Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio 50 Thanks for the advice about the z sustain board. My tv also makes a poping noise like others have described. Do I need to repace more parts or should I through away the tv and duy a new one not a visio?
    New Friend:
  • 129 Answers
The popping noise is coming out from the speakers , because some electronic component is shorted like this Z board , it is important to you to know that you can spend less money fixing this one than buying a new one . be ready to spend between $300 to $700.00 in parts. if you choose to not fix
you always can recover your money . returning parts not used to the vendor and or selling your tv as it is.
Your rating to my answer is highly appreciate
thanks
Posted on Jun 29, 2008
Vizio TV, power went out no light and it poped.
Look on the power supply board for a swollen capacitor or a burn mark on the board. Do the same for all the other boards. You can get replacement parts here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 06, 2016 | Vizio Televison & Video
I have a Vizio P50HDTV10A 50 in. Plasma that gave off a loud noise before the picture and sound went off. I have seen on YouTube that when that occurs, it is usually the Y Sustain Board that needs to
Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Dec 08, 2014 | Vizio Televison & Video
Samsung 50" plasma HPS5033X/XAA shut off and will
HGi:
This model is nortorious for Y-sustain board failure, replace the Y-sustain board and you should be good to go. The Y-sustain board is the one while standing with back off the set is the board on the left side of the television.
Jul 05, 2011 | Samsung HP-T5044 50 in. Plasma TV
I have a 50 inch plasma vizio tv. I was watching it then i heard a pop the screen went black and i still had sounds yesterday but today no sound, I called vizio tech support they told me it was the gas...
when you here a loud pop its usually the sustainer boards. Have you checked the fuses on the sustainer boards first to see if they are still good. There is a IC chip under the heatsink and when it gets extremely hot it gives. Also check you power supply board to make sure you don't see any swollen capacitors, leaky or bulged out from the top. Let me know if that helps at all.
Oct 26, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
Heard a "pop" then went dead.
Sorry to say - it sounds like the 'pop of death'. The 50" Zenith plasma is very common for having a power failure issue. The problem resides in the Y-Sustain board in most cases. The Toshiba 50HP66 and Vizio P50HDM (as well as LG and HP 50" Plasmas) also have the same issue as they all use the same PDP Panel (plasma panel). The parts are manufactured by LG/Zenith Corporation. Since your Zenith is the model i'm thinking of (Z50PX2D), then the board you would need is the following:
http://www.discount-merchant.com/PCB-Y-SUS-MAIN-FOR-HP-HP-PL5060N-TELEVISION-p/2 761-hp-hp-pl5060n.htm
The above site is the ONLY place that I have ever found selling this hard to find part and the price is reasonable. If they are out of stock on that exact link, just search for 6870QYC004C on their site and you might find one that is in stock.
NOTE: Before making any purchases, please check the part and make sure it is what your TV needs. I am simply making recommendations and trying to point you to the right direction.
Dec 22, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Plasma does stay powered on
Your sustainer board is probably bad. You need to get the Y & Z sustainer boards replace then it should be okay.
Feb 08, 2009 | Vizio VP50 10A 50 in. Plasma TV
Vizio Replacing Sustainer Boards
I would start by replacing the fans as they are cheaper and easier to replace. Plasma tv's have a fail safe not to turn on if the fans dont work. If you bought at costco a couple of years ago you are in luck, take it back for a full refund.
Jan 15, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
TV has no display -- Need advice on Z Sustain Assembly Board
Send your board for repair / exchange - we service those by truckload :-)
http://www.coppelltvrepair.com .
Nov 25, 2008 | LG 50PX2DC 50 in. Plasma Television
Vizio 50
tv needs z sustain board to be replaced try www.vizioce.com or www.ebay.com the part # is on the board.
remove the back cover and is the board on your right side
your rating to my answer is highly appreciate
thanks
Jun 29, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
150 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
