Question about Philips Televison & Video
Philips TV Model 44PL9522/17. When I fist turn on the TV, the color red turns green and then after an hour or two, it becomes normal. Now the TV will turn itself off after 10 minutes. When I turn it back on, it will turn itself off repeatedly until the orange light blinks and then it won't turn off.
    Brigadier General:
  • 3,614 Answers
There was a problem on your convergence module, if you were able to repair and check please check that area. if you have no idea to fixing the tv, you need to call for service on that.
Posted on Jun 29, 2008
  • 1,879 Answers
Greetings,
Power supply cannot sustain energy to the whole system.
If you know electronics, check the power supply section.
Else, have it serviced by a qualified technician.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Picture red can not fix
Step 1:
The problem you have is the grayscale tracking needs to be reset.
First, This looks like a philips tv. In order to set the grayscale tracking remove the back of the set. There should be rectangular shaped box that is marked screen and focus on it with 6 knobs coming out of it.
Step 2:
NOTE: DO NOT TOUCH ANYTHING INSIDE THE SET-YOU WITH BE SHOCKED! WITH THE TV TURNED ON, WITH THE REMOTE, TURN DOWN THE COLOR TO ZERO. ON THE CONTROLS I PREVIOUSLY MMENTIONED, THERE ARE RED,GREEN AND BLUE ADJUSTMENT POTS.
Step 3:
TRY TURNING DOWN THE RED UNTIL YOU SEE A NORMAL GRAY PICTURE. YOU MAY HAVE TO ADD MORE GREEN OR BLUE AS NEEDED. IF THIS DOESNT LOOK RIGHT ,TURN ALL 3 R.G ANDB ALL THE WAY DOWN, THEN ADJUST THEM UNTIL THE COLOR IS JUST APPEARING ON THE SCREEN, MAKE THE PICTURE AS GRAY AS POSSIBLE. iF THIS DOESNT WORK,YOU WILL NEED A SERVICE PERSON TO REPAIR YOUR TV.
Jan 20, 2013 | Televison & Video
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
I have problems it seems when the TV is on for an hour or less the picture starts to flash and then change colors. A normal football field starts out green then it after flashing turns brown and all the...
capacitor parts replacements must be done at power circuit,because not performing properly...worn out due to age...a normal situation for appliances..
Dec 31, 2009 | Televison & Video
Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jun 15, 2009 | Philips 26PF9966 26 in. LCD Television
Try to adjust it in the Service Alignment Mode (SAM).
Jan 04, 2009 | Philips 26PF9966 26 in. LCD Television
Philips 50p8342 problem
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Aug 15, 2008 | Philips 60P8341 60" Rear Projection...
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Color sudden change
Good day.
Your unit is still worth. It may be a caused of loose contacts along the circuitry. It can be remedied by resoldering the terminals particularly the chroma section and the crt circuit.
chris
Mar 25, 2008 | Toshiba 36A61 36" TV
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
Televison & Video Logo
47 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
