Question about Brother MFC-3240C All-In-One InkJet Printer
Printer won't print
I changed the cartridges on my printer, then it started the cleaning process. After it finished, i tried to print out some documents and they came out blank. The machine sounded like it was printing but nothing came out. I have done the cleaning process over and over and still nothing.
  • Wayne Urton Oct 09, 2008
    I get no black at all. I have tried replacing the black and running the cleaning process several times. The three colors look good, but still no black. I contacted Brother's support. They replied with "run the cleaning process several times" which I had explained that I did that in my problem statement, so that response was no help at all. And "call service" is not a good option. If you take a printer to a computer repair shop, they will usually tell you that service will cost more than just replacing the printer.
    Problem Solver:
  • 12 Answers
If you have not performed the exact procedure described on page 12-15 in Chapter 12, Troubleshooting and routine maintenance, of the Users Manual, do so.
Heed the last paragraph of this page: If you clean the print head at least five times and the print has not improved, call Brother Customer Service (see Brother numbers on page i).
Posted on Jul 21, 2008
4 Suggested Answers
SOURCE: HP Laserjet 1020 - prints blank documents
The printer accepts the sent document and processes it but the pages it prints are blank. I've tried several cartridges with the same result... so am confident it's not an empty cartridge problem.
Posted on Oct 31, 2008
  • 11 Answers
SOURCE: CHANGED INK, WON'T PRINT.
Try to reinstall software restart pc when it asks if the cartridge is new say yes
Posted on Mar 25, 2009
nicarta
  • 506 Answers
SOURCE: The PGBK cartridge doesn't print anything
Do a selftest on the printer. If the Selftest prints out something, uninstall the printer Driver and reinstall it again. If it still did not work checkin the printer to a qualified technican to have a look at it.
Posted on May 12, 2010
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
I keep on getting Ink System Failure for HP 309a inkjet printer. I tried to clean the printer head still no lack.
Most likely, it is a print head issue. The print head is what the printer cartridge sit in inside the printer. To fix the problem, please do the following:
1) Open the printer and wait for the carriage to slide over.
2) Remove the ink cartridges from the print head.
3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to clean the printer head and electronic contacts on ink cartridge.
4) Repeat the same procedure until no ink residue coming off on the cotton swab.
5. Once finished, allow to dry and put back the ink cartridges in.
6. Try printing.
If the above troubleshooting won't work then maybe one of the cartridges is defective or both. If none of the cartridges are defective, then you need to replace the print head.
I hope this helps.
carlo
Nov 16, 2012 | Office Equipment & Supplies
Lexmark X5470 is not printing but the software thinks the printing is complete. What's wrong?
It could be that your cartridges need some cleaning. From the printer operator panel, while on Copy mode, press the Menu button > Tools > Maintenance > Clean Cartridges. Your printer will then print a page forcing ink through the cartridge nozzles and clean them from possible clogs and dirt.
If that doesn't help, try to re-seat your cartridges into the printer. You may also replace your cartridge with a different known working cartridge to determine if it's a faulty cartridge issue.
Mar 04, 2012 | Lexmark X5470 All-In-One InkJet Printer
My Canon Pixma MP258 printer can't print the red color but other colors are okay.When I print out any words or pictures that needs red color,it becomes green color.I don't know what's wrong...
Solution
1. Press START - Devices and Printers
2. Right-click the Canon MP258 series - select Printing preferences
3. Click Maintenance - Cleaning
4. Select All Colors BK, C, M, Y - Execute
5. Wait until the process is finished (Do not start another operation until the cleaning has finished).
6. Click Print Check Pattern OK
If the results print out like this, there are two possibilities:
1. Red ink in the cartridge runs out. Solution: injecting with red ink
2. If the red ink has been filled, and check pattern is still not out, meaning the color cartridge error.
Solution: replace the cartridges
Oct 15, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
Hi pse help. My Canon MP600 printer does not print the magenta colour. I have changed cartdirges and tried evrything I could think of.
If you have already tried inserting a new Magenta cartridge & have checked to make sure that the piece of tape that covers the bottom of the ink cartridge has already been removed - then trying cleaning your print heads & aligning the printer.
