Question about Philips Televison & Video
I have a Philips 23pf9946/12 LCD tv. The problem is a black vertical strip, possibly electronic, which appears 1/3 from left hand side of screen and about 3" wide. If I switch off the set for 1/2 an hour and switch it back on it goes but appears 20 minutes later, first as a broken signal and then solid black strip. Any solutions welcome. Chris
wyoed1
  • 211 Answers
SOURCE: green vertical lines on the screen
Sounds like you may have some bad filter capacitors in the convergence board. Better take a close look at them before they damage the chips. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
  • 121 Answers
SOURCE: lcd tv picture,on start up
is this a rear projection tv? a table top one? how old is it because if it's over a few years old, then it sounds as if the bulb may be going out but without having more info, it's hard to give an accurate advice.. please let me know if this helps..
Posted on Feb 27, 2008
  • 208 Answers
SOURCE: Green spot / glow in center left side of Panasonic PT-61LCX65 LCD Projection HDTV
This unit has a chonic issue with corruption in the eeprom that causes spots and shadows. The correction is to find some service center that has the jig to hook up to your unit and correct the eeprom. This is an extended warranty issue with Panasonic and if you contact them they should be able to refer you a qualifed service center and Panasonic will pay.
Posted on Apr 08, 2008
SOURCE: Samsung DLP vertical black lines
I did some reading on this. They said its caused by a faulty DMD board. I understand it's costly... around $700 to replace. Still looking for a cheaper avenue...
Posted on Aug 30, 2008
SOURCE: Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Posted on Jan 19, 2009
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Bravia KDL46w5500. Why does it display vertical lines all over the screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 30, 2015 | Sony Televison & Video
How do I resolve a problem with a black vertical line that's appeared approx. 2 inches from the left side of the TV screen?
Apr 27, 2015 | Emerson LC401EM2F 40" Inch LCD Full HD TV
Vertical black bar on my LG 47" LCD shifting the image to the right
Two possibilities are there. The first one is, with loose LVDS cable, that connects the T'Con board to display panel. The second is the fault with its main digital processor board.
May 21, 2013 | LG 47LC7DF 47 in. LCD HDTV
NTV Scree
All plasma an lcd tvs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help....
Jun 28, 2010 | Televison & Video
I have a Samsung LN32A550 LCD TV. When I turn on my TV, there is a dark rectangular strip 3 1/2 inch in width on the left side of the screen. It is not that obvious, but noticeable. The strip does not go...
One thing you can try IF you know how to work with electronics.
Unplug and remove back cover. Remove the metal cover on the LCD Controller card. (it near the top of set) You may have to disconnect the top of the "H" frame to get to it. Disconnect and carefully re-connect the flat ribbon cable for the left side of the display. (The right side is good so don't touch it.) The connector for the flat ribbons will flip up to release the ribbon. The ribbon is short so this is tricky to do right. You may need a small plastic tool to help. Dont' break the connector. With the card back in place check if the band is still present. If vertical lines appear on the display, unplug and reposition the cable again until they are gone.
Don't touch the contacts on the connectors.
Re-assemble the set. No parts should be left over !!
LCD Controllers for this set are for sale on eBay if need.
Feb 17, 2009 | Samsung LN32A550 32 in. LCD TV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Transparent blue band
THIS IS MOST LIKELY TERMINAL. YOU NEED A NEW PANNEL. YOU CAN TRY TO TAKE OFF THE BACK COVER AND RESEAT ALL THE RIBBON CABLES THAT GO TO THE PANNEL. IF THIS DOSEN'T FIX IT, BUY A NEW TV.
Apr 23, 2008 | Philips 17PF9946 17 in. HDTV-Ready LCD...
Vertical black line on screen
Your set has either a bad driver board or more likely a bad plasma panel.
Oct 18, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
