URGENT HELP... i have broken my computer by OVERCLOCKING it...please help
Please advise me. i am a kid. i am not an expert in computers, so yesterday i decided to Overclok my computer. it was originally 216 Mhz. i am so stupid, because when i overclocked it the first time to 233Mhz, it worked fine. i thought i could make my computer go even faster, so overclocked it to the maximum 250 Mhz. now whenever i turn on the computer, the machine is "On" but the screen stays blank. I have broke my computer and my parents will kill me. I think the computer is possibly, overheated or damaged in some way. here is what happened:
I turn on the computer > press DEL to enter setup > blue setup screen appears. select Advanced Chipset features > DRAM configuration > Memclock Index Value (Mhz) > it was originally 216 Mhz. i over clocked it to 233, which worked. i am so stupid i did it to the maximum 250Mhz. then > F10, to save it. type "Y" for yes, when it asks if you want to save the setting. > the computer goes blank as it Restarts. When it was restarting, it made several Beeping Noises, and Moving Parts noises. The screen remained blank. when i realised it was "broken" i turned the computer off at the mains wall plug. The noises and blank screen till happen when i try to turn on the computer. i want to know if there is any way to fix it. the computer has my GCSE and AS schoolwork on it. Please help me. Nivedita
  • ntotheya Jun 30, 2008
    i can not return to the BIOS system setup on my computer, as, having overclocked it, my monitor is blank and doesn't work, even though the machine is "on".
Yes the pc beeps and and makes noises when i power up
i think i was overclocking the CPU.. i dont know what a VGA card is... i have not tested, but will test, my monitor on a different machine. Also, my monitor has hav problems recently, as it said the display driver was faulty. i think the monitor is the problem, but am not sure
Posted on Jul 03, 2008
    Sergeant:
  • 287 Answers
First of all, it seems unlikely that you have actually broken anything.
Please look carefully at the options in the main setup menu (BIOS) after you press the DEL key... There sshould be an option to "loade defalut settings" or "load optimised settings"
If so select this option and F10 to save/exit and allow it to boot
Posted on Jun 30, 2008
  • Dave Jul 01, 2008
    I would suggest that you remove the BIOS battery and allow the BIOS to reaset to default values.
    This is done by removing the cover and locating the BIOS battery and leaving it out for a while THIS ARTICLE may be of assistance in locating the BIOS battery and removing it.
    Once you install the baattery again see if the system will boot. If it does go into BIOS (usually press DEL to enter setup) and there should be an option to "load defaults" or similar. select this and F10 to save/exit
  • Dave Jul 01, 2008
    Hi ntotheya
    a few things to consider.
    does the PC make any noises or beeps when you power up?
    were you over clocking the CPU or VGA card?
    can you test the monitor on another machine
I have a business computer that will not connect to the internet. it didn't all day yesterday. Internet explorer says to unplug the modem/router but that would mess up all the other computers. please help....
try this to see if it works,unplug the network cable from your comp,then reboot it,after its booted completly,then shut it down then plug in the network cable and boot it up again.And make sure to check the network cable too.swap with another 1 to check it.
Oct 23, 2010 | Computers & Internet
HOW CAN I OVER CLOCK MY E7500 PROCESSOR??
Its so easy a child could do it, here is a link with step by step video guide as to how to over clock a computer, any problems get back to me as I am a expert with comps.
And please dont forget to rate me as this will help me to help others.
Here is the link.
http://www.wikihow.com/Overclock-a-PC
Cheers man
Feb 13, 2010 | Computers & Internet
Start up error overclocking problem
when u poerr up the computer press DEL or F2
then u enter in bios set date and save .
Nov 12, 2008 | Computers & Internet
I cannot use my Panasonic RR-US395 on my computer(Vista system)
I have lost the CD with the editing software and I cannot transfer data to computer
Sep 20, 2008 | Panasonic RR-US395 Digital Voice Recorder
How can I overclock my 166mhz classic computer?
Overclocking is not really recommended to be done by normal users. For overclocking your computer, you should have extensive knowledge of the hardware of your computer.
Overclocking may result in a totally non-working computer, burnt up Processor and motherboard and the likes. Also, overclocking results in heating problems, so you need to have made the arrangements for taking care of this heat issue.
Basically overclocking means increasing the Clock Speed of your comuter. Suppose I say that I have a Pentium 4 - 2.4GHz computer, the 2.4GHz part is the clock speed, which is increase in overclocking. Surely the computers with higher clock speeds work faster but that comes at a price. A small mistake on your part and your computer is no more working.
There are various Forums and sites on the internet that discuss Overclocking and its intricacies in greater detail.
Here's a pointer:
http://www.extremeoverclocking.com/
PS: Search google for "overclocking" and you should get a lotta links to work with.
Oct 13, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
