Question about Whirlpool LER5636P Electric Dryer
Grease spots on clothes
When the clothes are put in the dryer they come out with grease spots
  • Anonymous Mar 23, 2014
    can we take the front off or the top off
  • 417 Answers
That could mean your overloading your dryer to the point the wheel bearings are squished really bad. When loading your washing machine you should always be able to see the water level more than the clothes, your clothes should be floating in the water. That way, when you unload your washing machine and go to dry, you will have the right amount of clothes everytime
J
Posted on Jul 11, 2008
What should I do to stop washer from putting grease on clothes?
Good Afternoon Bernard,
I understand the washer of your Frigidaire laundry center, model# GLEH1642F, is leaving grease in your clothes. I also see that you noticed the grease in the detergent cup. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine where the grease is coming from to be able to repair your appliance. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire GLEH1642F Front Load Stacked...
I get brown spots on light clothes, looks like burn marks. What is the cause for this and can it be fixed?
Look for grease in the washer, and look for lint that has gotten into the burner of the dryer. It is usually burned lint that causes this issue, correct dryer venting is the solution, after completely cleaning the unit.
Mar 06, 2011 | Dryers
Grease /oil spots on clothes coming from washer
This sounds like the drum bearings are starting to wear and allowing grease to infiltrate through the inner seal.Does it sound noisy on the spin cycle.
May 03, 2010 | Speed Queen AWN432 Washer
Zanussi ZJD1219 Washer/Dryer - noisy spin and dirty spots
Sounds like the main drum bearings have failed, and the marks on clothes are probably grease spots from the main bearings.
It is quite an involved repair, and not one that I would recommend you tackle yourself unless you are competent to do so,as it really is involved.
Please rate my solution.
Thanks.
Nov 15, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Gas dryer leaves black grease spots on clothes
the soot is coming from the flame at the gas heater box the drier needs to be converted to propane the flame is too large without the conversion kit installed and thus creates soot at the vent. contact a local repair place for this one it can be tricky.
Sep 12, 2009 | Whirlpool LGR5636L Gas Dryer
Greasy looking spots on clothing after washing/drying.
Without seeing the spots, this is a bit speculative, but here goes,......
I'm guessing that the spots are only found on the front side, primarily of shirts, or blouses, etc. These are from grease splatters from cooking, which many times only show up after washing and drying.
The soap releases some dirt, which is attracted to the non-removed grease spot, allowing it to show up. Re-wash the clothing, pre-spotting those areas with a citrus pre-spotter.
Aug 31, 2009 | LG WM0642H
Rust spots showing up on the clothes?
Give the clothes more drying time and then remove them as soon as the dryer stops. Over the years, dryers get chipped inside and if damp clothing is allowed to lay on the chipped areas, rust spots will appear.
Also, If you have a lot of iron deposits in your water, you might want to put a filter in your line into your washer.
Feb 17, 2009 | GE DBSR453EBWW Electric Dryer
Moffat heavey Duty Dryer
Hi and thank you for your request.
Assuming the marks were not there before you put them in the dryer, then there are a couple of possibilities for the marks appearing.
Check that none of the clothes lifters or ribs as they are sometimes called in the drum are not loose, as the clothes could get caught in any gaps,make sure that there is no large gap between the drum front and the front of the dryer, as again clothes could get caught here,,check to see nothing is stuck on the drum itself that could transfer onto the clothes.
Make sure the drum is free to turn and that there is no unusual noise coming from it, if it does appear to be noisier than usual ,then it could be the drum rollers or bearings are starting to wear and this could transfer grease and the like onto your clothes.
Hope these suggestions help with your prob.
Plz feel free to leave any comments and rate my suggestions.
Thanks
Jan 05, 2009 | Dryers
Dark grease stains on the cloths after drying
Most likely a bearing failure, a seal that retains grease has given up and is spewing into the drum through a shaft opening of some kind.
If you are positive there is no grease in some of the clothes, or someone is putting it in the drum, then a seal has failed, and now that the grease is coming out, the bearing it is was supposed to lubricate is now low, and will fail prematurely, you need a service call and soon.
Will
Nov 17, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
227 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
