Question about Refrigerators
Ice cube tray not filling - Refrigerators
    Genius:
  • 1,036 Answers
The most common reason for this is the water filter at the back. This will provide less and less water to make ice with - so you can see it coming.
You can test this as follows -
Turn off water supply at the tap, (move fridge out to give yourself room)
Disconnect the pipe from the fridge side of the filter - place the unit in a bucket. Turn on the water supply and see that the output is a constant stream. If it's only a dribble - the filter needs replacing.
If the supply is good, the next thing to check is the control valve.
This can be disassembled and cleaned also.
If there is not a drop being dispensed, Then the control board is the most likely cause, and can be replaced as a unit, or repaired if you have time and equipment to do so.
Posted on Jun 29, 2008
Kenmore icemaker tray leaking water (model 795.51022.012)
Do the old 'KISS" thing first (keep it simple ......thing). Chances are that there are tiny calcium deposits in the ice tray which makes an ice cube stick in the tray. If one ice cube sticks, the water will overflow as it needs all the trays empty for the filling. The water will drip down into the freezer area causing chunky ice and stalagmites. The calcium deposits are very teeny in size but will hang up an ice cube from dropping. If more than one ice cube (basically all the ice cubes) didn't drop then the heater in that unit that initially gets the ice cubes to drop could be bad.
I've taken the ice cube assembly out and used vinegar with baking soda to dissolve the calcium and that worked. I left it in for a couple of days. "Do NOT" use anything like a knife or whatever to scrape the bottom of the tray as it will destroy the finish and keep the ice cubes sticking.
When I had the warranty service come out, the technician explained what happened to the tray (calcium). He replaced the tray but the next time it happened I used the vinegar and baking soda. I eventually bought a new tray for 1/2 the price on the internet when the problem happened later on in life.
Jun 13, 2014 | Kenmore Side by Side Refrigerator
Ice cubes wont come out when the dispenser tips it upside down
The ice mold tray has built up deposits that "glue" the ice cubes to the tray. This usually means you will have to change the mold tray. You could try vinegar or lemon juice to clean it but the trays are not that expensive.
Apr 12, 2014 | Refrigerators
My Bosch ice maker has a problem. It has frozen over and does not dispense the ice cubes, the refrigerator thinks it has dispensed the cubes and so try's to fill the ice cube tray up again with wa
Ice makers have heaters that loosen the cubes when time for harvest. Sounds like the heater on yours is bad, or maybe the ice maker itself is just bad. Most likely will have to replace ice maker.
Oct 12, 2017 | Bosch Refrigerators
Ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Aug 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
My ice cube tray is full...not dropping...and no clicking noise..
Hi first pls donot fill the ice tray full to its brim.... always fill it with less water because the volume increases when set... its easier to twist and remove the ice cubes
Aug 11, 2009 | True 598-TR1FRI1S Freezer Roll in One...
Ice cube tray not releasing cubes
The ice maker system is pretty simple.. A motor rotates with a gear reduction system and as it rotates... a switch is tripped when the motor reaches a certain point on its rotation... that switch lets water in for a prescribed period of time ( normally that is adjustable) and then as the motor rotates some more.. the ice tray has had adequate time for that ice to freeze and is positioned for it to be released,..at that time.. a small heating element is energized to release those ice cubes and the cubes fall from the tray into the bucket.. Chances are your heater is not working, unplugged or defective.. I would start by thawing everything out and getting the system free of any and all ice.. If after you've cleaned it all up.. and it still fails to release ice..you could be over-filling your tray and that freezes .. which in turn causes the system to fail too..You may need to adjust the fill level by throttle back on the water or if your system has a fill level control.. adjust that.. but first things first.. get the system back to a known good state.. ( meaning free from all ice ) so that you can monitor its performance,. Hope that helps...
Aug 16, 2008 | Samsung RS2578BB Side by Side Refrigerator
Ice cubes melt together
check the fill cup on the rear of the icemaker to see if any ice is frozen in the fill cup if so remove the ice
May 06, 2008 | Refrigerators
Water comes out the cubed ice portal and does not fill ice tray
scottt57 could have switched the wires on the solenoids. try switching them and observe where the water would come out..
Feb 12, 2008 | Refrigerators
My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Jan 30, 2007 | Kenmore 74172 / 74174 / 74179 Top Freezer...
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
