Question about Numark Fusion 494 Complete DJ Package
Cofig ion icue to virtual dj 4.2
Not sure how to config my icue controller (mixer) to virtual dj, i use two sound cards 1 with laptop and 1 exturnal 1, talk to you soon Joe
  • jhbigdog11 Aug 23, 2008
    how to install ion icue with virtual dj 4.2
  • 515 Answers
It is a little difficult, and more complicated for me to explain here. Your best bet is to hit youtube, and do a search for ICUE Instructions. There are PLENTY of videos out there.
- OPTiC
DJ Equipment Repair Videos
DJ Equipment Repair
DJ Equipment Sales
Numark Parts
Posted on Jan 17, 2009
Cue LE/ virtual DJ and icue controller
hey, I don't know what happened last night, the chat window just disappeared from my screen.
Lets see if I can get you a replacement skin file.
Jun 29, 2008 | Numark Fusion 494 Complete DJ Package
Cant hear anything out of my speakers connected to djio
Are you using a Mixer as a pre-amp for this set-up? For example, I have a Numark CM200 where I have all of the inputs and outputs I need to run. DJ IO is connected to Chanel 1 and Chanel 2 Lines in my mixer. The DJ IO is conected to my computer by USB cable. In Traktor souncard settings chanel 1 is set to (3&4) Chanel 2 (2&1) also, devise set up is Numark DJ IO and in External mode. Of course the mixer is conected to my amp and speakers conected to the amp as well.
Apr 26, 2010 | Numark DJ/iO Sound Card
Trying to setup Traktor PRO with the DJ IO and Stealth Control as the mixer... cant get the other deck to play on my headphones, and also having trouble figuring out the OUTPUTS in the properties menu of...
the outputs in Traktor should be set up like this; Chanel 1 (3&4) Chanel 2 (2&1) this set up will give you a stereo sound coming out of Traktor using Numark DJ IO. Make sure the output is set up External and the Audio Devise is Numark DJ IO.
Mar 06, 2010 | Numark DJ/iO Sound Card
All of a sudden my Echo Indigo DJ soundcard will play both virtual CD players on my PCDJ software on one channel. For a while, I had cd 1 on one channel and cd2 on the other. I am using a pig tail plug...
I can run audio on 3 separate channels/outputs of my laptop
I use Tricerasoft Swift Elite DJ software but the areas you need to look at for troubleshooting are probably similar:
1) check the (PCDJ) software settings for selecting the channel outputs of your Indigo DJ on each deck/ player. NOTE: 1/2 and 5/6 are the same physical port (headphone port), while 3/4 and 7/8 are also shared on the Line Out port. So make sure you use for eg. one player uses 1/2, and the other player uses 3/4 ONLY IF you want them running out to separate channels on the mixer
I personally run both my decks off the same channel, ie 3/4 so that my software can do the mixing for me. My mixer only acts as an master control device where everything else connects
2) Make sure you check your IndigoDJ Console (installed to the Windows Start menu under Echo Audio, Indigo DJ), if you have any conflicts or if for some reason one particular channel pair gets inadvertently muted, resulting in no sound coming from the port.
3) I also use my onboad sound card (typically for previewing music or for an auxillary output). This is obviously controlled by the Operating system... in Windows is is through the Sound properties, default sound device. I recommend NOT using Indigo DJ as a default sound card -- but that is a personal preference.
So in this way you actually have 3 outputs for sound
As far as cabling is concerned, it depends on what you are connecting to. I use a 1/8 (mini computer) jack to 1/4 whcih then plugs into a direct box (eleminates any static hum etc), then from the DI box using an XLR cable to the mixer. Your setup may be slightly different.
Hope this helps!
Dec 01, 2008 | Echo Indigo DJ Sound Card
Maya 44 usb problem
you need to make sure that you are actually choosing maya on both cubase and virtual dj and config settings
Oct 30, 2008 | AudioTrak MAYA 44 USB External Sound...
Vestax pmc 06 mixer / Virtual DJ Mix station
you need a sound card with headphone out seperate from master out
Oct 19, 2008 | Vestax Pmc06proa Thin DJ Scratch Mixer...
Phones 1-2 has both channels coming out of it
Had the same problem and fixed it today. It is the mute button. Whem you change from 1-2 to 3-4 if the mute button for 1-2 does not activate you will get the sound from 1-2 thru 3-4. Just change the setting and you are away. worked for me.
bruce
Jun 03, 2008 | Echo Indigo DJ Sound Card
Numark Fusion 494 Complete DJ Package Logo
1,132 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
