Question about Rainbow E series Canister Wet/Dry Vacuum
My Rainbow stopped running
I was using the Rainbow and it stopped running. Is there a fuse or reset button. Nothing happens when I turn the switch on.
  • 2 more comments
  • nicole wright Oct 01, 2008
    has anyone had any luck with this? I took mine apart and cleaned it and it still is having issues! It works for a few seconds then starts to smell bad then shuts itself off. After it cools down it will start back but the same thing happens all over again....
  • tusler Oct 09, 2008
    I have the same problem. It runs a few seconds and then stops....
  • shepsepp Nov 26, 2008
    lower setting of my Rainbow, e-series stopped working.
  • nsbskittle Dec 05, 2008
    Just got an e series on E- bay. waiting for all the parts to arrive. Do you need all the part to turn it on or can you turn on the vacuum without water basin. When I plug it in and turn it on nothing happens
Did you ever find out the problem with your rainbow? Mine did the same thing today- turned on the switch yet nothing happened. Think it needs a new switch???? Do you know how to get canister apart after taking out first screws?
Posted on Jul 19, 2008
  • Rainbow Expert
  • 324 Answers
It is a thermal shutt-off switch that tries to safe the motor. Smell indicates that there is somethng wrong with the motor so when it reaches certain temperature it shuts it off. You should not keep vacuuming with it as it may cause other motor components to burn and then repair costs will go up.
Posted on Oct 25, 2008
2 Suggested Answers
SOURCE: My Rainbow stopped running
I took my unit apart to clean it. I was careful to put it back the same way. Now it won't start.
Posted on Jul 13, 2008
My rainbow stop working.no red lights.3 times try to start and then switch off by itself.what should I do?
PDF]3 - Rainbow
rainbowsystem.com/.../Rainbow_e2_2011_R14449A-1_English_P...
RexairAs part of Rexair's Customer Care program, each Rainbow and Power Nozzle receives a ... If the Rainbow is not working ... Do not clean the unit or unclog the hose until theRainbow is switched off and the plug is removed from the wall ..... alone or with the Jet Brush attached. ..... The Power Nozzle brush is stopped and.
My Rainbow Vacuum Cleaner Won't Turn On ' eHow
Rainbow keeps shutting off Vacuums Questions & Answers ...www.fixya.com > Forum > Tags > keeps shutting off > VacuumsRainbow vacuums keeps shutting off related questions and answers. ... My Rainbowstopped running I was using the Rainbow and it stopped running. ... the switch . my electrolux has the same problem but wont always turn on.so it probably is ...Three common problems with Power Nozzles and how to fix ...
Dec 03, 2015 | Rainbow Vacuums
E series Canister Wet/Dry Vacuum: My tank foamed up into the motor and now the rainb...
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 17, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Have a rainbow e-2 that was running and quit.
Thank you,
Ralph
Apr 25, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Overflow .. HELP
Thank you,
Ralph
One other thing, water sucking through your vacuum should not hurt it. It is not good though, but will not make it not run.
Thank you again,
Ralph
Apr 21, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E-series will not turn on
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also. Thank you, Ralph
One other thing. All E series vacuums have a built in circuit breaker on the motor. Some of the earlier ones, it was only a fuse, and if it blew, it had to be replaced, or removed and wired directly without it on there. Most of them have a automatic reseting curcuit breaker, that will blow and auto reset its self, after it cools off. They do sometimes stay blown also, and do not reset. If that is the case, it has to also be replaced, or removed, and wired directly, with out it on there.
Motor brushes are usually the source of a non working E-2 vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature.
Thank you again,
Ralph
Apr 05, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e2 system. Will not power up
the water basin has a safety on it so the unit cannot run without it. if you look on the bottom of the rainbow you can see a small oval shaped space that you can depress just to test and see if it still runs it will only run with this depressed.
Oct 11, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Powerhead on rainbow not working
If the motor is NOT running - press the red button on the nozzle (assuming you have the model with the button on the nozzle)
If it stops working as soon as you release the button - you need a new circuit breaker. If Motor in the nozzle works but brush does not spin - you have to replace the belt.
Good Luck
Nov 20, 2008 | Rainbow 75th Anniversary Canister Vacuum
Jul 07, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
1,793 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
