Question about RCA P52950 52" Rear Projection Television
Wont power up
Had a power failure, since the tv will not power on. Good outlet, getting power, tv will not come on....any suggestions?
  • 2 more comments
  • pingman123 Jun 29, 2008
    no, no light. power button on tv and remote are unresponsive.
    no. no light anywhere. Power button on remote and tv are not working
    ok,, where would I find the fuse once I open the back? what does it look like?
  • yaya31520 Jan 18, 2009
    We turned off the tv before bed last night. this morning, it would not turn on. sounds like its going to turn on but doesnt stay on for a even 1 second. suggestions anyone?
  • RCA Master
  • 8,617 Answers
Does the led light up or blink when you press power? let me know but respond to this same post each time so I have access to the previous posted info, and I will try to help you out.
Posted on Jun 29, 2008
  • Sonny Berry
    Sonny Berry Jun 29, 2008
    Check the fuses and let me know, as they may have been burned due to a surge when the power went out. Unplug the set then check the fuse.
  • Sonny Berry
    they will be right next to where the power cord enters the circuit board, some models have two and others have only one. They will be small glass fuses Cylinders others are white clynders. Be sure to unplug the power cord before removing the fuse they just lift up out of the fuse holders.
Tv wont power up or come on
Ensure the power outlet is ok and if on doubt, check the TV on some other. If it does not work, the TV has some blown fuses or other board/component failures.
Aug 12, 2012 | Sansui HDLCD1908 19 in. LCD TV
Wont turn on stand by light just blinks
It seems TV microcomputer has blocked, you could try disconnecting TV from AC power outlet about 5 minutes, this should reset micro's memory, if doesn't there's possibly a hardware failure.
Feb 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My samsung tv wont turn back on
First make sure it is not the outlet. Plug it somewhere else that has a good outlet. Did you know that electronic device has the highest failure rate when it is brand new? This diminish dramatically then the failure rate goes up again as the device gets old. Mechanical things are diffrent because they have the high failure rate only when they are old because of wear and tear. Electronic device do not have moving part. Most of the early failure rate on electronic device are due to defective component or manufacturing errors.
Jun 26, 2010 | Televison & Video
Sharp TV LC37D40U Aquos malfunction. It fails to turn on (no picture, no sound) except that power button light blinks off and on continuously. Any ideas. Thanks.
The blinking light is a indicator of a internal failure, it usually blinks as an error code, I have two suggestions, unplug the TV from the power outlet and let it set for at least 30 minutes not plugged into the wall outlet, then plug it back in and see if it has returned to factory defaults and returned to normal operation, if that didn't work then contact sharp @ 1-800-237-4277 and they will gladly assist you. Good luck !
Nov 30, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
RCA 36695BC wont turn on
I'm afraid this failure is not just a fuse failure in your TV since you still can hear the relay clicking. This fix might not be a DIY.
Where can I send you additional info on what could be wrong with your TV?
Jul 24, 2008 | RCA F36695BC 36" TV
TV wont turn on due to power outage
I know it's been a while since you have sent this request, but if you havn't gotten any help or repaired the set by now, I'll try to help if I can. Your set has a seperate power supply board internally. The fuse could be burned out on that board. Also if you did in fact get a power surge, you may have a capacitor or a series of capacitors bad. Check the fuse first and if this is not the problem, I suggest you replace the power supply board as they are not real expensive. Good luck and I hope this has helped in some way
Ed Meshechek ( Radio Man )
NC Electronics
Mills, Wyoming
307-266-4675
Jun 01, 2008 | Olevia LT37HV 37 in. HD-Ready LCD...
RCA P52950 52" Rear Projection Television Logo
187 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
