Question about GE Profile Harmony DPGT750EC Electric Dryer
Need Help i have a ge  profile dryer dpgt750 the touch screen is out of sync. how do i fix this?
  • Anonymous Oct 15, 2008
    Same model GE Dryer DPGT750 EC. Touch screen doesn't work properly. About 1 1/2 years old. Right now it only works on Silk and Knit. Seems to be getting worse.
I had it unplugged for days, still wont syn
Posted on Jul 06, 2008
  • 54 Answers
Have you tried unplugging it for 3 min? That will reset the computer. If that don't work you might need a new touch screen \ computer
Posted on Jul 04, 2008
My GE dpgt750 dryer will not power up sometimes, but if I unplug the unit for a period of time it will come back on.
I replaced my thermistor heat sensor in the back and it began to work immediately, then after 4 or 5 loads it repeated the same problem. The next time I got it to run I made sure to run it only at 3/4 temperature or lower and was able to keep running all day. Is there something I am missing with this fix? David
Nov 21, 2011 | GE Profile Harmony DPGT750EC Electric...
I have a GE profile dryer dpgt750 and it will not get hot only stay wsrm
you need to access the cycling switch and the sensors in the dryer heater/blower housing and possibly replace the drying sensor bars by the door on the unit
Oct 03, 2010 | GE Profile Harmony DPGT750EC Electric...
I have a GE Profile Harmony Dryer DPGT750. The machine makes a loud, almost grinding noise when the dryer is operating. It also sounds almost as though the drum is out of balance. It is more noticeable...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 26, 2010 | GE Profile Harmony DPGT750EC Electric...
GE profile electric dryer, sounds like something is stuck in drum
Heating problem is most likely caused by one strand of your heating element is burned out. Heating element will have to be replaced if that's the case. Noise you are hearing is most likely coming from worn front and / or back bearing. Dryer has to be completely disassembled for either repair.
Aug 28, 2017 | GE Profile Harmony DPGT750EC Electric...
I have a G.E profile dryer dpgt750 cant seem to figure out how to take off the back panel, the dryer is making a loud noise sounds like possible belt problem. any ideals? THANKS MARTY
Marty, you need to remove the front cover on these and most dryers by removing lower front kick panel screws, then remove the front cover and then you access the top cover screws to remove top cover then you can access th drum belt
Nov 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
GE DPGT750 Gas Dryer runs but no heat
if your blower motor isn't getting up to speed it won't heat.check troubleshoot mode by holding my cycles and help at the same time for three seconds.may need a new blower motor
Mar 09, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Plastic box with wire on back of ge profile harmoney DPGt750
It's hard to tell for certain from your post, but it sounds like you broke the wire to a thermistor (part # WE04X10111). It is a little temp sensor which extends into the dryer about a inch with two same colored wires coming out of the exterior end. Easy to replace. remove cover, remove one screw holding thermistor. unplug white disconnect block. install new part. very simple, saved the $118, only cost ya the price of the part. (maybe about $35 or so) A FixYa rating would be appreciated. Thanks.
Sep 19, 2008 | GE Profile Harmony DPGT750EC Electric...
GE DPGT750 not heating
check your email this manual will take you step by step thru the repair
Jul 02, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
683 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
