Question about Acer Aspire 3690 Notebook
Won't power up
Hi
my laptop tripped out the electic in my house and then it would not power up at all got a replacement power pack now when you switch it on it lights up for 3 seconds you hear the fan then it goes off took battery pack off won't do anything without it not even the 3 second power up can you tell me what the problem may be
Thanks
  • 40 Answers
More than likely when the laptop tripped the electric it was due to a short in your system. It sounds to me as if the system board in your laptop got fried. I have also seen where the power connector on the board itself has gone bad. Sometimes you can order a new one off of ebay or somewhere but you have to actually solder it onto the motherboard.
Posted on Apr 09, 2009
  • Chris77H Apr 10, 2009
    please rate if this has been helpful. thanks.
So far I've attempted to replace the motherboard for power. Bought exact same on eBay but got robbed. That one wouldn't even allow me to get power... So any ideas on which direction I might go?
what sort of power . do you mean electicity or processing power. I would look at the AC to DC adapter power pack if it is a laptop and electricity. The battery could need replacing on the laptop but if you aint getting electricity like DC voltage out of the AC to DC adapter the battery goes flat. . A voltmeter could measure the DC voltage coming out of the AC to DC power pack adapter unit to confirm if power adapter is at broken.
Apr 25, 2015 | Televison & Video
When using the oven the electicity tripped; after resetting the breaker the oven does not appear to get hot; however the grill works, the light works and the fan works what could be the problem?
Sounds like the oven element has gone. When these elements go they often short against the outside casing of the element which is earthed (or should be). This trips the main trip switch in the house. Having tripped and cooled down, the element is now broken inside & won't heat up. Usually 2 screws to remove, either inside oven or outside at back. Element usually taken out thro oven. Take it & cooker info to your dealer & ask for replacement. Shouldn't cost much.
Jun 13, 2011 | New World Ovens
Hi, in my home every electical applience works well. But when i switch on microwave oven the power to house will go off. MCB trips i think oven drawing more current/power. what might be the problem...
There is a dead short in side the microwave... this is causing the breaker to trip...however you should also replace the breaker to the microwave, as that should trip before the MCB...unless both are tripping at the same time...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 12, 2011 | Westinghouse WST3504 Microwave Oven
I have a ML44T automatic timer for my outdoor lights which has been working perfectly until now. When the time turns until it gets to the point where it has to trip the switch to turn the lights on it...
The clock motor has gone bad.
There are no replacement clock motors.
To work around, buy cheap plug-in timer, set power pack to override and plug power pack into cheap timer.
Power packs have 5 year limited warranty.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Mar 08, 2011 | Intermatic ML44T TRANSFRMR WITH TIMER 44...
When I pull the red lever on the electic mower, the lawnmower will not start and the GFI to my house is being popped?
just for a quick test -- run power to the mower using a different outlet,,, GFI outlets are well known for having a bad trip circuit in them,, they go bad all the time. so if your mower does in fact work on a different outlet with no problems then the issue is your GFI outlet and you will need to replace it.
if the mower is infact tripping the next circuit then the problem is with the mower motor windings or a short at the switch or two wires shorting out. check all wires and make sure connections are good.
c...
Jan 30, 2011 | Black & Decker Black Decker 18" Lawnhog...
Rheem electic water heater model 81v52s. Switch was tripped off. I turned the switch back on. Will the water heat now?
providing ther is no problem with water heater it should.
It it trips again check out thremostats on heater.
May 15, 2010 | Rheem 81VP6S/430126 Water Heater
Whirl pool elect dryer keeps tripping breaker
Ok, this is the result of a failed High limit thermostat. you should replace this failed device asap.
Check for continuity in the thermal fuse as well. replace if no continuity is found.
May 31, 2009 | Whirlpool LEB6300 Electric Dryer
Dishwasher switched itself off during cycle - no power now
It is possible that some of the pips have been washed down into the drain pump and jammed the impellor, follow the drain hose back to the pump underneath of the dishwasher make sure the d/washer is switched off at the power supply before you attempt this, if you have reasonable mechanical skill you should be able to remove front of pump to clean it.
Oct 09, 2008 | Bosch Dishwashers
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Acer Aspire 3690 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
