Question about Roper REX3614KW Electric Dryer
My roper electryc dryer will not heat - Roper REX3614KW Electric Dryer
  • 6 more comments
  • jaye1978 Jul 19, 2008
    My Roper is fairly new.We've only had it for less than 2 years. It turns and air comes out well, but there's no heat. I tried flipping the breaker a few times and running it, but there's still no heat.Please help!!
  • tshull1 Sep 05, 2008
    my electric dryer will not heat, where is the heat relay switch
  • darbydesiree Nov 27, 2008
    same issue WHERE is the heat relay switch??????????
  • Anonymous Dec 29, 2008
    My roper REL4634BN2 has exactly the same problem. I've taken the back panel off, now what should i look for???
  • bahamajoe Jan 14, 2009
    Where is the dryer relay switch and what does it look like?
  • emmyh84 Jan 24, 2009
    ya wher is the relay switch?
  • picazo Mar 07, 2009
    DRYER WILL NOT HEAT i DON'T THINK IT IS THE HEATING ELEMENT WHAT COULD IT BE
  • Anonymous Apr 07, 2009
    Roper RES7745RQD Electric Dryer
    My son filled it full of clothes and now it isn't heating.
Where is the dryer relay switch located? What does it look like?
Posted on Nov 28, 2008
    Problem Solver:
  • 14 Answers
I always like to check the heat relay switch. I had that problem with my dryer and that was the solution.
Posted on Sep 03, 2008
My Roper dryer, model RED4100sq0, will tumble but not dry. Also, the timer does not run so the dryer runs continously after starting. There is no heat from the element. Both of these problems started at...
I fixed a roper dryer with a no heat problem and I did a youtube video you can google Roper Dryer no heat if my movie does not show but I gonna post it for you.
Sep 30, 2013 | Roper Dryers
I have a roper dryer and there is no heat. I changed the heating element and I still have no heat.
thermal fuse, for test purposes only (DISCONNECT POWER) tape the two wire together run dryer it will heat, then order the correct fuses and replace them before operating dryer;
http://www.applianceaid.com/thermo.html
Feb 16, 2011 | Roper Dryers
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer gets hot and turns but the heat is
remove the front cover of the unit and make sure the dryer wheel is hooked and turning,while in there check for any pipe ductwork thats disconnected
Feb 27, 2010 | Roper RES7646KQ Electric Dryer
Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Jan 11, 2010 | Dryers
Roper gas dryer does not heat.
If the ignitor is not powering , go to the switch. That has to send power to the ignitor, then on to the gas valve.
Jul 22, 2009 | Roper RGX4634KQ Gas Dryer
Dryer won'y heat up
you either have a bad heating element or your limit switches are out..it could be either or both they are what control the heat
Jan 27, 2009 | Roper REX3614KW Electric Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
My roper electryc dryer will not heat I just inheirited a Roper dryer and it won't heat. I don't have a manual and know nothing about where to look for the breaker or heat switch. Can anyone help? Thanks!
I have a roper and I will bet its your heating element. Pry the top up with a screwdriver (pops up) and you will see the element on the back of the dryer. Take it out and it will have a break in it.
Oct 24, 2008 | Dryers
Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
Roper REX3614KW Electric Dryer Logo
336 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
