Question about Krups FME2 Coffee Maker
Krups FME2 will not flow water.
The coffee maker will power on but will not flow water. The duo filter was removed and still no water flow. Several attempts were made after changing water, rinsing filter and removing filter with no success.
  • sonnyp53 Jul 03, 2008
    Very helpful, thanks.
  • irvvet Aug 25, 2008
    What is the procedure for "unsticking" the one-way valve? We have the water hot but will not come thru to make the coffee.
    Thanks
    Genius:
  • 1,036 Answers
Does it sound like it is boiling water at all?
If it is boiling, but not giving hot water, then the one-way valve is stuck.
If it is not getting hot (on the soleplate base) then usually the element has blown.
These machines use the steam generated by boiling as a means to move the water up - like a geyser, and need the heat to move the water.
Replacement elements are available, and the valves usually just require cleaning.
Posted on Jun 29, 2008
Krups FME2 coffee maker won't brew. Flashes an error ---
Most coffee brewers has what is call "resistance" . This resistance get hot to boil the water then brew the coffee and in most cases the resistance get burn and dont brew.
Apr 06, 2015 | Krups Coffee Makers & Espresso Machines
How do i clean my stainless steel krups coffee maker before use model kt 611d50
Just run one full pot of cold water through it. Do not add coffee. Then it is ready for use. Caution - Do not make coffee right away because you can break the glass carafe by adding cold water to a hot carafe. Also the hot plate would be very hot too.
May 30, 2014 | Krups FME2 Coffee Maker
I have a Krups FME2 coffee machine and when I fill it up with water, the screen shows that the water reservoir is empty? What the heck?
If there is a water level float in the tank it may be no longer floating, if you can shove a piece of plastic under it to lift it up that should trigger it to think it now has water.
Apr 09, 2013 | Krups FME2 Coffee Maker
Krups FME2 Coffee Maker will not turn on
Please go to nearest service store.
Jan 22, 2012 | Krups FME2 Coffee Maker
Hello, My Krups coffee maker keeps flashing the no water signal, even though there is water in it. Consequently it will not turn on. What should I do?
It sounds like the water sensor has gone out, that is probably causing a short that is preventing the pot from tuning on. If the sensor is not bad then it is probably a short in the circuit board itself. You will need to contact krups to have it replaced under warranty. If it's not under warranty then check with a small appliance shop for an estimate, however in most cases it is just cheaper to scrap it and buy a new coffee pot.
Feb 14, 2010 | Krups FME2 Coffee Maker
Where to put water? in glass jug or in the back
For filter coffee makers , there is a lid , lift this you will see the filter at the back of this there is a hole,fill this with the water.
But your coffee on the filter,close the lid, put the jug on the base turn on.
Oct 24, 2009 | Krups FME2 Coffee Maker
How can I set the automatic timer on the Krups FME2 Coffemaker
Problem solved...
Found the manual for my coffemaker online
Dec 15, 2008 | Krups FME2 Coffee Maker
Krups FME2 Error Message
if you still have the receipt, you can get it repair or replace under the warranty, unless the warranty is for 90 days. in that case you are toast.
time for a new one.
replacing the parts is half the price of a new one.
Oct 20, 2008 | Krups FME2 Coffee Maker
FME2 Coffee Maker
From page 9 of the manual:
Setting and Adjusting the Clock
• The machine must be “off“.
• Press and hold the prog button (o) for 3 seconds: the hours will blink “88 _ _“.
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button : the minutes will blink“ XX 88“.
• Adjust the minutes in steps by pressing the h/min button.
• Confirm the setting by pressing the prog button.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={FA4AA2D9-9799-4F8F-8136-8FEB029407FD}&SelectedProdRef=FME2
Aug 28, 2008 | Krups FME2 Coffee Maker
Krups FME2 Coffee Maker Logo
773 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
