Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Ceiling fan I cannot turn off my fan. I have changed the battery in the remote which is the only way to operate the fan and it still refuses to turn off. The lights and speeds also do not respond to the remote. HELP Tony
    Sergeant:
  • 234 Answers
Remote only problem! use assemble remote and test in fan!
Posted on Jun 30, 2008
My harbor breeze ceiling wont turn on.
  • Disconnect power at the source, not at the fan
  • Remove battery from remote. Press all buttons, then reinstall battery
  • Restore power. Using ONLY the remote, test operation
  • If the fan still does not work, disconnect power again and try every known combination of remote buttons and switch settings until the fan works or you give up in frustration.
Mar 13, 2017 | Dryers
My light on my ceilinf fan will only stay on dim.. What can I do to fix it.. It only operates bt remote
if fault is not on remote , you may need to bring down the ceiling fan and check on stuck electrical contacts and sensors to fix the problem.
Dec 28, 2013 | Hampton Bay Indoor Ceiling Fans and Light:...
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
The remote on my Hunter ceiling fan (Model: 27185 - 060) does not activate the ceiling fan. I can turn the light on manually, but not the ceiling fan. I cannot see the antenna on the ceiling fan.
The first thing you need to do, is change the battery(s) in the hand held remote, as well as the battery(s) in the receiver inside the fan's cowling. Weak batteries will limit a remotes operation.
And, FYI - there is no antenna on the ceiling fan.
I hope this helps you. Thanks for choosing FixYa.
Jul 25, 2011 | Heating & Cooling
I have a hunter ceiling fan and the light blew, when it blew then the remote quit working for the light, it still turns the fan on & off but after I replaced the bulb it still will not operate the...
Hello nita... I believe the fact that the remote stopped working is due to a weak battery in the remote. Change that battery and you should be back up and running. Joe
Thanks for choosing Fixya!
Jan 14, 2011 | Hunter 20537 / 20538 The Vista Iron...
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Remote controlled ceiling fan has mind of it's own.
I have the same fan. The fan and the remote have some "jumpers" which allow you to change the codes, useful if someone else nearby has the same fan. You can see the jumpers inside the remote, open the back cover... you'll see "4 3 2 1" on the circuit board. Unfortunately you'll need to dismount the fan to change its jumpers, they need to be the same as the jumpers in your remote (which you can move around pretty easily).
Jul 01, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Remote not working at all
Check the fan and the remote to see the code switches are same. Sometimes depending on the age and humidity you may have to slide the switches back and forth to clean the contacts. Did it ever work? Are the batteries in the proper polarities? The fan and remote have to have the same numbers picked to operate properly.
Nov 16, 2008 | Hampton Bay 48670 Flemish Pewter Finish...
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
46 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
