Question about Minolta Maxxum 7000 35mm SLR Camera
Lithium battery I have replaced the lithium battery with a new one and have three fresh aaa batteries however the camera is still dead. What to do now Info please.
    Problem Solver:
  • 3 Answers
Maybe just a typo, but you know it requires 4 (not 3) AAA batteries. The holder swivels to the side to expose a 4th battery slot that is sort of hidden under the others. Put a volt meter on the 2 tiny contacts to the right of the batteries. Make sure you get very close to 6 volts.
Posted on Aug 19, 2008
Try letting the camera set for a while with the new batteries in. I had the same problem, nothing worked after i replaced the batteries. I let it set for a couple of days and everything started working.
Posted on Aug 02, 2008
Can i put AA batteries in my finepix F60 camera instead of using the lithium ion battery
I doubt you could fit three AAA batteries inside the camera. Chargers aren't that expensive if you know where to look. Take a look here for some examples.
Oct 26, 2012 | Fuji FinePix F60fd Digital Camera
Immediately request battery replacement
Standard AA's also have current capacity limits. When you buy them have to check to make sure its fresh alkaline battery 1.5 v LR6 ?
Jun 25, 2012 | Panasonic Lumix DMC-LZ2 Digital Camera
How do i charge a vivicam 8690
You don't. The 8690 uses three standard AAA batteries. You can use disposable alkaline or lithium batteries, or rechargeable NiMHs. If you choose to use rechargeable batteries, you must charge them outside the camera using a separate battery charger.
Dec 23, 2011 | Vivitar ViviCam 8025 Digital Camera
I put new lithium triple aaa batteries in my TI-83. Nothing happened . days later it turned on worked for a little while then stopped. would it help to change the round lithium battery? Do you know what...
The button cell backup battery keeps the memory electrically refreshed when the calculator is turned OFF. The necessary power for regular use is supplied by the 4 AAA batteries (main power). That nothing happened when you put in a fresh set of (expensive) lithium batteries may be due to the screen being too dim to see anything.
If the calculator displays RAM CLEARED each time it is turned on, it may be due to a depleted backup battery. The battery model number is CR1616 or CR1620. On my TI84PLUS the backup battery is of type 303 (Sony) or SR44SW (Maxell).
Sep 05, 2010 | Texas Instruments TI-83 Plus Calculator
Cant find batteries I live in Georgia
Depending on the battery holder, you can use AA, AAA, lithium.
If you have lithium battery holder, buy AAA battery holder or AA battery holder from eBay.
May 05, 2010 | Minolta Maxxum 7000 35mm SLR Camera
Mv500 camera batteries run down fast
you need some new acumulators or alkaline batteries
Oct 27, 2009 | Microtek Take-it MV500 Digital Camera
Worthless batteries won't last DGW-100
Try rechargeable batteries if your are using AAA. Some cameras just stop working with the AA one-use batteries. If you have a lithium or other specialty battery, try getting another battery. Your battery may need to be replaced.
Jun 20, 2009 | Moultrie MFH-DGS-100 Digital Camera
Won't turn on
How "fresh" are the batteries. Quite often they are weak, right out of the package. We revive a lot of "dead" cameras with Energizer Lithium AA batteries. Many cameras that people are ready to write-off, are resurrected with the Energizer Lithiums. I also think that battery manufacturers are not putting as much "juice" in them as they used to.
May 19, 2009 | Kodak EasyShare C433 Digital Camera
Blinking film on screen.
Sounds like the batteries went dead, and the internal lithium memory battery was already dead, causing it to forget the settings. install fresh batteries, and reset the ISO of youtr film by holding down the ISO button, and pressing the up/down buttons behind the shutter release. That should return it to normal, but you will have the same problem again whenever you are changing the batteries until you replace the lithium cell. To change the lithium cell, remove tha battery pack, and open the metal plate in the camera's battery compartment. The cell is a lithium CR 2016.
If that does not fix it, you may have a broken camera.
-John
Sep 03, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Maxxum 7000 camera lithium battery
The lithium button cell is under the metal plate where the battery holder attaches. There are six screws holding the plate to the camera. I believe the cell is a CR-2025.
That being said, replacing the lithium battery will only restore the cameras ability to remember your settings and frame counter when the regular batteries are not on the camera. It will not restore functions of the camera.
If the camera is not functioning properly, you have a power problem with the main batteries, not the memory backup cell
Mar 21, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
89 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
