Question about Technics SL-1200MK5 Turntable
I took my TECHNICS SL-1200MK2 apart to replace the tone arm and the wires. Now I am having a problem reassembling it.
  • shwell Jul 02, 2008
    I did it from the bottom. In all honesty, I have a decent handle on the reassembly, but there are a few little bits that have me confused on where they should be placed. Thank you fro the break down. It should prove to be very helpful.
  • 515 Answers
Oh boy. This is always interesting. Here is a part schematic which will help you in figuring out how to put this back together:
http://1200s.com/images/Parts/MK2_tonearm.jpg
However, there's a little more to it than just putting it back together. YOu have to make sure the wires are routed correctly.
How did you disassemble it? Did you just remove the screws from the top (incorrect), and go that route, or did you go from the bottom of the unit (the correct way)?
Feel free to give us a call here, and our techs can walk you through this:
1.866.668.1596 ext 1
- Davis.
DIGITAL ANALOG THERAPY
Posted on Jul 02, 2008
  • TERMiNAL OPTiC
    TERMiNAL OPTiC Jul 02, 2008
    The main thing you have to be careful with is the routing of the tonearm wires. If not routed properly, they can be severed in the re-assembly. It has to go through the smaller of the holes on the cabinet where the tonearm mounts, and then routed through the white plastic piece right through the middle hole.
Hi i would lick to send my tone arm and base off to be anodised they have asked me what metal it is made of can you please tell me also the pop up light shell.thanks
They are asking this because anodising is especially suited to aluminium alloys, but not to steel.
Anodising can be done in various colours and finishes. Steel can be chrome plated, shiny or dull, and also plated with other coloured finishes such as cadmium.
The tone arm in this photo of the SL-1200Mk2 looks to be chromed, which means it is steel. To find out use a small magnet at the midway point to see if an attraction can be felt.
http://www.mds975.co.uk/images/vinyl_heaven/sl-1210_04.jpg
May 13, 2015 | Technics SL-1200MK2 Turntable
Why is the right side of my Technics turntable dropping out and giving me a ground hum?
It sounds like a bad connection to the cartridge, perhaps even the cartridge itself.
Feb 02, 2013 | Technics SL-1200MK2 Turntable
Just bought a new Shure high performance stylus for my Technics SL-1200MK2. After a few weeks of use, while a record is playing the volume on the left channel will drop significantly. If I take the...
it could be two things:
1.the tone arm wires that connect to the head shell (blue-red-green-white i think)
2. the needle arm has twisted round
Put it on the other deck if you've got one & see if it does it.
look right at the end of the needle tip,& see if it's straight & pointing down, if not carefully twist the needle arm round until it is,& push it into back in to the cartridge a little bit.
Sep 30, 2010 | Technics SL-1200MK2 Turntable
I have two technics turntables that aren't outputting any sound.. What are some possible problemns and how much would it be to fix???
Old decks have BAD RCA connectors. I would start there first. Its easy to solder them in... but you have to take the decks apart. As well as look at the leads that run through the tone arm down into the decks.
Nov 05, 2009 | Technics SL-1200MK2 Turntable
Tone Arm
(remedy) ok you can take the whole tone arm (remove the screw under the tunrtable , the rubber and the hard black and  go to the tone arm position (under) there is 3 screw to loosen and then try to burn wher the screw position .i mean take some lighter.but be carefull...
Aug 12, 2008 | Technics SL-1200MK2 Turntable
SL-1200MK2 Balance weight releasing?
Honestly... Just Pull it back off and switch it around.... it may feel like your gonna break your tone arm but just pull at the weight and it will give before your tone arm does... but BE CAREFUL!!!
Feb 06, 2008 | Technics SL-1200MK2 Turntable
Technics 1210 pop up light?
Maybe you should try putting a smaller (in Watts) lamp in the pop light...
Nov 09, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1200MK5 Turntable Logo
135 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
