Question about Nikon D200 Body Only Digital Camera
Dust inside my d200
I have some dust in my sensor? If look at the viewfinder I see alot of dust and hair like particles.
  • 667 Answers
The view finder and focusing screen are separate from the CCD sensor. The mirror reflects the image to the view finder until you take a picture. Then the mirror goes up, the shutter opens to expose the CCD to capture the image.
If you have a lot of dust, you should look into a cleaning kit, or have it professionally cleaned. This will show up on your images as white and/or black specks.
Posted on Jun 30, 2008
Looking for a dust resistant furniture solution
Anti-static fabric spray, neutralizes charged particles.
Dec 25, 2013 | Motorcycles
How I will clean my Laptop Keyboard.
Hi Shravan Chakravarty,
You may want to refer the below link to clean the laptop keyboard:
http://bit.ly/qCVqTs
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Nov 16, 2013 | Samsung Computers & Internet
Spot on viewfinder and picture
Whoops! Clicked the wrong icon before. Here's my solution:
The spot is most likely a spec of dust that is on or in the cameras' lens or optical sensor (the sensor is the "film" in digital cameras). Dust is a problem for the SLR type cameras (the kind that have removable lenses) as the camera body is open when swapping lenses. Your camera does not have the ability to accept different lenses - so the chances of dust is minimized - but not impossible. When zooming, the lens extends and creates suction inside. When air is drawn in, a particle of dust was could have been brought in at the same time. Most of the time, dust will vary in appearance from a sharp, irregular shaped object to a fuzzy, rounder object - depending on whether the lens is zoomed in or zoomed out. A professional cleaning should be able clear this problem. Contact a camera shop for an estimate.
Other times, this is a much more sinister issue. The optical sensor has developed a problem. The optical sensor or simply "sensor", is a small rectangular semi-conductor that is sensitive to light. The size is often stated in "pixels". The are about 10 million pixels on a 10 megapixel camera's sensor. One of the sensor's has stopped responding to light focused on it by the lens. Depending on how it failed, this will appear either as a sharp, black dot in the same place of every picture if is failed "off" (this is called a dead pixel), or as a sharp colored dot in the same place of every picture if it failed "on" (this is called a hot pixel). Unfortunately, dead and hot pixels can not be fixed individually. The entire sensor must be replaced as a unit. This can be a costly repair depending on the camera make and model and sometimes it is better to buy new instead of investing money in an older camera. Again, consulting with a camera shop that does repairs or even the manufacturer in this case is in order for the best estimate of what repairs may cost. Good luck!
Jan 08, 2012 | Kodak EasyShare Z981 Digital Camera
Curser will not move
check out the mouse. It may be caused due to the some dust particle occured in the sensors of the mouse.just clean the dust inside from the mouse and then check out whether the mouse is working properly or not.
May 27, 2011 | Computers & Internet
I see some hair inside the lenss when i look thru the view finder
It's very unlikely to get hair inside the lense. You probably see the hair on the reflex mirror of your camera. Remove the lense, Check inside the camera body for any dirt, dust, hair etc. Take a blower-brush (you can get one from the nearest camera dealer) and gently blow-brush away any particles from the mirror and the cavity. DO NOT use any force and don't touch the curtain shutter as it can easily be damaged. Don't touch the insides of the camera with your fingers, since the grease from the fingertips attract dust. Replace the lense. The hair should be gone now.
Jul 04, 2010 | Canon EOS Rebel G 35mm SLR Camera
IN MY JUST PURCHASED UNIT I HAVE ENCOUNTERED WHAT APPEARS TO BE DUST OR PARTICLE SPECKS IN THE VIEWING SURFACE WHICH ARE MOT RELATED TO THE NEGATIVES OR SKIDES. I HAVE SCANNED APPROXIMATELU 900 SLIDES AND...
Most of these devices have photoelectric sensors build-in, which tells the unit whether there is too much paper dust on the sensors, When there is too much paper dust covering the sensor, the device will report to the User that there is too much paper dust on the sensor, and the device will not function properly, due to the build up of paper dust.
Get a can of compressed air and gently spray inside the device, to remove the build up of paper dust,
-a.
Dec 06, 2009 | Pacific Image Electronics Memor-ease...
Dust spots on images
this will give you the idea how to clean the lens and have lens cover which is available in market to protect it from dust
http://www.picturecorrect.com/photographytips/207/cleaning_camera_lens.htm
thank you
Sep 22, 2009 | Leica M8 Digital Camera
Hair and particles on pictures-not on lens or mirror-on sensor
You must have dusty mirror box area. Here is what you should do. 1. Remove lens from the body. 2. Blow out any dust from the mirror box area using can duster (careful not to spew out liquid). 3. go to menu and select mirror up or ccd clean mode. You can also set at manual shutter speed "B" and hold up the mirror. 4. Blow out dusts over the CCD sensor (Do Not Use can air! If any liquid sprayed on CCD the cleaning gets worse) so use Hand-squeezee air bulb. You can purchase one from any camera stores.) 5. test shots and repeat. 6. If this procedure did not resolve the removal of the dust, you can purchase a cleaning solution package and try it. I do not recommend it becasue our techs get lots of cleaning requests from these package. Remember, if you are using these solution, 1. Never give any pressure to the screen, just tissuie touch pressure only. 2. move circular motion as you mouth blow the air as you move. complete the motion exiting through the corner of the screen. Did not work? send it to repair techinician! Our tech cleans it for $49. 24 hour turn around and also checks the camera too. Good Luck
Mar 26, 2009 | Nikon D70s Digital Camera
Black particles on focusingscreen
If the specks are just on your viewfinder focussing screen, they won't be on your pics. If they're on both your pics and focussing screen, you need to find someone else to clean your camera. Cleaning either your CCD sensor or your screen yourself can leave scratches. Changing lenses often can suck dust into the inside if the body is dusty. Try another repair shop for thorough cleaning - it shouldn't cost more than $50.
Dec 17, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
550 Problem: Dust collecting inside Viewfinder
I had hoped that a few people would check their cameras and posted replies before I contacted Pentax about my dust problem, but nobody has so far. But it's interesting that someone else posted a message this morning that he has some dust inside the lens of his 550. Anyway, this morning Pentax Canada told me that there should definitely be NO dust inside the viewfinder or the rest of the camera for that matter. Although the Viewfinder is "almost sealed" from the rest of the camera, it is not a total seal - which means to me that if dust can get into the viewfinder, it can get into the rest of the camera's interior - including the lens and imaging chip. They have asked me to bring my camera in so they can remove any dust particles that are inside. Basically, they told me that the only place I should see any dust is inside the lens cover, which is meant only as a protective covering rather than a seal from dust. Even then, they claim that any dust on the outer lens would only enter while the camera is being used. That one I don't buy, as the lens cover is very flimsy and can easily be accidentally spread open while the camera is turned off.
Sep 08, 2005 | Pentax Optio 550 Digital Camera
Nikon D200 Body Only Digital Camera Logo
149 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
