Question about Aiwa NSX-MTD9 Shelf System
Mtd riding yard machine - can't have blades engaged in reverse, daughter did this and now all I am getting is a clicking sound out of the transmission. Please advise.
  • 45 Answers
Without knowing the year and model number, I can only suggest checking your owners manual
You can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need the model & serial numbers.
Posted on Aug 25, 2009
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
Why won't the blades engage on my riding mower 54" mtd 13ap625k730?
You have probably thrown the belt for the blades. If it continues to throw the bet check the tensioner.
Aug 10, 2014 | Mtd Garden
Knocking sound in deck assembly of driving mower when driving without blades being engaged
sounds like bearing is broken if so replace this is dangerouse
to operate
Dec 10, 2013 | Yard Machines Garden
Riding mower will barely move
Sounds like it time for a tuneup. Air filter changed, Spark plugs replace and oil changed, plus sharpen the blades while you are at it.
Sep 26, 2009 | Mtd 22" Yard Machine Push Mower
I want to be able to back up with the blade
cut the wire on the safety switch just under the belt housing
Sep 19, 2009 | Mtd 22" Yard Machine Push Mower
Blades run in reverse and only for a short distance going forward
ok when was the last time you had the hydrolic fluid changed ?
or the oil for that mater ?
oil breaks down
you wouldnt cook your french fries in year old oil but you will cook your tranny with it in a cub or mtd machine 100-120 hours max for the fluids in an mtd b4 they start to loose texture or viscosity ( sound it out)
hydro pumps di die mtd has 1 monster that is quite expensive also have you changed the filter on the rear axcel lately or is it full of nut butter and in bypass mode
100 hours doesnt seam like much but for a tractor it is
service service service
Jul 25, 2009 | Garden
Mtd 17.5 will not start
Riding mower have three safety switches. One under the seat, one under the clutch and one on the blade lever. Make sure all are making contact as the button tip can get worn after many uses. These can be replaced. One trick you can try before that..
Sit on the mower and pull the blade engagement lever back further than necessary and hold it in that position while trying to start it. This may work as it puts more pressure on the safety switch button and makes contact possible.
May 21, 2009 | Mtd Products Yard Machines 158CC Tiller
My Yard Machines MTD blade won't engage. The belt that spins blade is loose when I try to engage deck.
My mtd 20 hp mower, blade will not engage, found a large spring and a small metal piece that came off and I have no Idea where it goes in order to get this blade going again, can some one give me some info Please..
Apr 19, 2009 | Garden
21hp Yard Machine
did you recently hit something while mowing? if you did chances are that one of the blades are out of balance or the shaft is bent
Sep 12, 2008 | Mtd Garden
Aiwa NSX-MTD9 Shelf System Logo
74 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
