Question about GE Profile Harmony DPGT750EC Electric Dryer
Electric Dryer runs/heats but takes double the time to dry than normal.
I have cleaned the lint trap and made sure the exhaust is venting and when it is running I put my hand in it and made sure it was hot.
1st question What should the inside temp at high temp?
2nd question Is there a hidden self test on the menu somewhere that GE uses during manufacturing or is there a user self test? I could not find one?
Thanks,
Paul
  • 54 Answers
The temp is between 153 deg and 189 deg and yes there is a tech mode.
Posted on Jul 04, 2008
GE Dryer DBSR453Eb2WW takes twice as long to dry clothes
A clogged or partially clogged vent will reduce the air flow through the dryer and greatly increase the drying time. I assume you checked the drying time again after you cleaned the vents. Have you also checked that the lint trap is clean? Make sure no lint has found it's way around the lint trap and has jammed the intake.
I would be very suspicious of the 240 v breaker double breaker feeding the dyrer; maybe the dryer is only running on 120 vac instead of the full 240vac. The motor would be getting full power, but the heating element would only be getting half power.
Mar 26, 2013 | Dryers
My dryer is heating up but it takes a long time to dry.
If the clothes are coming out wet and hot after the first cycle then there is a blockage in the exhaust. This blockage could be at the lint trap or at the exhaust tube leaving from the back of the dryer. You need to check the lint filter area by removing the lint filter and with a flashlight look into the area where the lint filter was to see if there is any build up of lint. If so, you will need to clean this area. Also at the back of the dryer there is a hose that comes from the dryer to an outlet to the out side. This hose could be clogged with lint or possibly kinked to where the proper amount of air flow is not allowed to leave the dryer therefore causing the clothes to have to dry longer. Check these two areas first before going any further due to these checks are simple and may solve the problem.
Good luck hope this helped
Dave
Mar 30, 2010 | GE DVLR223 Dryers
My electric dryer runs for awhile then it just shuts off after about 15 minutes of running? Its a neptune.
a couple of things here may be the problem.. First I would check to make sure my lint trap and the dryer exhaust is not full of lint causing the dryer to heat at a higher temp throwing the high limit switch into disconnect due to the amount of heat generated by the coils. This hi limit switch is a safety device to prvent fires. If you find a lot of lint in the dryer vent or the dryer lint trap, once cleaned, see if the machine doesn't operate like you want. Second. The motor bearings or strator may be going out and the motor is going into thermal overload and shutting down to prevent, as you guessed, a fire. I would check the lint trap and dryer exhaust first since it is more than likely the problem and is cheaper to fix. A wet/dry vac should do the trick. Also remove the back of the dryer to clean out the lint paying special attention to the area around the motor vent which can get blocked causing the motor to over heat. Once these vents are cleared the motor may be fine. Make sure to do all of the above with the dryer disconnected from the power source..
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
I have a Kenmore Elite dryer Model:110.C60952990 almost no heat.
Before assuming you may have a component failure, do a little routine inspection of the dryer and exhaust vent ducting.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be because the exhaust ventilation ducting is clogged. If you can't remember the last time the exhaust vent was cleaned, or if it has never been done, this can contribute to dryer performance problems. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat, causing poor drying results and eventual failure. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced.
There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted with the moisture from your clothing. If the exhaust vent is kinked or has excessive bends that create choke points, lint will accumulate in these points. Once the lint starts to accumulate, the moisture from your clothes starts to collect in it, and more lint get trapped. This eventually creates a clog. The Rule of Thumb: The SHORTER and STRAIGHTER the exhaust ventilation ducting, the BETTER.
A simple test to determine if you have a clog somewhere is to remove the dryer hose from the back of the dryer and attempt to dry a load of clothes as you normally would. The air escaping the back of the dryer should be forceful and warm (about 140 degrees). If the air flow is normal and the clothes dry as they should, then you need to inspect the ducting thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs.
If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect.
If your exhaust vent runs to an attic, this is a poor design that gravity will always win because of the resistance the blower fan meets trying to push the exhaust up the wall. The lint will eventually collect in the ducting going up the wall and have to cleaned out from time to time.
Also, make sure you don't crush the dryer hose behind the dryer when you push it up against the wall. You should always leave plenty of space behind a dryer to prevent this from happening.
Rodents and birds are anotehr cause of dryer problems. If they have access to the outside exhaust vents, birds will build nests in them and mice love a warm place with plenty of bedding material (lint makes a nice nest). Make sure the exhaust vent is at least a foot from the ground and use a louver type cover to keep pests outside. Do not use a screen. It can resist air flow and clog.
In addition, you should be using semi-rigid metal type ducting that resists kinking, crushing and rodent infestation.
If the air flow is weak, then you need to inspect the dryer INTERIOR to see if the air blower is working properly and is not clogged. It is important to keep a dryer checked routinely. Failue to do so can lead to component failures and is a potential fire hazard.
If you have questions, please let me know. I hope this helps you.
Sep 18, 2009 | Kenmore Elite HE4 Electric Dryer
Will not dry clothes fully. the machine heats fine but it takes two or more cycles to fully dry a little load. someone told me about a part that may need repaced around the lint trap.. Any ideas?
Your lint exhaust is blocking the heat flow.
Remove the vent from the rear of the dryer and run a timed cycle load for 40 minutes.
If laundry is dry, repair the outside vent.
If not dry,open the dryer cabinet and clean the inside lint and heat vent.
Mar 05, 2009 | Kenmore Dryers
Whirlpool duet electric dryer taking too long to dry
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Mar 03, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Relatively new dryer takes several cycles to dry normal loads
Check the lint trap all the way down to vent, then make sure that the vent is not crushed in anyway. Depending on the way the person cleaned it they could have actually caused more of a clog
Feb 11, 2009 | Whirlpool LER4634J Electric Dryer
Frigidaire dryer heats but clothes not drying
Nov 23, 2008 | Frigidaire GLER642A Electric Dryer
Dryer is heating but not get clothes dry...
make sure you have a strong air flow from the dryer it self take hose off and run the unit it should force your hand away if not your dryer is stopped up you will have to take fan casing off and clean (the metal going to hole for vent hose) if you do go outside and make sure you vent outside is opening and free of lint also wash your lint filter with warm soapy water fabric sheets stop them up and cause longer drying time
Nov 12, 2007 | Roper REX4634KQ Electric Dryer
Dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Jul 28, 2007 | GE DBSR453EBWW Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
56 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
