Question about Phase Linear UDV9010 Car DVD Player
Playing a DVD on Phase Linear UV7
I have the parking break wire connected properly, however you must put the parking break on and off in a sequence that I do not know. It is not discribed in the manual. I did it once by randomly putting the break on and off, but I forgot what I did.
  • 1 more comment
  • Korby Jul 01, 2008
    No there is a sequence. I found what it is and posted it here. The player even asks for a sequence. The older players did not have a sequence, however, people would bypass that by grounding the wire. Now to bypass it you would have to put a switch in to toggle the sequence.
  • Ryllz Jul 20, 2008
    Hey,
    I believe i have the same problem except the solution posted doesnt seem to work, the symptoms of my problem is that as soon as i pop a dvd into the player the blue screen comes up and says i have to engage the break sequence to access the movie and ive tried the sequence from my manual and from the solution posted but have had no luck.
    Reilly
  • Anonymous Jul 21, 2008
    What kind of switch does it have to be to bypass the break?????
You have to insert a DVD then put the parking brake on for 1~2 seconds, then put the brake off for 1~2 seconds, then back on. If you take longer than 2 seconds or less than 1 second then you have to wait 10 seconds to try again.
Posted on Jul 01, 2008
    President:
  • 624 Answers
It must start out in the off position and then when you want to watch the video put it on. There should not be any more to it than that. You may have an intermittant connection on the parking brake wire that makes you think there is some type of sequence because the first time you set the parking brake it did not work. I would check and make sure the parking brake is always engaging the wire to ground when the parking brake is pressed.
  • Dave DeGain
    Dave DeGain Jul 01, 2008
    Thanks for that info Korby, I have been repairing car and home audio for nearly 18 years, but not Phase Linear. I assumed it would be the same as the Pioneers, Kenwoods, JVC, and Panasonics that I repair at an authorized service center for all of those.
    It goes to show, you can always keep learning and nobody is above making a mistake. I really appreciate that you did not give me a bad rating for giving you the wrong advise. Your a stand up guy, thanks.
    If you ever need some help or information on something I actually work on, I would be mor ethan happy to assit you.
    Have a great fourth,
    Dave
Movie wont play
The Stereo is looking for a ground signal on the parking brake wire. It's a safety feature so that you are not watching movies while driving. To bypass this you will need to connect the stereo's parking brake to ground.
Sep 03, 2012 | Phase Linear UPA424CS Car Audio Amplifier
I have the phase linear UV7i I was trying to put in the overide
reset it,try with out the remote and change the remote battery,put in dvd wait for the blue screen,then press stop 2x then enter 1264 then,if you have a up,down,l/r control on the deck press down 1x then press play,you dont even have to use the ground wire then go to the rest, when you can see the menu,i dont know if it will work but u can give it a try
Jun 18, 2009 | Phase Linear UDV9010 Car DVD Player
Want dvd to play while driving its played before i hit reset button now it does'nt play
You need to hook up the pink wire to a power wire. I myself have a switch in my cig outlet (which ran blue lights i had inside my car) running it so if i ever got pulled over i just pull out the switch and they cant prove i was playing a movie.
Oct 19, 2008 | Phase Linear UDV9010 Car DVD Player
Phase linear uv8 parking brake problem
for the uv8 to bypass the parking brake to watch dvds you have to take the pink wire and put one end to one of the screws on a two screw toggle switch connect the other end of the pink wire to the other screw and connect that to the black ground wire
Mar 12, 2008 | Phase Linear UDV9010 Car DVD Player
Parking brake connection
You need to ground your packing brake wire(light green). May be bench test first before intall. Goodluck.
Feb 27, 2008 | Phase Linear UDV9010 Car DVD Player
Phase linear uv7
Theres a wiring harness on ebay for it.
Jan 11, 2008 | Phase Linear UDV9010 Car DVD Player
HELPPPPPPPPPPPPPPPPPPP!!!
Ground your parking brake wire(light green). Goodluck.
Dec 29, 2007 | Phase Linear UDV9010 Car DVD Player
Linear uv7
here's the code. I did this with my remote and it works.
press stop twice(which is also the band button)
press1,2,6,4
press down 1 time(button below the play/enter)
press play/enter 1 time
(you should see the menu now)
brake override should say no
I was told to change macrovision to no
hit system setup twice to save and exit
hope it works like mine did
Dec 07, 2007 | Phase Linear 160W AM/FM/CD Receiver W/...
Phase linear UV7i makeing the dvd player without useing parking
There is a pink wire that goes to the parking brake. It connects to the ground wire on the parking brake that makes the brake light come on the instrument panel.
connect the pink wire on your stereo to a frame ground.
Oct 28, 2007 | Car Audio & Video
Linear uv7
Is the parking break wire connected to the parking break switch?
Sep 22, 2007 | Phase Linear UDV9010 Car DVD Player
Phase Linear UDV9010 Car DVD Player Logo
353 people viewed this question
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
