Question about Canon PIXMA MP160 All-In-One InkJet Printer
Error E 4, 2 canon pixma mp 160
Ayuda con la impresora no se mueve y sale el error E 4, 2
  • 2 more comments
  • Anonymous Jul 08, 2008
    I have a problem with the mp 160. an error E 42.
  • Anonymous Sep 09, 2008
    error E 4 2
  • misty11 Sep 09, 2008
    I have disconected the printer from power and also tried troulbeshooting for the E42 problem an i can't get the printer to work.
  • whitefink196 Dec 20, 2008
    please clarify, will the power led remain green or orange with each press of the reset button? does one have to time each press with the alternate flashing of the orange 'alarm' and green 'power' light? additionally do you know of any new printers that do not have false expiration chips ('death chips") installed either in their boards or in their ink cartridges? i had the idea that hp having lost an EU lawsuit regarding this practice would find more dignified ways doing business. the $2.43 (against a $14.00 cartridge) settlement check i received as a result seems to have encouraged other companies to join in rather than consider the venality carrying on like this.
    thanks for your time,
    sjw
  • 4,889 Answers
E42 means scanner error. May require a hard reset(disconnect from power supply for 30 min). Otherwise may require factory reset procedure to be applied. Follow the steps below:
Mp160 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s)
according to the function listed in the table below.
(Each time the Stop/Reset button is pressed,
the LED lights alternately in orange and green, starting with orange.)
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset procedures below.
5 times Orange Destination setting See Destination setting procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Posted on Jul 09, 2008
  • 25 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
548
Posted on Feb 27, 2009
Mi impresora HP 5610 tiene encendidas todas las luces marca un errror 0xd05d010d RESET POWER, que puedo hacer.. gracias
SOLUCION: Hola la solucion para la HP Officejet 5610 con ERROR 0xd05d010d es muy sencilla hay que resetear el Equipo lo cual se hace asi:
1. Desconectas el cable que va de la impresora al equipo
2. Luego desconectas el cable de poder de la impresora
3. Mantienes presionadas las teclas (ASTERISCO) * y (NUMERO) # y conectas el cable de poder a la vez.
4. Te sale unas preguntas de Idioma y pais las respondes y LISTO
BUENA SUERTE
Aug 23, 2011 | HP Officejet 5610 All-In-One InkJet...
Tengo una television sharp y no se como programarle el control universal dish podrias ayudarme con los codigos y la manera en la que se programa
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televisor Sharp. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Sharp tenemos los codigos 628,739,741,605, y 835. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Apr 04, 2011 | DISH Network IR Remote Control
Codigo de erro 3807 como resolver?
Para solucionar el mensaje de error que indica que se ha producido un error en el estado del sistema (c?digo de error 3807):
  1. Desconecte el adaptador de alimentacion de la impresora.
  2. Espere 30 segundos para que se reinicie la impresora.
  3. Conecte el adaptador de alimentaci?n a la impresora. Si fuera necesario, encienda la impresora.
Si el error continua:
  1. Abra la puerta de acceso de la impresora.
  2. Retire e instale el cabezal de impresion dos veces.
http://support.es.kodak.es/app/answers/detail/a_id/31546/selected/true
  1. Cierre la puerta de acceso de la impresora.
  2. Espere a que la impresora est? lista para su uso.
Si el error no se soluciona, pongase en contacto con nosotros:
http://support.es.kodak.es/app/answers/detail/a_id/22432/selected/true
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Feb 25, 2011 | Kodak ESP 5 Printer
Mi impresora canon mp 210 no la reconoce leopard 10.6.3
Gutenprint-5.2.6.dmg (MB de 14.8) Esta liberaci?n ofrece apoyo adicional para el Estilo de Epson Profesionales impresoras, junto con algunos cambios para otras impresoras de Epson y apoya para el Canon adicional de chorro de tinta e impresoras l?ser de PCL.
http://sourceforge.net/projects/gimp-print/files/gutenprint-5.2/5.2.6/gutenprint-5.2.6.dmg/download
Feb 06, 2011 | Canon PIXMA IP5200 InkJet Photo Printer
Mi impresora canon mp150 prsenta error 6500 y no encuentro solucion agradeszco su opinion
Un error 6500 hace referencia a un error de la placa l?gica en la impresora. Con el fin de solucionar el problema, le recomiendo lo siguiente:
1. desench?felo y desconecte la impresora del equipo. desenchufar la impresora de la toma de corriente.
