Question about Toshiba Satellite 1115-S103 Notebook
Error message: PXE-E61: MEDIA TEST FAILURE, CHECK CABLE
I installed a new internal hard drive on my computer and now when I turn it on I recieve this error message. I have a Toshiba Satellite 1115-s103. I purchased a new Hitatchi Travelstar 2.5 hard drive. Is it possible this hard drive is incompatible with my laptop? I have tried every solution I could possilbly find on the internet such as disabling the netwook boot which is pretty much the only solution I could find short of getting a new hard drive (which I just did). Any other possible solutions someone could suggest would be greatly appreciated!!
  • Linz84 Jun 29, 2008
    The old drive gave me the blue "screen of death"
    They had the same amount of pins in the same places
    I reinsterted the hard drive cable multiple times to make sure it is well secured and properly put in.
    I no longer have my user manual since i've had this computer for about 6 years now. I'm sure I can download one somewhere but the Toshiba website is completely useless for anything.
  • 3 Answers
In case you haven't given up or solved the problem, you probably need to boot from some other device (e.g. the Windows XP or other recovery CD) and define an active primary parititon on the new hard drive, format it, and reinstall the operating system before it will be usable. .
Posted on Dec 15, 2008
    Scholar:
  • 176 Answers
- did the old drive mallfunctioned, or u just wanted to put a larger one ?
- i presume that both drives have the same standard (pata most probably (lots of pins at the connection part...))
- have u checked the cable connection, and cables (some may get loose when removing hardware ...)
-also check the BIOS for hidden settings (see u;re manual). There may be settings on the mode that the drive should work..
Posted on Jun 29, 2008
  • Cisf Jun 29, 2008
    try disconnecting the cd-rom drive, maybe the error is from it and not from the harddrive;
    can u test the new drive on another laptop, to make sure it;s ok ?
    when u say "the blue screen of death" do u refer to the windows error or other error ? Because if it's windows ... is very unlikely that the hard drive I/O caused it ... (unless it;s badly damaged, and partially working ...)
    also recheck all pins on the drive (some get very easily bent ... ), and if u can, check the continuity of the cable from the drive up to the motherboard (if it;s easily accessible and u have a measuring device ... )
Computer wont boot error code pxe e61
You must initialize the new hard drive first.
Jan 28, 2014 | Toshiba Computers & Internet
Pxe-e61: media test failure, check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 22, 2012 | HP Compaq Presario R4000 Notebook
Laptop won't start up
Aug 12, 2012 | Toshiba Computers & Internet
Toshiba satellite L455D-S5976 PXE-E61 media test failure...brand new hard drive What do I do???
You need to boot from an installation CD for the operating system, or the Toshiba restore set. New hard drives are completely blank when you purchase them. The computer is looking for something to boot from and cant find it, so it trys to boot from ethernet. Check your bios set up for boot order and boot devices. You might try disabling boot from network.
Hope this helps
May 04, 2012 | Toshiba Satellite L455D-S5976 Notebook
Pxe E61 Media Test Failure Check Cable
my server ph prolite doesn't start gives an error essage "PXE-E61: Media test failure, check cable" the reboots after 5 seconds
Apr 22, 2012 | HP ProLiant DL180 G5 Server
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
I have a nc6000 and the the message PXE-E61: Media test failure, check cable PXE-M0F: Exiting Intel PXE ROM. comes up I can not boot my computer it states a disk read error occured can you help me. I have...
The PXE-E61 is the error code for No Network Bootable Device Found. Which means the computer cannot find your hard drive and is looking for a network drive to boot from. Either your internal hard drive has failed, or it is not seated or operating properly. Troubleshoot the hard drive, either it is dead or there is an interface problem between the drive and the motherboard or BIOS setting.
Oct 16, 2009 | Computers & Internet
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
PXE-E61: media test failure, check cable.
Save your self a lot of reading, do this first.
Check in BIOS rom for start up sequence and check if there is an asterist (!) in front of the hdd. If there is, it’s disabled. Select the hdd and press shift key plus “1′ This removes the ! and you can then use the hdd to re-format or….
Dec 15, 2007 | Toshiba Satellite A105-S4004 Notebook
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Toshiba Satellite 1115-S103 Notebook Logo
103 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
