Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 52 in. Rear projection hdtv problems
RCA D52W20 52 in. won't stay on turn it on and turns off 3 to 5 sec. the green light comes on like its trying to come on then goes off. please help .
  • 13 more comments
  • bowlchamps85 Jun 29, 2008
    when i try to turn it on the green light comes on then it goes off and comes back on and goes off then comes back on and goes off and thats it then it takes a couple min. to try it again and it does the same thing!
  • Anonymous Nov 29, 2008
    jjam2063 I have this problem also and it comes on and turns on and off 3 times before shutting down. Help jjam2063@yahoo.com
  • ktanner75 Dec 01, 2008
    i power my tv on and the green light comes on for about 2 to 3 seconds then it powers down and it tries again and it does the same thing . the coaxial plug fell out from the back and i tried to soder it back in place and i did and the tried to power the tv on but this problem accured.
  • Anonymous Dec 03, 2008
    I have the same problem with rca d52w20. I press power and it comes on then shuts off. It will then try to turn on 2 more times before shutting off. I then have to wait like 10 minutes before trying to turn on because when i hit power after it (cycles) it will not do anything. It also just loses its picture while were watching and just starts flickering. This piece of **** is just under three years old and was sitting in the basement practically unused for a year and a half. Wht a waste 0f 1100 dollars. RCA Blowz
  • gdh2o_72 Dec 05, 2008
    i have the same problem with this. can anyone please help!!!!???!!!
  • rodfehrmann Dec 07, 2008
    TV turns green power light on for the count of 10 off for the count of 4 on count of ten off count of 4 on count of 10 then off. Power green light flashes when you try to power down while green light is on. You can repeat after 3-4 minutes.
  • d8diana Dec 13, 2008
    When I turn on the power, the light blinks for a few seconds and goes dead. If I try a few times, it sounds like it wants to turn on but the light goes dead again. We bought this in 2005, and we already have problems. Not good! I'd like to fix this myself....any suggestions?
  • brucebettye Dec 23, 2008
    I PRESS THE POWER BUTTON AND A FEW SECONDS AFTER THE TV GOES OFF
  • jputman82297 Feb 22, 2009
    TV started shutting off by it self, got progressivly worse! Finally would not come on at all Power light just blinks three times and you can hear a high pitch whistle sound each time the light comes on. Was woundering if replacing the circut board and flyback would solve the problem? I can get both for about $200.00 and it would be worth fixing. Any suggestions would be appreciated>
    John
  • Anonymous Apr 22, 2009
    same problem
  • klnjdavis Apr 28, 2009
    hit the power button, the green lite comes on for about 2 seconds and goes off ( faint click inside the tv) about 3 seconds later the lite comes back on but only for a couple seconds ( faint click inside tv), then you can press button and nothing happens for about 2 to 3 min, then you can start over.
  • Anonymous May 09, 2009
    got the same problem....power wont stay on....turn off every 5 secs,...
  • Anonymous May 12, 2009
    I have the same problem, my tv turns on and makes a high pitch noise, then it just turns off. It does this about 3 times before it quits all the way.
  • JamesM513 May 14, 2009
    i have the same problem when i try to turn on my TV it just lites up and sits there for a sec no noise no pitcher
  • Gina Apr 27, 2012
    I'm having the same problem and don't see a solution...PLEASE HELP!!! Is it the bulb or is it the circuit board? Please help, please help, please help.
  • RCA Master
  • 8,617 Answers
Can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Posted on Jun 29, 2008
  • D Cook Dec 06, 2012
    No, it is solid red.
  • Sonny Berry
    Sonny Berry Dec 09, 2012
    The small signal board is the most likliest if the power indicator doesnt flash slowly three times then go out
  • RCA Master
  • 5,138 Answers
Replace cp150 2200uf 16v cp114 220uf 35v----cp120 220uf 35v these capacitors are on deflection board.
Posted on Dec 13, 2008
Lighty comes on three times no picture no sound
Posted on Nov 30, 2008
2 Suggested Answers
SOURCE: RCA D52W20 52 in. Rear projection hdtv problems
the circuit board behind the power on and off button needs to be replaced very easy fix.. good luck everyone
Posted on Jan 09, 2009
My rca 52inch rear projection tv would shut off then come back on know it won,t come at all is it possable it is a bulb help wayne
this model does not use a bulb, but has 3 picture tubes. Most common problem for this is bad solder connections under the high voltage transformer.
Nov 29, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Can u help me my RCA TV will not stay on keeps turning off.
Palaboy, where can i buy this part at ? R73 .0087uf h 2000 vdc. the one in red rectangle.
Jan 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Won't turn on
the power supply is bad ,deflection board is where i would look. the board w/ the transformer on it
Jul 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Won't stay on.
internal problem, if its under warranty take it back to store RCA is owned by Thompson and are IMHO not very good about outside registered repair techs. peeking in the case. I own a RCA 32inch and could not get even help for a Service Manual I think they are a closed repair gig.
Apr 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Check 3 capacitors on Power supply/deflection board cp150 2200uf 16v if it is bad replace 2 other caps in same circuit cp111 cp114 220uf 35v
Dec 01, 2008 | RCA D52W19 52" Rear Projection Television
Tv will not turn on. green lite for 4 secs, 3 times, then off. D52W20
It could be several issues from a bag power supply, the TV is connected to a power strip with several other components hooked up (DVD, Sound System, Xbox, etc.).
Try connecting to the wall directly and see if it now starts up.
Sep 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" RCA HD capable projection tv won't stay on!
This set has a processor that is telling the set there is a safety problem and shut the set down. this could be one of about 35 different cuiricts. Are there any sounds clicking chirping? An rca technician have special computer interfaces that can read errors generated by the processor that can help in determining what is wrong with your set.
Jan 15, 2008 | RCA HD52W56 52" Rear Projection HDTV
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
1,535 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