2. Pulse y mantenga presionado el bot?n "On" durante 30 segundos, luego deje la impresora solo por 10 minutos. Esto permitir? que alll corriente el?ctrica para ser dado de alta de la impresora.
3. conectar todo de nuevo a la computadora y toma de corriente. Encienda la impresora.
4. eliminar los dep?sitos de tinta de la impresora, a continuaci?n, volver a asiento. Aseg?rese de escuchar cada "clic" en su lugar a medida que los puso pulg
5. Apague la impresora y, a continuaci?n, de nuevo, prueba para ver si funciona ahora.
Si no es as?, tendr?s que ponerte en contacto con Canon para la reparaci?n de la impresora / una junta nueva l?gica para la impresora.
Dec 28, 2010 | Canon PIXMA MP150 All-In-One InkJet...
LA MÁQUINA INDICA ERROR E000805-001
1) Desconecta el poder de la impresora. 2) Quita el ladrillo/bloque negro del poder por detr?s de la m?quina. (Puede ser un malvado peque?o de sacarlo la primera vez usted lo quita.
3) Abre la cima de la impresora/multi unidad de funci?n.
4) tira Suavemente la cinta para centrar el portador de cartucho de impresora.
5) Abre o el lado de izquierda o derecha y quita el cartucho. (Depende de cu?l lado el error ocurre en, negro a la izquierda, el color a la derecha)
6) Verifica que toda la tira pl?stica que cubri? los nuevos contactos en el cartucho tiene de hecho fue quitada.
7) Toallita tanto los contactos de cartucho como impresora con una seco, hilas libertan tela.
8) Enjuga el fondo del cartucho con una h?medo, hilas libertan tela para verificar que la tinta fluye y los vistazos corrigen.
9) se Asegura de que no hay agua que queda en el cartucho.
10) Reinserta el cartucho en el portador y se asegura de que es profundizado y es insertado completamente al trasero de la ranura de portador.
11) Reinserta el ladrillo/bloque del poder.
12) Conecta de nuevo el cable de energ?a el?ctrica de impresora.
13) el Poder en la impresora y el error debe ser resuelto.
14) Corre la alineaci?n de impresi?n e impresi?n o copia varias p?ginas para asegurar el problema ha sido resuelto.
Dec 19, 2010 | Office Equipment & Supplies
La impresora canon ip4600 no reconoce los cartuchos. al encernderla parpadea las luces y sale el error 6502
C?mo restablecer el c?digo de error "6502" para CANON iP4300 ip4600? tal vez los siguientes consejos pueden ayudarle:
Con la impresora desconectada, retirar el carro de tinta a la derecha, Enchufe la impresora, presione el bot?n POWER, No suelte el bot?n de encendido, y luego presione el bot?n RESUME dos veces seguidas. Suelte el bot?n POWER, pulse el bot?n REANUDAR 4 veces.
La se?al ac?stica puede sonar una vez. Luego, con la impresora desenchufada, despu?s de que restablecer la unidad electr?nica de la impresora, abra la impresora y este proceso ha terminado.
Listen Read phonetically
Dec 14, 2010 | Office Equipment & Supplies
El problema que tengo es con una dell 3100cn y elo que me aparece en la pantalla es el siguiente mensaje "bandeja 1 debe de ser de 250 hojas" no me permite meterme al menu ni tampoco se queda...
Nused que cuando movi? la impresora que usted instal? atr?s encima de la bandeja de 250 hojas (es requerido para el modelo 3100cn), es posible que puedan haber da?ado la entierra-conexi?n el?ctrica entre la base de impresora y la unidad de 250 hojas de bandeja.
Devuelva la base de impresora de la unidad de bandeja y conjunto aparte. Examine con cuidado el conector en la unidad de bandeja y aseg?rese del corchete que contiene el conector no ha sido doblado ni ha sido deformado. Consiga alguna ayuda e incline la impresora atr?s suficiente distante que usted puede examinar el conector que aparea debajo de la impresora. Si no ayuda a estar disponible, desliza la orilla de la impresora lejos la orilla de una superficie fija s?lo lejos suficiente en ver la conexi?n.
Nov 30, 2010 | Dell 3100cn Laser Printer
Error code 5100 on my printer cannon ip 1700
por favor necesito ayuda para una impresora cannon mp180 despues que la mando a fotocopiar y va a tomar la hoja me sale el error (servicio impresora 5100) les agradezco me estan atacando
May 04, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
10,205 people viewed this question
old marine
old marine
