Question about Motorola Mobility H700 Wireless Headset
H700 i keep losing established connection with my phone while i am using it it comes in and out its like its turning on and off
  • chr1smar1e Jun 30, 2008
    headset constantly says switching to handset and then back again. Tried to disconnect it then reconnect, now it won't pair. Anyone have a solution?
Yes, I know the exact problem....The boom mike is a little loose at the swivel. Once it gets loose it does exactly what you are describing. Once it becomes loose like that it's kind of annoying but still usable. You need to squeeze the headset at the pivot.
So you open the boom and squeeze the pivot right in the middle. (One finger right in the middle of the pivot and the other finger on the outside of the headset by the buttons) you will feel it move just a hair and everything starts working again.
After a while you have to do this squeeze every time you open the boom.Let me know how well this works
--john
Posted on Jul 02, 2008
Can pair my h700 w my bberry storm
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 16, 2009 | Motorola Mobility H700 Wireless Headset
Tip
Switch playing up
I have a H700 , I bought last year and hardly used. I tried to use it few days ago and it keeps loosing connection to my phone. I figured out that the headset switch is very flaky and slight touch makes it connect and disconnect the bluetooth connection to my phone. Any clue to fix it ??
on Jun 19, 2008 | Motorola Mobility H700 Wireless Headset
I have a blackberry storm and im trying to pair my bluetooth h700 with it. it found the headset but it keeps saying connection successful the 2 seconds later itll say connection terminated. all my...
Jan 18, 2009 | Motorola Mobility H700 Wireless Headset
H700 wont connect to lg rumor
after pair successful highlight the headset and hit connect
Jan 07, 2009 | Motorola Mobility H700 Wireless Headset
My LG Shine KE970 can not find Motorolla H700 bluetooth headset
Is the question really, is your H700 in pair mode? To set this you need to push and hold the big talk button while the boom is closed. once the purple light comes on open the boom to keep the light. Now you can search for it with your cell phone.
Hope this helps and don't forget to rate :)
Dec 10, 2008 | LG Shine KE970 Cellular Phone
H700 will pair, but won't connect.
To successfully pair the Motorola 700 with the Centro:
Select Bluetooth from the Home screen.
Select "On".
Under "Visibility", select "Visible".
Now click "Setup Devices".
Click "Hands-free Setup"
On the Motorola earpiece, with the flip-out mouthpiece in the closed position, press and hold the multi button until ring around it glows purple. Flip open the mouthpiece.
Now click "Next" on the Centro's screen.
The Centro should find the Motorola. Hold the Motorola to the right side of the phone if you have difficulty getting the Centro to find it.
Once found, click the Motorola H700 listed in the window and click "OK".
The Centro will ask for the device password. Enter 0000. Be sure that the checkbox for "Add to trusted device list" is checked. Click OK.
The two devices should now be paired to work together and the Motorola's multi button should rapidly blink blue; NOW click "Done".
You will be taken to the Trusted Devices screen.
You will see your Motorola in the list of Trusted Devices. Click on it to highlight it, if it is not already highlighted.
Click the menu drop-down key (located to the right of the ALT key).
You will now see a drop-down at the top of the screen that says "Connect". Click the "palm" center button on your Centro.
NOW the two devices are connected. The phone name will now be bold, and a small Bluetooth icon will appear to the right of it.
When you click the Phone key on your Centro, you will see a tiny blue headphone symbol now at the top right of the screen where the Bluetooth icon used to be.
To use the earpiece:
Flip it open and hang it on your ear.
Dial the number you want to call on the phone.
Press the multi button once and now you should be connected via the earpiece.
To receive a call, when your Centro rings, press the multi button once.
It took me a few hours to figure it out. Hopefully you can do it in a few seconds.
Dec 28, 2007 | Motorola Mobility H700 Wireless Headset
Connection problem
noavatar_s.png By nonexpert_s.gif Guest
Rank: Not rated
Rating: 0%, 0 votes
First, turn on your bluetooth on your phone.
Flip the boom mic on your H700 and hold down the call button for 5 seconds.
The indicator light should be purple. That means it is in pairing mode.
Then using your phone, attempt to connect to your H700.
It'll ask for a passkey. The default passkey is 0000.
Nov 08, 2007 | Motorola Mobility H700 Wireless Headset
How to do pairing
Thank you. I called a 1-800 number for tech support but they told me I had to wait 14 days from the date of purchase before they could help me. Your suggestion was right on the money. Thank you.
Jul 18, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 Problems with BB Pearl 8100
Steps to pair a H700 headset with any bleutooth pone:
  1. Make sure the H700 fully chared (very important)!!
  2. Make sure the microphone boom is folded closed, i.e. power is off!
  3. Hold the call button for 1-5 seconds until the light is steady lit purple
  4. Flip out the microphone boom, the light should stay lit purple!
Now you are ready to pair the headset with your phone, so follow the pairing instructions of your phone.
Note: When prompted for the Passkey; it is most likely 0000 but the correct Passkey should be on the headset accessory instructions.
I must add that indeed my headset on occation (once or twice every three months) also loses its connection with the blackberry (a 8703e) . At which time I have to remove the headset from my phone bluetooth device list, and start the above described steps to pair my headset with the phone again.
Jun 02, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
79 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
