Question about Olympia InfoGlobe Cordless Phone ol3020
Button doesn't work
#4 button is not working.
  • 1 more comment
  • Anonymous Sep 15, 2008
    our phone doesn't work either. The buttons don't depress and make contact as they once did. Makes "dialing" very irritating.
  • captlen Dec 04, 2008
    My #1, #4 and #7 buttons don't work. Can the phone be repaired?
  • Anonymous Feb 06, 2009
    I need a replacement handset. The rubber button cover over the # 6 key fell off on this OL3020 handset and the battery can not hold a charge. Where and how can I get a new replacement handset?
None of the buttons on my phone work can these phones be replaced?
Posted on Sep 21, 2008
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
1995 Ford Explorer 4 wheel drive trouble, front wheel drive doesn't work
Something you can do is to tap the 4/4 motor under drivers side on the back of transfer case with key on engine off. Have someone work the buttons as you gently tap the motor. Don't hit so hard as to dent it. Usually works.
Feb 22, 2013 | 1995 Ford Explorer 4.0
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
Why wont my iphone 4 turn on
Try connecting it to iTunes, and click on restore. If that doesn't work, try holding the power button and home button at the same time until the Apple logo shows up.
Jun 28, 2012 | Apple iPhone Smartphone
Speed up button doesn't work, everything else works good.
1) Check button: clean with special spray (for clean contact) in Radio Schack.
1a) Relais for motor test and clean it.
2) Take measure for a fuse
3)Test Speed Sensor in the motor and calibrate , and replace if necessary.
4) Check the drive motor, and repair( brushes, wiring)
Nov 03, 2011 | Exercise & Fitness
Neo Notebook model no. LC89-black screen only.
  1. All Operating Systems
    • 1 Remove any discs in the computer.
    • 2 Hold the power button down until the computer turns off.
    • 3 Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    • 4 Remove the battery and unplug the netbook. Wait 30 seconds.
    • 5 Reinstall the battery and plug in the netbook.
    • 6 Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    • 7 Insert the end of a paperclip into the reset button to reset the netbook. The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    • 1 Create a new Notepad file.
    • 2 Type this code:
      taskkill /F /IM dwm.exe
    • 3 Save the file as displayfix.bat in the following location: C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    • 4 Restart your computer.
Sep 20, 2011 | Computers & Internet
Cannot set the clock on my oven
It depends which model of timer, but try this.
Hold in the two leftmost buttons (of 4??) and turn the litte knob to the correct time then let go the buttons.
On some clocks you will have to press the far right and far left simultaneously 2-4 sec. to go int the set mode if this doesn't work try other combination of two buttons until the display blinks.
Hope it helps.
May 25, 2011 | Ovens
My mousepad is working but the cursor between left and right button doesn't work? I have a ACER Aspire 9300
1) Go to control panel (either with the help of keyboard or mouse)
2) Open Mouse
3) On Button Tab Select Button Configuration ( Switch Primary and Secondary Buttons)
4) Also Check your Touch Pad Driver Software
Thanking you
May 16, 2011 | Acer Aspire 9300 Notebook
4 Wheel drive does not engage on my 2002 Ford Explorer (6 cyl). Nothing happens when I push either the 4 High button or the 4 Low button. Any suggestions on what it could be? Worked fine last winter!
Could be the actuator motor on the transfer could be stuck or bad connection. Check to see if your gett power to the plug on the transfer case.
Feb 10, 2010 | 2002 Ford Explorer
If your iPod nano won’t turn on or respond
1) Make sure the Hold switch is off.
2) If that doesn’t work, connect iPod nano to your computer’s USB or FireWire port. Your
iPod nano battery might need to be recharged.
3) If that doesn’t work, your iPod nano might need to be reset.
a) Toggle the Hold switch on and off (set it to Hold, and then turn it off again).
b)Press and hold the Center and Menu buttons for at least 6 seconds, until the Apple logo appears.
4) If that doesn’t work, you might need to restore iPod nano software.
Mar 12, 2008 | Apple iPod nano
Olympia InfoGlobe Cordless Phone ol3020 Logo
63 people viewed this question
Top Olympia Lands Phones Experts
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
