Question about Hotpoint Aquarius WF000 Front Load Washer
Filter HOW DO I CLEAN THE FILTER FOR HOTPOINT WF740 WASHING MACHINE
  • 1 more comment
  • Anonymous Jul 18, 2008
    can't find the filter on my aquarius 800. hace eased off front bottom panel, found turning gadget but can't find where it should go
  • shans_kingdo Jul 20, 2008
    when empting filter will water come out worried cos lots of wires
  • Anonymous Mar 17, 2014
    My hotpoint wf740 is flashing f 02 and all my washing has come out really dirty
    President:
  • 1,462 Answers
Most hotpoint have a hidden filter
take back bottom panel off. you will see a large diameter hose coming from tub to pump. undo hose at tub end. filter is inside this hose. take it out and clean it
Posted on Jun 29, 2008
  • Hazel Hoult Sep 27, 2013
    how do i take the black hose off please as the person i bought washer off says i cannot do this myself and do you know where pump is please and how do i unblock this. Please help, thanks
We tried this and it works and got rid of the two error codes we had f-04 and f-05
thanks again
Posted on Apr 02, 2009
Where is the filter on my wf740 hotpoint
Maybe something jambed in pump, lint , coin or similar. Just fixed my LG machine coin in pump..Unsure of layout on Hotpoint but simply follow drain hose to pump.
Apr 17, 2013 | Washing Machines
Hi, I have a Hotpoint Aquarius+ WF740 washing machine which is around four years old. It has all of a sudden locked the door and will not open and is showing F 05 on the dispaly any help would be greatly...
Hotpoint (Indesit) 'F05' decodes as 'pump blocked'.
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Apr 06, 2011 | Hotpoint Washing Machines
I have a hotpoint wf740 which has had a bad smell coming from it, i took the front off the bottom, and unscrewed the filter which then snapped when i pulled it off as it was full of coins. (my dad gave me...
I think this is your pump and filter.
http://cgi.ebay.co.uk/hotpoint-indesit-drain-pump-and-filter-assy-new-sealed-/220605267643?cmd=ViewItem&pt=UK_Home_Garden_Washing_Machines_Dryers_Parts_Accessories_ET&hash=item335d193ebb
I spent a very long time looking for this. I recommend you look in your local phone book business pages for Appliance parts / supply and have your model number WF740 in hand. These complete pump assys appear to be cheaper than just the filter. You can order the new pump / filter assy and just use the filter for now.
Thanks for using FixYa,
Kelly
May 18, 2010 | Hotpoint Ultima WF860 Front Load Washer
How do you change brushes on a hotpoint aquarius washing machine
I have a Hotpoint Aquarius WF740. This does have brushes. Tilt the washing machine backwards & look underneath. The brushes can be seen on the motor housing, they are secured by two screws each.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My WF740 is also flashing F-05...unable to unlock door!!
The error F-05 indicates that no drain or pressure switch
jammed on full.
Sep 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Can you remove hotpoint bwm 12 washing machine filter
Hi, yes it is. Hotpoint bwm12 is a built-in washing machine, the filter is located at the bottom (black round knob). Undo the filter by turning it to the left (please be sure there's no water inside the machine, or getas much as possible out before opening the filter).
Cheers
Feb 19, 2009 | Washing Machines
Cant find filter on my hotpoint Ultima
Good luck. All modern washers that I know dont have the filter you need. If a clean out is needed you will have to clean out the pump.
Jan 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius Wf740 F-08 just before rinse and spin.
Hi my Hotpoint WF740 keeps flashin H20. Does anyone know why please?
Jan 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf740 washing machine
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Oct 01, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
822 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
