Question about Sony SLV-D370P DVD Player/VCR
DISCWON'T PLAY, RECEIVE MESSAGE "THIS DISC CANNOT BE PLAYED, PLAYBACK PROHIBIT BY AREA LIMITATIONS
WHEN I PUT IN THE DISC, PLAYER DISPLAYS A MESSAGE "THIS DISC CANNOT BE PLAYED, PLAYBACK PROHIBIT BY AREA LIMITATIONS, DVD - ERRLOG5 1F8B5108000000000006 01010C00000C002400D7"
  • MrTimTO Feb 15, 2009
    My Sony SLV-D370P indicates a region code problem with DVDs created on my computer. Other players read these OK and the Sony reads DVDs created by the same software on another computer. Any ideas?
  • unemployeddesktop Jan 16, 2013
    Create an AVI file from the DVD using BITRIPPER. http://bitripper.com/download.html Burn a new DVD from the AVI file using SoTHINK Movie Maker. http://www.sothinkmedia.com/movie-dvd-ma... worked for me.
I am ohamed scondo
i have pdf repair
Posted on Sep 16, 2008
My DVD and VCR in one has always played DVDs, and now when I tried to play a DVD, it says playback feature may not be available on this disc. I've played the same DVD on the same tv perfectly before!!
sometimes the discs get scratched enough that the player has difficulty reading them, using some car wax on the disc to clean it may help
Mar 09, 2013 | Televison & Video
Why ask me my DVD Playback prohibited by area limitations ??? Pls help me now I wane watch movie thanks
Most DVD players are region-locked, meaning they will only play disks encoded in the location they are from, or disks without region-specific encoding. For example, if I bought a DVD player in Europe and tried to play a disc from the United States, it would not play. Unfortunately, in order to get past the "area limitations" you will either have to buy a DVD encoded in the same format as your DVD player, or set the player to a different region code (which often will lock the player after a certain number of times).
Feb 27, 2013 | Televison & Video
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
My dvd player says playback prohibited by area limitations
Sounds like it's the wrong region disc. Try a disc that worked before and if it does than there is nothing wrong with your dvd player it is the disc you are trying to play that has the issue.
May 07, 2010 | Sony DVP-SR200P DVD Player
Pinnacle DVD's won't play in DVD players
The region code of your stand alone player is different from the region code on the disk. To resolve this Pinnacle should have an info tool that will allow you to check the region code. If not Nero has this tool available with thier software. You should be able to download it @www.download.com. Also most newer DVD players only read specific data types. For instance, you cant use DVD-RW in a player that only reads DVD-R. So make sure you are using disks that are compatible with your DVD player.
Mar 15, 2010 | Pinnacle Studio Ultimate 12 for PC
Disc spins, then " Type of disc can not be played" message
it means the format of the type of cd u put in cannot be played by the system.
try playing the disc it on another player, if it does the same, it means the disc cannot be played. some players dont play mp3 format, blu ray, and some others, so you can check the kind of disc you want to play on it.
goodluck
Feb 03, 2010 | Panasonic DVD-S25
DVV Player won't play disc
Check to make sure your player can play other disks. If so then use the disk doctor to remove the scratches on your favorite disk. The area that all DVD players scan before playing a disk is probably smudged or scratched.
Nov 21, 2008 | Philips DVP3345V/17 DVD Player/VCR
ERROR MESSAGE:
If these disks have not been finialized then they will not play on the dvd player. Turn your computer on and see if they will play. If they will then you will need to the dvd palyer finialize them. I hope this helps you. If not get back to me and then we can try a different way.
Aug 15, 2008 | Hitachi 168589 DVD Player/VCR
DVD doesn't play any disk anymore. Displays a message: this can't of disc can't be played ... I tried several different types of disks.
Same here! It would say something along the lines of "this type of disc cannot be played. please insert a different disc." it's the appropriate dvd region, i've tried all types of dvds, and it still won't work. the vhs and cd still works, it's just the dvd player that won't.
Mar 30, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
Sony SLV-D370P DVD Player/VCR Logo
1,459 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