You can access the cleaning features on your printer by pressing the menu key and using the up and down arrow keys on your keyboard to scroll the options until you see the maintenance catagory - then click on it. Continue scrolling the options with the arrow keys until you see the clean the print heads or print nozzles choice, then click on or accept to start the process. follow the prompts on the printer and try cleaning at least twice, then try a test page. If this does not solve the issue, then go back to the menu key and return to the maintenance area and choose align print heads instead. Press ok or accept to start the alignment process and follow the prompts on the printer until its completed. Check the print out to see if the color has printed. If it has not printed then you might want to try cleaning the print head area in the printer yourself.
To clean the print head area yourself, open the printer to bring the ink cartridges front and center to make sure they are accessible to you. Then turn the printer off and unplug it from the wall. Press and hold the power button for 45 to 60 seconds. Then open the printer so you can see the ink cartridges and remove them all. The print heads are located right below the area where the ink cartridges are installed. There should be a plastic tab to press or pull right under the ink cartridge carrier to access the print heads. Print heads look like plastic square containers with sponge heads on top. Remove each print head one by one and use a dry lint free cloth to clean up and ink spill you see there. Use warm water to clean the brass connections on the print head and in the machine to remove any dried ink. You can also use Qtips and alcohol mixed with water to remove any stubborn or stuck ink. When finished press the sponge to make sure its wet and not hard and dried out. Then reinsert them, plug the machine back in and turn it on. Try a test page or the alignment process one more time to see if you issue is solved.
If all of the above does not solve your issue, I suggest contacting Canon for assistance.
Sep 14, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Installed new 28 and 29 cartridges in lexmark x2550 and it won't recognise the cartridge and won't print at all, very frustrating please help urgently
It could be that your cartridges need some cleaning. On your computer, launch the Lexmark Solution Center. Click Start menu > Programs or All Programs >Lexmark 2500 Series > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print again.
Jun 29, 2011 | Lexmark X2550 All-In-One Printer
My Lexmark Z2320 only printing pink.... 3/4 full black cartridge, and 1/2 full color cartridge. Why only printing pink....
If your printer is only printing one color, it is a clear sign that the printer is in need of a head cleaning, and possibly an alignment. The instructions to do so are as follows according to the Lexmark website:
  1. Load plain paper.
  2. Then do one of the following:
    - in Windows Vista, click pattlnk_852008_1527-vista-start-button.gif.
    - in Windows XP and earlier, click Start.
  3. Click All Programs or Programs, and then select the printer program folder from the list.
  4. From the printer folder, click Maintenance - Align Cartridges.
  5. Click Print.
  6. Follow the instructions on the computer screen to finish
  2. Do one of the following:
    - in Windows Vista, click pattlnk_852008_1536-vista-start-button.gif.
    - un Windows XP and earlier, click Start.
  4. From the printer folder, click Maintenance - Clean Cartridges.
  5. Click Print. A page prints, forcing ink through the print cartridge nozzles to clean them.
  6. Print the document again to verify that the print quality has improved.
Complete both of these processes, and your printer should begin printing normally again.
Apr 07, 2011 | Office Equipment & Supplies
Canon MX850 Large Black Ink Cartridge - PGI-5BK problem
Just bought new MX318 one chamber gets finished after a few pages. No indicator for finished ink. One compartment of Ink cartridge looks empty the other still full. Tried cleening process but no improvement. Replaced Cartridge but it seems to behave the same as the first after a few prints.
Aug 03, 2009 | Canon PIXMA MX850 Multifunction Printer
C84 not printing
I assume that before the old cartridges ran out of ink, everything was printing normally. If so, the usual reason for this problem after a cartridge change is getting air into the print head system. Did you do a proper cartridge replace process, which finished with an ink charging cycle? Have you tried running 2 or three head cleaning cycles? If not do it, then run a nozzle check. Any sign of ink - yes - then things are OK you've just got to get the ink flowing properly. Run a couple more cleaning cycles then leave it to rest for 24 hours to let the air bubbles disperse. Then try again.
If you get no sign of ink after these processes report back.
Jan 18, 2009 | Epson Stylus C84 InkJet Printer
Brother MFC-3240C All-In-One InkJet Printer Logo
204 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
