Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet WFW8300SW01,door won't open
It flashing F01, I did everything what the manual instructions. I unplugged the washer and plugged back in. nothing happened. Can you please help me what to do? Thank you
Lisa
  • 1 more comment
  • matthew6 Jun 29, 2008
    i have a whirlpool duet WFW8300SW01 with a error code F 01 code. door also locked on me . machine will not work on any cycle. need help
  • Anonymous Feb 14, 2009
    Try by unplugging for 1 hour to reset system. Dan
  • wsenbeta May 11, 2010
    Whirlpool Washing Machine the door is locked how to unlocked?
SOURCE: Whirlpool Duet Washer - "Door Locked"
check wiring to switch.
Posted on Nov 01, 2008
fridgetech
  • 473 Answers
SOURCE: Code F1 @ Whirlpool Duet Sport Washer
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. Sears sells it for $119.46 http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WFW8300SW01&productCategoryId=0153200&brandId=1198&modelName=RESIDENTIAL-WASHER&diagramPageId=00003&componentDescription=CONTROL%20PANEL%20PARTS&documentId=W0607261&backToLink=Return%20to%20Sub%20Components%20list.
Posted on Dec 12, 2008
  • 61 Answers
SOURCE: whirlpool WFW8300SW03 F01 CODE
on the front control the display has a little lock emblem normaly between the options and spin speed buttons you press both buttons at the same time and hold for 3-5 seconds this will unlock the control if the problem reacoures on its on you will need to replace the display control board.
Posted on Jan 16, 2009
  • 240 Answers
SOURCE: My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Posted on Jul 19, 2009
  • 7 Answers
SOURCE: I have a whirlpool duet
check this site
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
error code page
Posted on Sep 14, 2009
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
WFW8400 WHIRLPOOL FRONT LOAD WASHER KEEPS FLASHING F01 ERROR CODE. HOW DO I CLEAR IT?
Un-plug the washer to reset the ccu. If still in error, open the top and check the connections of all the plugs going into the ccu. Post back on your findings.
Mar 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HOW TO FIX A F01 ERROR ON MY DUET HLT WIRLPOOL WASHER
hi my name is joyce
Did you try to unplug the unit for 60 secounds and replug it back up?
do this and see if this works. then reset the machine's cycle, you are in the middle of cycle I usually push pause cancel and wait till the door beeps and then I can open it. but if this does not open the machine do the unplug and reset method. if this does not work please let me know.
thanks,
joyce
Feb 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door locked & nothing happens Whirlpool duet wfw8300sw01
hi there,
sounds like the machine has no power at all.
there was no need to break the lock.
unplug the machine
take off the console
check connections from the touchpad to the CCU board
make sure nothing is corroded, burned, bent or pinched
unplug and replug the wiring harness
plug the machine back in and try it again.
let me know if this works.
Sep 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error Code F01
Hi there, After about year and half Whirlpool duet sport gave F01 error code. The technician manual is located under the lower front panel. There are three possible reasons for F0: 1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me). 2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer – it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force (watch “Armageddon” movie for more instructions on it). Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following. 3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU.
Aug 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I will need the model number off the unit on a regular Duet there is no F-01 codethere is a F10 some models (ie. Sears units) have diffrent codes so if you post the model number i can see where the problem lies also if you need to open the door there is an Emgcy. door release it is located behind the lower panel you will need to remove the 3 #10 torks screws the panel will come off reach up below the door latch assby you will see a tear drop plastic tab pull on it and it will release the door
Apr 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code F01 on my whirlpool front loader? any help is appreciated
Hi, After about year and half Whirlpool duet sport gave F01 error code. The technician manual is located under the lower front panel. There are three possible reasons for F0: 1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me). 2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer – it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force (watch “Armageddon” movie for more instructions on it). Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following. 3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU. thanks
Apr 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
921 people viewed this question
Dan Webster
Dan Webster
Sal De
