Question about Coleman Mach III Air Conditioner
Coleman Mach III 13,500 btu ducted roof air conditioner
I took out the old unit and replaced it with the new one and wired it according to the wiring diagram-nothing happens. The unit acts as if there is no power. Can you advise?
  • Coleman Master
  • 6,674 Answers
Did you plug upper unit (on roof) into lower control unit (inside). Not to insult you, because i've done it myself, in a rush situation. Breaker on? Sure you didn't mix up any wiring?
Posted on Aug 16, 2008
Btu of coleman 7830-901
That should be a 30,000 Btu unit. Its been a while since I worked on them. The 78 is the series or model, the 30 is the capacity or btu's and the 901 indicates it is a Copeland compressor.
Jun 09, 2014 | Coleman Air Conditioner Shroud Rv Roof Top...
Won't turn on
There can be wiring issue. Try to check it by giving direct power to it and try to turn it on. You will know the issue.
BMW Performance Chips
Aug 12, 2012 | Coleman Mach III Air Conditioner
My roof top unit is letting the condensation run into the coach.
Either you need to replace the square gasket between the ac and the roof or you need to seal/replace your roof..
Aug 03, 2010 | Coleman Mach III Air Conditioner
We have a Coleman roof unit a/c on our RV. We are going to be replacing it and we're not sure what the btu's are. We are thinking 13,500. The model no. is 6759-707. Can anyone tell us what the btu's are...
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers
Jun 08, 2010 | Coleman Mach 15 Air Conditioner
Coleman roof top a/c, is the heat controlled by thermostat
on the new colman units (trane) the heat is control only from the t-stat.
i will reccomand a programble t-stat for the new unit.
Nov 02, 2009 | Coleman Mach III Air Conditioner
My coleman 13,500 roof a/c year 2000 does not blow as cold as used to. I have cleaned the top condenser coils, with no help. It also at times will seem to pull a heavy load when I assume the compressor...
if the compressor started and stoped means
1 thermostat need settings
2 compressor over heated due to low suction pressure need to check and repair the leak then charge the freon
Sep 14, 2009 | Coleman Mach III Air Conditioner
Did you purchase a new Ducted Ceiling Unit with the Upper Unit air conditioner? If you are replacing an older mach 3, the ducted ceiling packs are not compatible and you will need to purchase the ceiling pack as well. The ducted ceiling pack part number for the 8333 series Mach III AC is below.
1. Heat/Cool Air Distribution Box - 8330B735
2. Cool only ADB - 8330A733
3. Wall Thermostat (if needed) - 7330G3351
Hope this helps.
Jul 01, 2009 | Coleman Heating & Cooling
I have a 13,500 btu coleman on our 1989 avion camper. It was making a very loud noise for some time, and vibrating then the motor locked up on it. My husband thinks the blower went out on it. It was...
You should be able to turn the fan motor freely by hand. If there is any resistance or the noise turning it by hand, then the fan motor is definitely bad. Is it a wall thermostat unit or manual controls? Wall thermostat, you can use a jumper wire from the 12+ terminal of the thermostat to the HG terminal and the fan should come on, if not, then the motor is bad.
Jun 24, 2009 | Coleman Mach III Air Conditioner
Coleman Mach III Air Conditioner Logo
821 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
