Question about Maytag Neptune MAH5500B Front Load Washer
Maytab Neptune FL washer
The lights on the panel won't change settings and it won't start. I tried unplugging to reset the oard but nothing happens. It has been an intermittend problem but it seems to be lasting longer. What can I do?
  • 2 more comments
  • jkraska Jul 06, 2008
    Having the same problem, sometimes after loading the washer and closing the door, i will hit the start button, the door will lock and then moments later it will unlock and never start the wash cycles.
  • Nebuzaradan Jul 15, 2008
    Sounds like I've got the same problem. I had a load in the washer and it was running but we had to stop it in the middle of a load because the pipes were backing up. It was two days before we could get the pipes cleared and restart the machine. When we turned it back on, most of the lights lit up, but nothing happens when I pressed start. It did not respond when I pressed the off button either. I tried unplugging it and resetting it and still nothing. I messed with it over the course of a day and a half and suddenly it began working again.
    Now it is doing it again and so far I can not get it to start. Anyone know about this?
  • j14b90 Oct 04, 2008
    no matter what i do nothing changes. i turn the machine on the lights go on, everything seems fine until i push a button. it just gives me the error beep. the only time it seems to work is when it wants to. and there is no indication of when that is. leavin it unplugged doesnt work either. can someon plz help me. so much for maytag being dependable.
  • Anonymous Oct 09, 2008
    i am having the same as everyone else
  • 750 Answers
Hello ortizai and friends
Welcome
If the washer stops here are some reasons why this may happen.
The water lines have screens that can become clogged by accumulating debris in the water,
And then the machine will automatically shut down. And if its not completely blocked it will shut down intermittently!
1. Plug cord into live electrical outlet.
2. Check fuse or reset circuit breaker.
3.Close door firmly and push the Start/Pause pad to start the washer.
For your safety, the washer will not tumble or spin unless the door is
closed.
4 This may be a pause or soak period in the cycle.
Wait briefly and it may start.
5. Check screens on inlet hoses at the faucets for obstructions.
Clean screens periodically.
May be on hose ends too,and will be in the water inlets of the washer!!!!!!!!!!
Let me know who gets started, since there are multiple people with this problem.
Huuum
Please remember to leave a rating
I'm trying to figure out more ideas and will forward them soon.
Posted on Oct 05, 2008
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
Why won't my maytag neptune front loading washer will not start?
Check out the door switch to make sure that it closes when you latch the front door. If it does not close the machine will be inoperative - safety measure.
Sep 19, 2017 | Maytag Neptune MAH5500B Front Load Washer
Washer will not start. Accidentally pressed 'off" button and now the start light is blinking and I can't change the settings or start the washer
try unplugging the washer for 5 mins. to reset the main control board, if that doesn't help check to see if both door latches are locking
Jun 03, 2011 | Maytag Neptune MAH5500B Front Load Washer
I started a cycle, added the detergent to the water compartment but then FL code showed on the display and the cycle stopped. I turned the washer off, unplugged but nothing change.
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer will not start...indicator lights are on. We have unplugged and tried to start by pressing "cotton/sturdy" and the start/pause. Cannot change settings
Do you hear a double beep sound when depressing any of the other buttons? If so you most likely have a defective key panel. If nothing happens at all, it may be the home control board (inside the control panel). Before you replace the board, try this diagnostics test,
Press and hold the hand wash key and the heavy soil keys for 3 seconds. The display should go to "00" next press the spin only key and the machine should run a quick spin test. When this completes press the "off" key to exit service mode.
Now try the machine, and hopefully you have cleared it's software glitch.
Good luck to you!!
Jun 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
LID WON'T LATCH ERROR CODE FL
With that code FL “ Failed to lock” I would start looking at the lid latch mechanism. See this link from another site for lid latch problem.
http://fixitnow.com/wp/2006/09/06/maytag-neptune-fav6800aww-top-load-washer-op-code/
If you want to try to repair or get a better understanding of how to diagnose and repair this machine take a look at the service repair manual.
http://www.servicematters.com/maytag_library/docs/16022808.pdf
I hope this will help with your decision to try a repair or replacement.
Good luck with your issue.
Jan 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
"FL" light
The "FL" error code indicates that the door is not locking. The buzzing sound you hear is most likely the door lock trying to lock the door. It may only be a matter of aligning the door so that it locks properly. Otherwise, you may have a faulty door lock that needs to be replaced.
Feb 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
88 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
