Question about Dell Computers & Internet
Dell laptop error message no boot sector on hard disk
  • 3,940 Answers
Sounds like you'll be getting a replacement hard drive.
Here are some things you can try.
  1. Reseat the hard drive, ensure it is seen and ID'd in the system BIOS.
  2. Run diagnostics on the drive is detected.
  3. If Diags pass/unavailable, you can try booting to an XP CD, enter recovery console, see if you can run a CHKDSK /R and fix the issue.
  4. Reformat the drive and reinstall.
If the drive fails to format or fails diagnostics, replace the drive.
Posted on Jun 29, 2008
Error 0x490
I think your windows boot configuration file is corrupted. May there are some bad sectors or else. What to do is use UBCD or Hiren BootCD and boot it offline and check the HARD disk using hard disk repair tools in any of those two.
Dec 06, 2012 | Dell XPS M1530 Laptop
No boot sector on internal hard drive. No bootable
A boot sector is a sector of a hard disk that contains booting programs stored in the other part of the hard disk. You boot sector might have been deleted or corrupted and you can't logon until you repair or recover the boot sector. To do this you must have your OS cd. Boot from OS cd the follow below steps...
Windows Vista
1. Insert the installation disc.
2. Restart your computer
3. If prompted, press any key to start Windows from the installation disc.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7.
On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Boot from you hard disk then you're done!
Regards,
Jeep Brainy
Jul 29, 2009 | Dell Inspiron 6000 Notebook
Blue Screen doesn't load Operating System. I beleive there is a software conflict when my daughter downloaded an application she needed for university
If you are getting 'Uncorrectable data Error or Media' for your internal hard drive then it is likely that you have a disk problem rather than a software conflict caused by anything your daughter downloaded.
If the Dell diagnostics provide no solution, then you would need to use a specialist boot CD to try to repair the disk errors. One such disk is Hiren's Boot CD which can be downloaded as a CD image file (.ISO) from http://www.hirensbootcd.org/ then would need to be burnt on to a blank CD then the laptop booted from this CD.
On the initial Hiren's boot menu, select DOS programs, then select Disk tools before selecting HDAT2 to perform the disk repair actions.
HDAT2 can take some time to complete depending on the size of your internal disk drive and the number of bad sectors or other errors encountered - the tool will attempt to repair bad sectors by reading, verifying, writing and re-reading / verifying the data.
If the disk can be recovered, then you may be lucky and the system will be able to boot but otherwise, you may still need to do some further recovery work for the operating system, in which case you may need your Windows install or recovery CD media.
Dec 22, 2011 | Dell Inspiron 6000 Notebook
I have dell inspiron 1525, with windows 7, and this message appear whenever trying to login to my pc.. "Windows failed to start, a recent hardware or software change might be the cause. File:...
The hard drive may had a BAD SECTOR ( corrupt section )
try to format with normal mode,NOT quick format.
try using LLFTOOL ( hard disk low level format ) http://hddguru.com
quite bit longer to fix the bad section,but works.
akee.4shared.com
Aug 15, 2011 | Dell Inspiron 1525 Laptop
I'm getting a stop error code 0X000000ED,0X86714368, 0X0000006, it's on a Dell Latitude D600 laptop?
Unmountable boot volume indicating that the system cannot successfully read the boot sector of the hard drive.
Run the diagnostics on the hard drive, if it fails, replace the hard drive.
If diags pass, boot to the recovery console, run chkdsk /r If it still gives the error after that, you can try reinstalling windows.
If that fails to resolve, then again, replace the hard disk drive
Nov 19, 2009 | Dell Latitude D600 Notebook
Latitude D510 Hard Drive S/N IDE 167K0396T error. The laptop will not boot. Error test found only 1 location. Read Test error 0f00:0244 at Block 5842740. Can Windows XP be repaired so the computer will...
If boot sector of this hard drive resides on block 5842740 then this is a problem. Try followings...
1. Boot with a XP CD, try to repair. OR
2. When PC boots are you able to go to safe mode by pressing F8? If yes, try Good Known Configuration option first.
3. Otherwise boot in safe mode, go to command prompt, type chkdsk and then reboot your PC and let it check disk. If it ask to find sector and block issues and wanted to gic them automatically, accept it.
Good luck....
Jamil
Oct 05, 2009 | Dell Latitude D510 Notebook
Dell b130 internal system restoration failed
Incase you don't have any thing important on the computer try a factory restore. This will wipe out everthing and make the cmputer like new. To start it power off the laptop. Power it on and hold down ctrl and tap f11 severl times at the Dell logo screen. Try this q couple of times as it may not work the first time. If this does nothing you'll need the os cd (xp cd) tO repair or reinstall windows.
Aug 07, 2009 | Dell Computers & Internet
Disk read error occured
If not give it a go and do a repair if needed again!
1- You may have a corrupt MBR (master boot record)!! You will need to reformat and do Fdisk /mbr to delete the master boot record!! Save all data first as this will not allow you to access any of your data as all file location addresses are located in the MBR!!
2 - Your harddrive may have a bad sector get a zerofill tool(low level formatting tool)!! This will rewrite you HD's sectors putting them back to factory spec's!! Maxtors is called Maxblast you can get it from thier site!!
3- or it could be a defective drive, but most read errors are due ot corrupt MBR or a bad sector!!
Mar 26, 2009 | Dell Inspiron 1525 Laptop Jet Black
Boot up failure
Fixed disc is refering to your hardrive and the fact that it has been unable to read a bad sector on your hard drive, that sector probably being where the boot.ini file resides. You will have to get the drive checked out, by means of an 2.5" ide to usb powered connector, which will connect to another pc's usb port to enable you to perform a disk check and a repair if possible of the bad sectors, or take to a local repairer where they should have the required adapters.
Aug 21, 2007 | Compaq Armada E500 Notebook
Computers & Internet Logo
485 people viewed this question
Alun Cox
