Question about JVC GR-D20EK Camcorder
No picture the message appears as "remove lense cap" even when its removed and there is no picture whatsoever on the monitor, what should i do. thank you
  • Anonymous Jul 08, 2008
    have same problem with jvc...i dont understand this
  • 34 Answers
The ccd base assy. needs replacing.
Posted on Sep 05, 2008
I need to remove the base of my Acer AL2216W monitor to send it out for repair, but I don't see how to remove it. Does the stand unsnap from the bottom ledge of the monitor, or does the "tongue"...
You need to remove the hinge plastic cover to get to the mountung screws.
Download the service manual here:
http://elektrotanya.com/?q=showresult&megnev=Acer%20&megnev2=%20AL2216W%20&kategoria=monitor&kat2=all
Look at Chapter 3 page 19.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 10, 2010 | Acer AL2216W LCD Monitor
Vivitar 6330s taking pictures with blue line around subject
The lens cap may be loose. Slightly loosen the cap, maybe even remove it SLOWLY.. over a table with a towel on top. Clean the lenses with a camera cleaning kit and reinstall the cap. Use the booklet that came with the camera. I have 3 cameras, as far back as the 1st Digital JVC 1.5 mp from '96 and I have ALL manuals and warranty papers for it. Hope you do, too. Be careful, take your time and do not Over tighten the lens cap. The circular Hold-Down cover over the outer lens.
Jan 04, 2010 | Vivitar ViviCam 6330s Digital Camera
Nikon D60 newbie : colour distortion / large smudge in photos
D-SLR cameras are designed to be used with interchangeable lenses and foreign matter may enter the camera when lenses are changed. Once inside the camera, this foreign matter may adhere to the sensor, where it may appear in photographs taken under certain conditions. To prevent foreign matter from entering the camera
  • do not change lenses in dusty environments
  • point the camera down when changing lenses.
To protect the camera when no lens is in place be sure to thread on the body cap provided with the camera, being careful to first remove all dust and other foreign matter that may be adhering to the body cap.
Remove foreign matter from low-pass filter
  1. Clean the low-pass filter covering the sensor as instructed in the camera manual or continue reading below.
  2. Have the low-pass filter cleaned by authorized Nikon Authorized Service Center
  3. The Nikon D300 and D60 has the ability to clean the sensor* using the "Clean Image Sensor" feature. Please see page 371 in your D300 User's Manual, and page160 in your D60 User's Manual for more information. *Clean Image Sensor may not remove all sensor contamination and additional manual cleaning may be necessary. See page 374 in the D300 manual, and page 162 in the D60 manual for more information.
  4. Fix images with black spots
    Photographs with dust or foreign matter on the low-pass filter can be retouched using the 'Image Dust Off' function available in Nikon Capture 4 or later (available separately) if the image was taken in the NEF format, for more information visit the article on 'How does Image Dust off' work.
Mar 24, 2009 | Nikon D60 Digital Camera
LENSE CAP WARNING STAYS ON EVEN WHEN IT IS REMOVED?
Mine went back to JVC because it was a design problem. They fixed it for free.
Sep 20, 2008 | JVC Everio GZ-MG130 Camcorder
I have error 99 in my camera canon 400d
Ifd the camera is only 3 months old - return it for replacement
Sep 01, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Hp photosmart r725 6.2 megapixels.
If you're getting the 18-4489-957-000 error code, then give it a good tap on the corner where the lens cap is. A little tapping and the lens cover should pop closed. When you turn the camera on again it will probably work just fine.
I was just about to junk my camera when I googled the error code and found this very tip in another thread. It worked like a charm.
May 29, 2008 | HP Photosmart R725 Digital Camera
Panasonic DMC-FZ7 digital camera.
I believe the FZ7 determines that the lense cap is still on when it can't extend the zoom lense because the lense cap is in the way. I would check to see if your zoom lense housing is somehow stuck (could be sand or dirt in it) which is creating enough resistance to make the camera think the lense cap is impeding the zoom lense from extending.
Jan 03, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Jul 31, 2007 | Canon Digital Rebel / EOS-300D Digital...
JVC GR-D20EK Camcorder Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
