Question about Hitachi 53UDX10B 53" Rear Projection Television
Chirping, flashing power LED
Hi, My 53UWX10B has the same problem, Is the solution the same as the
UDX?
Thanks, butchilee
Ok, first let excuse me for the first solution that I make in the 53UDX10B 53 in. I was thinking was a DLP Television but it was a Projection Television.
The Projection Televisions has others problems, so maybe it is that a Technician must has to solder (weld or give weld points) in some boards (PCBs) inside the TV, (the Main PCB and/or the Sound PCB) and/or perhaps has to change a capacitor (C 33uf 16v) that maybe it is exploded. Because that happen with those old Projection TVs.
It is the same with the 53UWX10B.
For all inquiries please call: 1-800-HITACHI and tell then the problem.
They maybe give you a better solution.
Posted on Jul 01, 2008
Viper 5501 control center won't enter pairing mode
If you didn't already get it all set you can disconnect power from unit for a little while (10 or minutes) and reconnect, you then should be able to program your remotes regardless if it was locked or not.
Feb 19, 2014 | 5501 LC3 SST LCD 2 Way Car Remote Starter...
Alarm went off but no smoke was found and no other smells were detected. I do not believe that there was CO present. All the units were activated. after a period of time they stopped. This occurred 3 times...
http://www.kidde.com/Documents/User-Guide-900-0102-A-ENG.pdf Remember that smoke take presidence over C/O detection so notice whats going off first . LED Indicator Operation
Red LED
The red LED will flash as described below under the following
conditions:
--During smoke or CO alarm, with every beep
--During testing (same as alarm)
--Low battery, single flash with chirp
--End of product life, double flash every 30 seconds with chirp
--Unit error mode, single flash with chirp
--Unit error mode, a Fault Code is flashed every 30 seconds (can
be observed and reported to customer service for
troubleshooting. Above is the user guide.
Sep 09, 2013 | Kidde 9000102 Night Hawk Combination...
No picture or sound with a red flashing power light. Have replaced the convergence IC's but no change (do not have the chirpint sound). Removed main power board & green LED does not light up
On that model the conv IC is usually not the solution. I believe its the blown capacitor problem with is an easy fix. Check the site www.TvRepairKits.com for a repair kit.
Apr 11, 2012 | Hitachi 53UWX10B 53" Rear Projection...
TV makes chirping noise.
Power Lite LED indicator on the front panel bazel flashes?Ur power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv will not come on
check the power supply , or check the bulb it may need replacement
Mar 15, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
53UWX10B
Good Day, Butchilee,
Sounds like you have patience, hope your TV has some trace left. Hit recommends that you replace the originals with
STK-392-150's and the resistors. Replace said items with care then back down on the screen/ focus controls and gradually bring the screens up until you have pic, adjust focus. Go into customer menu and adjust color down, set brightness to 50%, contrast to 100%. Then go back and adjust the screens for proper, black/white, tracking. AND It's best to double check the soldering connections.
Good Luck, Big Irish.
Jul 04, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Progress
I would check the red CRT PC Board for a bad connection on the socket. The focus wire plugs into that socket. And a corroded socket, cracked solder or a faulty focus lead connection can cause that symptom.
Jun 13, 2008 | Hitachi 53UWX10B 53" Rear Projection...
No raster, no sound on 53UWX10B
double check the wire connections, as the filaments not being lit makes me thing a wire isnt connected properly, or one may have been loosend while doing the convergence repairs.
Jun 12, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Zenith iqc50h95 50 in rear proj
Rainman, can`t really be of any great help on this one, both techs can be right, the chirp is exactly as you thought, the set is trying to come on but there is a short in the set and it`s shutting down because of the short, could be convergence, low voltage power supply, high voltage power supply, until a tech gets in there and starts un-loading circuits it`s impossible to say where the short is, gonna have to call someone out for this one, good luck with it, BMW Rider
Jan 09, 2008 | Zenith IQC50H95W 50" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
67 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
