ALERT!CHIPSET HEAT SINK NOT DETECTED,SYSTEM HALTED!>
  • Anonymous Feb 05, 2009
    When I start up my pc, the screen shows "Alert! Chipset heat sink not detected. System halted !" error message.
No cpu fan are working very well. i don't really know what the problem is, all i get is Chipset heat sink not detected system halted
Posted on Jan 24, 2014
    Scholar:
  • 88 Answers
Did the cpu cooler fall of? did a fan stop working? perhaps you should open it and have a look- obviously something is overheating. We need more information than this.
Posted on Jun 29, 2008
Dell optiplex 780 . Alert! chipset heat sink not detected. system halted!
that means that you need to reset your fan and heat sink and/or replace it.
Jul 27, 2014 | Computers & Internet
Alert! Chipset heat sinknot detected. System Halted.
There is a heat-sink that is attached to the video chip on the motherboard. The restraining clap that holds it in place is probably detached.
Mar 05, 2013 | Dell OptiPlex SX280 PC Desktop
Alert chipset heat sink not detected system halted dell xps 420
Sounds like your heatsink which is inside the computer and sits on top of the CPU is bad. There will probably be a fan that sits on top of the heatsink.
Look on ebay and purchase one for your system.
http://www.ebay.com
I found a new one below on ebay for $14.95 (the link is below)
http://www.ebay.com/itm/New-OEM-Dell-Dimension-9100-XPS-420-430-Heatsink-Assembly-XP850-/350520689627?pt=LH_DefaultDomain_0&hash=item519ca943db
May 12, 2012 | Dell XPS Computers & Internet
Alert! Chipset Heatsink not detected. System halted! is the alert that comes up when I turn my computer. What can I do?
Hi scotteg71121...
The alert is caused by a loose chipset heat sink.
Dell has a self test that prevents further damage by halting the system and displaying the message Alert! Chipset heat sink not detected. System Halted.
The solder joint seems to fail from constant tension and heat.
If you find the missing clip inside the computer you can solder it back in place and reattach the chipset heat sink wire hook.
If you can't find the clip you can replace it by bending a thin piece of wire in a half circle.
You can see a picture of where the clip goes on your computer motherboard by following the link below.
Please take time to rate me
http://www.aplusperfect.com/articles/chipset-heatsink-not-detected
Sep 05, 2011 | Dell Dimension 4600C PC Desktop
Hello, I've got a Dell Optiplex GX280 series desktop pc which has refused to boot up. Instead it shows an error saying "Alert! chipset heat sink not detected system halted! Would appreciate your...
Both your CPU and chipset have heatsinks to dissipate the heat they generate.
Over times, the heatsink compound between these components and the heatsinks
may dry up and no longer conducts heat efficiently. Your system on power up,
detects excessive heat from the chipset and if allowed to continue on, will burn
itself up. To protect it, your system shuts itself down.
Open up your case and inspect the chipset. Make sure the fan (if any) is running.
If it is, you may have to remove the heatsink (normally clipped on to the chipset)
and remove the old compound and apply a fresh new layer of heatsink grease.
While you are at it, also replace the heatsink compound of your CPU.
Jul 11, 2011 | Dell Optiplex GX280 (99301) Motherboard
On boot up on my Dimension 3100C I receive the following error message: Drive 1 not found:Parallel ATA, PATA-0 (PRI IDE Master) Alert! chipset heat sink not detected System halted!
first off your going to ewant to hit f2 or f12 to get into setup and you are going to want to change boot oder to your hard drive. i then would open the comoputer up by taking the side of the case off and checking your cpu. u are going to wanna make sure there is a heatsink or fan securly on your cpu. if not this could over heat and burn your cpu up. heat sinks look like thisbadboy616.png
Jan 07, 2011 | Dell Dimension 3100 PC Desktop
Turn the computer off.
Disconnect the AC power.
Open the case.
Check that the heat-sink is securely and tightly connected where it should be.
May 07, 2010 | Dell OptiPlex SX270 PC Desktop
Computers & Internet Logo
901 people viewed this question
David Payne
David Payne
