Question about MyMusix PD-6030 MP3 Player
I can not turn on the device - MyMusix PD-6030 MP3 Player
  • kim33 Jul 19, 2008
    my mp3 was left in someones handbag for 2 months and when I got it back and hook it up it never came on. Do I need to buy a new MP3 player.
Because you dont want to open his
Posted on Aug 12, 2008
Eco power turn off
That is because it is a clock radio with a sleep function.
Apr 01, 2017 | Philips Audio Players & Recorders
Tip
RCA Universal Remote Code Search Models RCR312W - RCR311BN - RCR311BIN RCR311SN...
RCR311SN - RCR311STN
To setup your RCA Universal Remote Control with your TV or other devices, you can perform a code search. A code search tries to turn your set off with different brands' remote control codes until it finds one that works with your set.
Here are the steps for an RCA Universal Remote Control Code Search:
  1. Turn on the device you would like to control.
  2. Press and hold the device key (TV for example).
  3. While holding the TV key, use your other hand to press and hold the ON/OFF key.
  4. Wait until the ON/OFF key light comes on and stays on, then release both keys.
  5. Point the remote at the front of the TV and press PLAY.
  6. Wait 6 seconds while the remote sends a batch of 10 codes to your TV. If your device turned off, go ahead to the next step. If the device did not turn off, press play again and wait 6 seconds again.
  7. When your device turns off, press the REVERSE key on the remote and wait 2 seconds. If the device turns back on, press STOP and your remote is now successfully programmed for controlling that device. If the device does not turn back on, keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
I hope that helps.
on Apr 07, 2010 | RCA Universal Remote Control
Tip
I hope that helps.
on Apr 06, 2010 | RCA RCR311B Remote Control
49 FF81 error on HP Laserjet 3035xs MFP
49.XXXXX ERROR To continue turn off
then on
A critical firmware error has occurred.1. Turn the device off, and then turn the
device on.
2. Go to www.hp.com/support/
LJM3027mfp or www.hp.com/support/
LJM3035mfp to check the latest
firmware image version. If the latest
firmware image version is newer than
the one installed on the device, upgrade
the device.
3. Try printing a job from a different
software program. If the job prints, go
back to the first program and try printing
a different file. If the message appears
only with a certain software program or
print job, then the error is in the software
program and not in the device. If the job
fails to print using a different software
program, then turn off the device and
disconnect all cables that connect the
device to the network or to a computer.
4. Remove any DIMMs and EIO cards, and
then turn the device on.
5. If, after removing DIMMs and EIO cards,
the device behaves normally, turn off
the device and reinstall DIMMs and EIO
cards one-by-one, turning off the device
off and then on again each time you
reinstall a DIMM or EIO card. If a certain
DIMM or EIO card causes the message
to reappear, replace the DIMM or EIO
card.
6. Reconnect all cables that connect the
7. If the message persists, replace the
formatter (see Formatter on page 116).
Apr 03, 2012 | HP LaserJet M3035xs MFP All-In-One Printer
How do u program. With and withoit codes
Manually:
To enter the code into the remote, turn on the device you want to add. Point the remote control at the device and hold the "Code Search" button until the LED light is solid red. Press the button for the device you want to set, such as "TV" or "DVD." The light will blink once and then stay solid red. Use the number buttons on the remote to enter the first code associated with your device. Once the code is inserted, the LED light will turn off. Point the remote at the device and press the "On/Off" button. If the device turns off, the code is correct. If the device does not turn off, repeat the preceding steps using the next code on the list.
No Code:
To use the code search, turn on the device you want to set. Point the remote at the device and hold the "Code Search" button until the LED is solid red. Press the corresponding button for the device you wish to set, such as "TV" or "DVD." With the remote pointed at the device, repeatedly press the "On/Off" button. Continue to do this until the device powers off. When it shuts off, press the "Enter" button to set the remote control. Use the "On/Off" button and see if the device turns on again. If it does, the setting is complete. If it does not, attempt the code search again and be sure to press the "Enter" button quickly when the device turns off.
Feb 28, 2011 | Innovage Jumbo Remote Control
I just need a pin number so i can pair my headset to my iphone
Step 1: Set the headset to be discoverable
Turn off the headset.
Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000. let me know does thsi help regards golu_fixya
On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000. user_offline.gif
Aug 29, 2010 | Cell Phones
My hp color laserjet 2840 keep gave me error 79 ask to turn off then turn on I did it several time but it don't fix the problem. Please help me fix this problem.
79 Error
Turn off then on
The device has experienced an internal
firmware error.
Turn off the power by using the power
switch, wait at least 30 seconds, and then
turn on the power and wait for the device to
initialize.
If you have recently installed a memory
DIMM in the device, turn off the device,
remove the memory DIMM, reinstall the
DIMM to verify that it is seated properly,
and then turn on the device.
If a surge protector is being used, remove
it. Plug the device directly into the wall
socket. Use the power switch to turn the
device on.
If the error persists, upgrade the firmware.
See Updating or recovering the firmware
code.
If the error persists, replace the formatter.
See Removing the formatter assemblies
Apr 27, 2010 | HP LaserJet 2840 Printer
I need a manual with the progamming codes for a Sanyo tv
I don't have a code book for you, but I can tell you how to program the RCR660 using the automatic programming feature.
Programming RCA model RCR660 (no code search button)
While following these instructions, keep the following in mind:
device = the component you wish to control with your remote (TV, DVD, VCR, etc.)
DEVICE = the button labeled for the component you wish to program
1. Turn on the device you wish to program.
2. Turn off all other devices in the general vicinity.
2. Press and hold DEVICE
3. While holding DEVICE down, press ON/OFF and hold them both down until the LED turns on for that device.
4. Release both buttons.
5. Point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing.
6. If the device does not turn off, then continue to press PLAY and wait the required interval (for a maximum of 20 times) until the device turns off.
7. When the device turns off, press REVERSE, wait two seconds and continue doing this until the device turns back on.
8. To finish programming, press and hold STOP until the LED turns off.
Dec 22, 2007 | RCA RCR660 Remote Control
CODE SEARCH????
Nov 13, 2007 | RCA RCR660 Remote Control
Need code for Emerson TV,DVD,VCR Combo
Nov 10, 2007 | RCA RCR660 Remote Control
MyMusix PD-6030 MP3 Player Logo
76 people viewed this question
Top MyMusix Audio Players & Recorders Experts
Greg Cann
Greg Cann
michael galang
Sandeep Shenoy
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
