Go to control panel then mouse properties and see if it needs to be reconfigured. Sometimes they just change on their own if you are using a mouse as well as the touch pad, remove the mouse (device), then reinstall the Synaptics touch pad software and try setting it up. You may have to turn on that function in touchpad control settings.You can reinstall the touchpad driver, be sure though that it's for your laptop's model.
SOURCE: HP Pavilion dv8000 - touch scroll pad won't work
at the top black rim around the touch pad, there is an orange light showing, press and have it show blue. It will work now.
Cheers.
Please rate this fixya.
SOURCE: touch pad
your touch pad might be disabled find the fn key + touchpad icon usually found between F1 to F10 the icon is like a square with pointer above it
SOURCE: my scroll feature on the touch pad on my alienware
I've seen this before and I think I know what might have happened.
Of course, I'm guessing, so bear with me.
during an update from Windows website, the touchpad drivers were updated. This was done, in all likelihood, without your knowledge.
Find the touchpad in the Device manager (I'm guessing you know your way around a computer) and look at the properties.
Then, roll back the driver and restart.
good luck.
tony
SOURCE: scroll bar on the right side of my touch pad scrolls too fast how do i slow it down
It depends, do you know if there is an icon down in the taskbar near the clock that has options for your mouse, if there is then you would double click that and there should be options in there.
SOURCE: touch pad scroll bar not working
You say it has been restored so I assume that Windows has been re-installed. If so then it is probably using the generic Windows touchpad driver and you need to update to the specific touchpad driver. Go to HP Website and download the touchpad drivers.
