Question about Kodak EasyShare Z730 Digital Camera
Kodak z730 lens
The lens cover will not open and the lens extend upon turning on the camera. Seems like the gears are stuck.
  • amigauser Jul 05, 2008
    Hmm Same problem here, and this was noticed 7/7/08.
    I just shot and downloaded pictures earlier 6/25/08 (USB) and it worked well.
    And now not even software (PC) connection works....
    I get a little red blinking camera icon on the lower right corner of screen before the camera shuts down.. and- yes- battery is good.
    hmmmmmm... nice easy camera to use..nice big screen. want to keep this.
    Danielj
Ok found out my particular fix...
Had to recharge battery 2 times in a row, no idea why this worked.
Camera now operating as usual.
Posted on Jul 06, 2008
Shutter will not open to take the picture
there must be dust or rust in lens cover so with the help of the finger open it if the image no appar see the sutter or ccd
Sep 08, 2009 | Kodak EasyShare Z730 Digital Camera
When battery is put in red led in front turns on but lens will not extend or turn on it is an kodak easy share c763
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Aug 24, 2009 | Kodak EasyShare C763 Digital Camera
My Easy Share (Z730) is in the open position & will not close.
VERY COMMON WITH EASY SHARE. There are only a couple things you can really do. FIrst, try removing the memory card and try it. Than if that dosen't work. Try holding power button while gently wiggleing the zoom.
May 30, 2009 | Kodak EasyShare One Digital Camera
The lens will not extend
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
May 29, 2009 | Kodak EasyShare Z612 Digital Camera
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 08, 2009 | Kodak EasyShare V1003 Digital Camera
Shutter does not open
The camera does not gets opened on power on it seems that some gear has broken inside
Feb 27, 2008 | Samsung Digimax A400 Digital Camera
Lens stuck camera turing on and off
Lens mechanism is shot. A repairs is not likely to be an economic proposition Contact Kodak customer support for a try
Jul 29, 2007 | Kodak EasyShare Z710 Digital Camera
Lens stuck open
Hi! Sounds like we have the same problem but mine says lens error 221,0,0,0 and my daughter dropped mine. If i dont get an answer soon, im sending my in for repair, it will only cost me $50.00. Here is the website incase you want to fix yours :) WWW.Kodak.com and just click on the repairs and services. Good Luck!!
Jun 18, 2007 | Kodak EasyShare C703 Digital Camera
Kodak DX6340 Lens Cover Does Not Open
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Aug 13, 2006 | Kodak EasyShare DX6340 Zoom Digital Camera
Kodak EasyShare Z730 Digital Camera Logo
220 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
