Question about Refrigerators
Water build up in bottom of refridge
I have a condo in Ocean City Md and periodically the bottom shelf below the crisper fills with water is this just condesation from the heat and humidity or is it a drain problem? When I pulled the refridge out the drain was completely dry.
    President:
  • 1,462 Answers
There is a blockage in the drain from the fridge. I am assuming that it is a conventional fridge with ice on back wall. half way down on the back wall, there is a sloping gulley with a drain in the middle. push something flexible down the drain to clear
Posted on Jun 29, 2008
Where can I find a schematic for the Ocean City 809 9/0 reel?
info on Ocean City reels
http://www.oceancityreelphotos.com/ocean-city-salt-water-numbered-reels.html
This one is more difficult as they are old. This is from the Penn reels website.
  • In 1922, Otto Henze left Germany at age 25 and came to the United States.
  • He began working as a machinist for the Ocean City Reels Company of Philadelphia.
  • But Mr. Henze had greater aspirations. Mr. Henze dreamed of one day owning his own company, and building fishing reels that would set world records.
  • Feb 25, 2016 | Fishing
    Amana fridge model number Arb1914cw is not cooling. Freezer is working fine
    Bottom freezer fridges are especially susceptible to
    1. Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
      • Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
      • Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
      • Replace plate and allow 24 hours for inside temp to stabilize.
      • Adjust top temp setting if needed to maintain safe temp level.
      • Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
    2. Airflow blockage through the crispers and meat keepers.
      • Remove crispers and meat keeper as well as glass cover shelf.
      • Find cooling passages between crispers and at midline of meat keeper.
      • Remove any buildup of air blocking debris.
      • Wipe up fridge box floor beneath meat keeper.
      • Reinstall glass shelf, meat keeper, and crispers.
      • Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
    Mar 16, 2015 | Amana Refrigerators
    My crisper drawers collect water
    adjust your settings for what you keep in there...and you should be able to solve the problem
    Oct 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
    Water build up
    Good Afternoon Friend,
    I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
    -Best Regards-
    WP
    May 29, 2014 | Frigidaire Refrigerators
    Puddles on top shelf and under crisper drawers
    This is not a major repair and also a very common problem. You will need to turn unit off and remove everything from inside the freezer. After this remove the back panel of the freezer and you will see ice built up at the bottom of the coils. You will have to remove all this ice and clear the defrost drain trough and tube. After the ice is removed you will see the defrost drain located about midways. Use a hair dryer to melt this then take a cup of very very very hot water and pour a little in the tube. Let stand for 5 minutes then dry it up real good and repeat. Do this till the drain clears and water flows freely. Then reassemble and you are good to go.
    May 28, 2010 | Kenmore 64802 Top Freezer Refrigerator
    My FRT8B5EW4 has water building up in the crisper drawers and on the glass shelf that covers the crispers.
    This is a common problem when the drain for the condensate from defrost tries to get to the pan below your refrigerator. Almost every blockage may be a little different. The trick is to find where it begins and eliminate that problem first and then cleaning the condensate drain line out with a wet and dry vacuum cleaner. Click on the link below and if you have any questions or need one on one assistance let me know, Thanks, Sea Breeze appliancepartsse@yahoo.com
    CLICK HERE=>HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
    Aug 20, 2009 | Frigidaire FRT17G4B Top Freezer...
    Water is pooling on the bottom shelf and in the
    Hi I can help you with this annoying problem.
    Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
    If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
    Jul 14, 2009 | Refrigerators
    Water on the bottom shelf of the Refridgerator
    Has the refrigerator got a wet inner back?
    Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
    The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
    However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
    Also, whether the refridgerator is either empty of full willaffe the day to day operation.
    Hope this helps.
    Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
    Water on bottom shelf of FRT15B3AW3
    is the fan still running in the freezer compartment???? it may be your defrost thermostat.....
    Aug 18, 2008 | Frigidaire FRT15B3A Top Freezer...
    Amana French door Refridge-water dispence inside the door not working
    pull out crisper and deli shelf thers a tank behind them its probably froazen, hit it fora few minutes especally around top neck portion with a hair dryer, common issue
    Jan 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
    Refrigerators Logo
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
