Question about Lite On LVW-5005 DVD Recorder
LVW 5006 I turn on my machine, it says Hello and that is all it will do. Is there a fix for this or is the machine broke?
  • 1 more comment
  • grcarter5 Jun 30, 2008
    I have already tried a hard reset, both for 2 hours and a couple times over night. It still only comes on and says Hello, there is no start up sounds or anything. I also cannot get the dvd door to open
  • grcarter5 Jul 06, 2008
    I have unplugged my Lite On, I have tried the hard reset. There is not a disk in the drive. My thought is that the hard drive is junk and that it is not a problem with the other workings of the machine. My problem is how do I know for sure, is there a way to reset the DVD burner? Will I need to buy a new burner and replace it. This unit is only 3 years old, but I will say that I use it a lot to burn DVD's. It is frustrating when something only 3 years old quits. As I stated in my first post is that it turns on, says Hello and then nothing. There is no sign that the DVD is working.
    Thank you
  • grcarter5 Jul 07, 2008
    Yes, this solution is a confimration for me. It is what I thought, but i was hoping it might be fixable.
    I thank you for your help.
    Sergeant:
  • 275 Answers
You can go to this link because it is your machine manufacturer website. they can provide you assistance better .
http://www.lvw.com/support.htm
Posted on Jul 06, 2008
  • 1,512 Answers
Sorry to be the one to break it to yah man, but the it probably wont be worth the repair. A player this old could have more than one thing getting weak. I would just replace it. Best bet.
regards
robotek
    Guru:
  • 1,894 Answers
As a default try
please try a hard reset before going for next trys
disconnect it from the power and leave for 2 hours.
Posted on Jun 30, 2008
Can't get door open
You can solve the problem by opening the dvd recorder, look for the mechanism, on the mechanism u will see a motor attached with a rubber to rotate the wheel tray of the dvd recorder, check if the rubber is okay or not , also check the motor that drive the tray in and out, if otherwise the functional board of the dvd recorder is bad, then change the function board , or call a well skilled technician to handle it..
Hope this will help in solving the problem....
Aug 04, 2011 | Lite On LVW-5006 DVD Recorder
I have liteon lvw 5006, i am having problem with Ejecting the Disc.
good day sir...
your problem is on the ejecting motor,.The broken rubber that connected to the mechanism or on the motor itself...You have to do is....
first,Open the cover by removing all screws that holds the cover
secondly,Try to remove the lens assembly one set including the CD tray..by unscrew the lock of that mechanism...
thirdly,Try to see the ejecting motor if the rubber is okay and remove the motor to check the resistance weather it good or bad the reading is not more than 25 ohms or or try the actual testing using a 1.5v battery if the motor spin up that's good
fourthly,But when you found the trouble like on steps 2 and 3..replace immediately on the same type and ratings...its either motor or the rubber
And finally,if you found the defects re-assemble it and test it again...
Reminders;Pay attention to the alignment of the mechanism assembly to eject the DVD smoothly..
thank you and good luck.
Apr 11, 2011 | Lite On LVW-5006 DVD Recorder
When i turn on my unit it says hello. and will not do nothing , even if i turn it on & off what can i do thank you model liteon lvw 5006 dvd recorder
There is a capacitor on the power supply board that needs to be changed, if memory serves me it is a small 220uf capacitor, the recommended replacement is 470uf capacitor with a higher voltage rating.
Mar 17, 2011 | Lite On Televison & Video
Liteon dvd recorder won't play or record from disk or cable tv
You should be able to connect with the AV input, Y, Video R, W. Audio, they go to same color on DVD & TV.
Feb 18, 2010 | Lite On LVW-5005 DVD Recorder
Do i need remote
Yes you can't finalize without a remote.These units use a RM 51 remote.You can find one ebay or you can get a new one at Litetrekinternational.
Dec 21, 2008 | Lite On LVW-5006 DVD Recorder
Record a cd from a taperecorder to the LVW 5006 I own. Need hook
The LiteOn download page for manuals is http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=153  Category - video.  Model - LVW-5006.  User manuals available in English and French.
Nov 13, 2008 | Lite On LVW-5006 DVD Recorder
Unlock code for a liteon lvw-5006
Go into 'Setup'
Move the cursor to 'Exit'
Press 2 9 6 0
Set the region you want or region free
Sep 22, 2008 | Televison & Video
Lite On LVW-5005 DVD Recorder Logo
151 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
