Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Change light bulb
Lost the maintenance booklet. How do you get the cover off the light bulb compartment to change it out?
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
Ok just like you would change the belt take screws out of top the cover should come off inside there is a plastic cover take it off theres the bulb
Posted on Jul 01, 2008
  • Zappo Blappo Aug 17, 2013
    To remove the top cover, you'll need to remove several screws from underneath...AND remove a screw from the top that's hidden underneath the Hoover trademark label.
    To remove the top cover, unscrew several screws from the underside that are all in plain view. AND...remove the single screw that's hidden underneath the Hoover trademark. It will then easily come off. The bulb is simply pulled straight out by hand. Make sure that you hear a click when you insert the replacement bulb.
Kenmore vacuum cleaner model no. 116. 5861279 belt replace
Do you need the belt or the directions for changing the belt? Sears Parts Direct has the manual for the 116.58612790 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Vacuum-Parts/user-manuals/manual-downloads/Model-11658612790/0582/0640500?modelNumber=11658612790&diagramPageId=&documentId= . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0802691.pdf . See pages 14-15 of the manual.
To replace the belt, you need to remove the light cover and then the light bulb. Press in the sides of the cover and lift to remove it. the bulb needs to be pushed in and then turned couter-clockwise. Remove the cover screws. Then flip over the Power Mate and use the flat blade screwdriver to release both tabs. Turn the Power Mate back to right side up and press on the handle quick release pedal and lower the swivel. Tilt the cover forward until it snaps free. Carefully, use your screwdriver to pop the brush supports free on both sides to remove the brush. Slide off the old belt. (If needed, slide off the brush supports and washers. Clean the brush before reassembling the unit. Then replace the brush supports and washers.) Push the belt on motor drive and then onto the brush sprocket. Push the brush supports back into place on the base. (Make sure that this isn't assembled upside down.) Then line up the front of the cover with the base and tilt the cover back into place. Press firmly until you hear both sides click into place. Replace the cover screws, light bulb and bulb cover.
The belt is available here: http://www.searspartsdirect.com/Kenmore-Vacuum-Parts/742024/0020/116/Model-11658612790/0582/0640500.html . This is part number 5285; it's the direct replacement for the original 742024 belt.
I hope this helps.
Jun 16, 2016 | Kenmore Vacuums
How would I find a instruction booklet for a Mr. Coffee Model ECMP10? I bought it for my daughter she didn't want it but she lost the user instruction booklet.
Go to Mr.coffee.com and key in the model# of your coffee pot and request a instruction booklet. Hope this helps.
Bobby
Jun 29, 2011 | Vacuums
HOW DO CHANGE THE BULB IN MY ELECTROLUX 3000 UPRIGHT VACUUM?
Remove the 5 phillips head screws on the bottom of the base.
Insert a flathead screwdriver into the square holes and release the latches.
Turn vacuum front up.
Lift back of powerhead cover and carefully remove.
Look at light diffuser carefully and remember how it fits. Lift off the light diffuser.
Push bulb in, twist, and remove.
Insert new bulb, push in, twist to lock.
Place diffuser over bulb.
Place front of cover on with the lip in the grooves on the inside of the base.
Settle cover into place, making sure the latches snap into place.
Turn vacuum over and replace screws.
Mar 11, 2011 | Electrolux Epic 3500 Vacuum
My Hoover Soft and Light Supreme upright vacuum has a model #U4264-930. The last two numbers in serial # are 05. I have no manual and need to change a burned out light bulb. Need to know two things:...
http://www.vacshopusa.com/pdf/hu4253930.pdf Use this link to download a pdfd scehmatic for your model. This link is the site I got it from. http://www.vacshopusa.com/elite_%26_elite_ii.htm You may find more info there. Just from looking at the schematic, I would guess the bulb cover would pop off (carefully) and see what type of bulb it is. Remove it, take it with you to buy a replacement.
Nov 21, 2010 | Hoover Soft Light Supreme U4262-930 Bagged...
How do you empty the dust container?
Actually Fixya does have the owners manual for your particular model downloaded to their site. Please see page 5 of the instruction manual that will explain how you can empty the dust container. Also instructions on basic maintenance in terms of the filter replacement, and belt changing. This is a very useful booklet to have.
I hope that this helps you;
http://www.fixya.com/support/p12392-eureka_2971av_ez_kleen_bagless_upright/manual-3962
Chris Jones
GoVacuum
Mar 23, 2010 | Eureka 2971AV EZ Kleen Bagless Upright...
Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Mar 11, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
I have a Fantom Fury, and I cannot get the cover off of the motor assembly. Do you have any drawings or schematics that would help me accomplish this?
first need to open two light bulb covers with a screw drive and you will see two small screws. Remove the light bulbs and unscrew two small screws. After that, you can move the cover off.
Dec 11, 2008 | Fantom Vacums XT450K Upright Vacuum
I want to change the light bulb on my hoover elite 600 upright vaccum. How easy is it to do and where do I start? Thanks! Brian
It should be fairly easy.
You will need a flat-edged screwdriver to pry up the white/opaque plastic diffuser that covers the light - the bulb is in a socket underneath it.
Pry up an edge of the diffuser with the screwdriver and you should be able to see that it's held on with 4 tabs - two on the top and two on the bottom. Push the tabs in on either the top or bottom and the cover should pop out easily.
Jul 19, 2008 | Hoover Vacuums
I have lost the instruction booklet for my Bissell Flip-It hard floor cleaner. Where can I get this info on line? Thank you.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=747125
Generic problem for all Vacuums
Posted by kanerika on Jul 06, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can get the Bissell instruction booklet from the Bissell factory of which I will list below for you. Your local vacuum cleaner dealer may not have the instruction booklet for the Bissell Flip-It hard floor cleaner. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 06, 2008 | Vacuums
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
365 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
