flashdrive.
Hopefully, you'll get the message that the installation was successful.
3.) The next step is to copy the grldr file to the flashdrive's
root folder.Using Windows Explorer, browse to the folder
where you unzipped
the Grub4DOS program and copy the file to the flashdrive.
3.a) Grub4DOS is now installed on the flashdrive.
4.)Download file
menu.lsthttp://dl.dropbox.com/u/4040651/menu.lst
4.a)You need to copy the menu.lst file to USB Flash
4.b)Create a folder Boot on a USB flash drive.
in this folder create new folders
Splash
menus
4.c) Download file
Snaiyahttp://dl.dropbox.com/u/4040651/Snaiya
4.d) On USB flash-open the folder Boot
Within-we see Splash folder. Copy the file Snaiya into it.
5.) Add Puppy Linux on a multiboot USB flash
5.a) Download the Puppy ISO imagehttp://www.puppylinux.org/
5.b) Create a folder Puppy on a USB flash drive.
5.c) Take from the downloaded ISO, file
PUP_420.SFS (from the folder Puppy)
Rename it to pup_420.sfs
and copy it to
USB flash.
5.d) Copy all other files from the downloaded ISO (from the folder Puppy)
to the folder /Boot/Puppy/ (Create a folder on a USB flash)
5.e) In the menu.lst add a:
title Puppy
kernel (hd0,0)/boot/Puppy/vmlinuz ramdisk_size=100000
initrd /boot/Puppy/initrd.gz
5.f) Preserve the changes and now menu.lst looks like this:
gfxmenu (hd0,0)/boot/Splash/Snaiya
timeout 30
default 0
title Puppy
title Boot from CD-rom
cdrom --init
map --hook
chainloader (cd0)
title ShutDown PC
halt
title Reboot PC
reboot
5.g) Puppy on our MultibootUSB flash-is ready for operation.
(Now we can restart our computer and see how it looks and works)
Depending on the options your motherboard, it is necessary when starting
your computer keyboard press: F8 or F12 or Esc, etc..
Thus you will appear a menu where you choose your USB flash drive.
on Feb 07, 2011 | Computers & Internet
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
Every tym i insert my pendrive it says insert disk into the drive...???removable disk appears..but it doesnt opns...is there any solution...plz do help me
Assumption 1
Flash drive is damaged, the normal operating system.
Solution
If the flash drive is detected (eg; detected the flash drive in drive G), but it says "insert the disk into the drive ..."
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download).
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
If the flash drive is not detected (not detected as drive G),
the above solution can not be used.
Assumption 2
Normal flash drive, the operating sytem is corrupt
Solution
Flash drives do not require drivers (plug and play). Because flash drives plug and play, it should be, when the flash drive inserted detects the operating system without installing drivers. But, if the operating system does not detect, the possibility of operating systems corupt. The cause is a virus corrupt your operating system.
1. Download and install anti-virus Avira or AVG (free).
2. Update anti-virus
3. Scan your computer.
4. Repair the operating system.
5. If no virus is detected, the possibility of operating system is corrupt.
I hope this information helps.
Oct 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My pc can't open and flash in monitor "you can
1) Insert your original Windows XP Professional CD into your optical drive
2) Boot your system from the CD
3) When you see the blue screen look for an option that lets you repair your existing operating system
4) Follow the instructions displayed on the screen very carefully and finally let the program repair your corrupted operating system files.
Jun 03, 2011 | Microsoft Windows XP Professional
How do i reset the change oil light on a 1040 cub cadet 1000 series
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Aug 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have a samsung syncmaster 204T monitor. Everything was fine until last night when i kept my system on standby for approx 5-6 hrs. Now whenever i start my system there is only a green led on front panel...
I just started having the same problem! The green light flashes, but the monitor is blank. None of the button work (menu, source, etc...) and nothing changes when I disconnect it from the computer. I was suspecting a bad graphics card at first, but now I'm thinking the monitor itself is bad?!
Jun 29, 2010 | Samsung SyncMaster 204T Monitor
Sandisk Cruzer Micro 2GB Usb Flash Drive. Windows was unable to complete format!
Try this:
STEP 1 - Optimize the flash drive for performance
1. Plug in the device to the PC.
2. Double-click My Computer.
3. Right-click on the flash drive, then select Properties.
4. Click the Hardware tab.
5. Select the SanDisk Cruzer USB Device disk drive, then click Properties.
6. Click the Policies tab.
7. Select Optimize for performance, then click OK.
STEP 2 - Format the flash drive
1. Double-click My Computer.
2. Right-click on the flash drive, then select Format.
3. In the File system list, click NTFS.
4. Click Start.
5. Click OK to start formatting.
Jan 13, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Toshiba Laptop SPA 10 -WONT START
that just sounds like the hard drive running, try plug an external monitor and see what happends
get back to us
regards
Nov 27, 2008 | Computers & Internet
About a problem in my viewsonic monitor
Hi
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Oct 06, 2008 | ViewSonic VE710s  (Black, Metallic...
Gateway Media Center 610XL PC Desktop Logo
54 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
